有个项目要用到cyclone III,ep3C16Q240,于是在网上买了块cIII的板子。以前用cII,还是很顺手的,但是现在问题在于,AS口和JTAG口都可以用,跑纯数字逻辑没为题。在NIOS下run也没问题,可就是在NIOS环境下载后,无法从epcs启动,我设置程序运行在片内ram中,用的quartus 9.0.
烧写后,出现以下提示,说明程序已经下载到epcs中了,可就是跑不了,求大侠指点啊,崩溃了,点了个流水灯花了两天时间,郁闷啊!
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/Project/6_EP3C16Q240_project/Demonstrations/2_SDRAM_test/software/hello_wo
rld_0/Release
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="D:/Project/6_EP3C16Q240_project/
Demonstrations/2_SDRAM_test/SDRAM_test.sof" --output="SDRAM_test.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=SDRAM
_test.opt D:/Project/6_EP3C16Q240_project/Demonstrations/2_SDRAM_test/SDRAM_test
.sof SDRAM_test.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 70 megabytes
Info: Processing ended: Sat Mar 23 14:03:55 2013
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:03
Info: Command: quartus_cpf --no_banner --convert SDRAM_test.pof SDRAM_test.rpd
Info: Peak virtual memory: 68 megabytes
Info: Processing ended: Sat Mar 23 14:04:00 2013
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:04
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00000000 --sidp=0x0
0001810 --id=1020735803 --timestamp=1364008731 --instance=0 "SDRAM_test.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00001810: verified
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00020000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
00020000 : Reading existing contents
Checksummed/read 16kB in 0.3s
00000000 ( 0%): Erasing
00010000 (33%): Erasing
00020000 (66%): Erasing
Erased 192kB in 1.7s (112.9kB/s)
00000000 ( 0%): Programming
00010000 (33%): Programming
00020000 (66%): Programming
Programmed 177KB +15KB in 4.6s (41.7KB/s)
Did not attempt to verify device contents
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="SDRAM_test.flash" --input="hello
_world_0.elf" --output="epcs.flash"
# Programming flash with the project
0001810 --id=1020735803 --timestamp=1364008731 --instance=0 "epcs.flash"
Checksummed/read 49kB in 1.2s
00020000 ( 0%): Erasing
Erased 64kB in 0.5s (128.0kB/s)
00020000 ( 0%): Programming
Programmed 16KB +48KB in 1.5s (42.6KB/s)
