SN8ICE2K Plus II 仿真器
一个简单的产生PWM波的程序,仿真器中运行没有出错,但是检测仿真器的I/O口,却没有波形输出。
请教下各位朋友,是怎么回事额?代码如下:- TITLE MyFirstTimeA
- CHIP SN8P2712
- //{{SONIX_CODE_OPTION
- .Code_Option LVDM LVD_L ; 2.0V Reset
- .Code_Option Low_Power Disable
- .Code_Option Reset_Pin P01
- .Code_Option Watch_Dog Disable ; Disable Watchdog
- .Code_Option High_Clk 12M_X'tal ; Crystal/Resonator: 10Mhz~16Mhz
- .Code_Option Fcpu #3 ; Fcpu = Fosc/8 ; If Low_Power enable, Fcpu should be less than or equal to 2MIPS.
- .Code_Option Security Disable
- .Code_Option Noise_Filter Disable
- //}}SONIX_CODE_OPTION
- .DATA
- DS 1
- TMP2 DS 4
- TMP0 EQU 5
- TMP1 = 6
- TMPA EQU 7
- .CODE
- ORG 0
- JMP MAIN
- ORG 0x8
- ORG 0x10
- MAIN:
- MOV A, #0
- B0MOV TMP0, A
- B0MOV TMP1, A
- B0MOV TMP2, A
- B0MOV TMP2+1, A
- B0MOV TMP2+2, A
- B0MOV TMP2+3, A
- MOV A, #0xFF
- B0MOV P4M ,A
- B0MOV P4UR, A
- MOV A, #0x0F
- B0MOV P4, A
- LOOP_MAIN:
- XOR P4, A
- INCMS TMP0
- NOP
- INCMS TMP1
- NOP
- INCMS TMP2
- NOP
- CALL DELAY
- JMP LOOP_MAIN
- DELAY:
- B0MOV TMPA, A
- MOV A, #56
- MOV R, A
- LOOP:
- DECMS R
- JMP LOOP
- B0MOV A, TMPA
- RET
- ENDP
复制代码 |
