发表于 2013-3-25 16:48:10
fickle 发表于 2013-3-21 09:43
赞同这个回答,看数据手册上写着呢。
omap3530这个芯片也忒强悍!
这个是不是要自己写驱动吧?
我在板子要移植的linux系统中搜gpmc相关的文件,结果如下:
./arch/arm/plat-omap/include/plat/gpmc-smc91x.h
./arch/arm/plat-omap/include/plat/gpmc.h
./arch/arm/mach-omap2/gpmc.c
./arch/arm/mach-omap2/gpmc-smc91x.c
./arch/arm/mach-omap2/gpmc.o
./arch/arm/mach-omap2/gpmc-onenand.c
里边的gpmc.h gpmc.c文件又是怎么回事呢?如果是驱动的话,应该在driver文件夹下面才对啊!
下面是gpmc.h的内容,您帮我分析一下这是什么?谢谢!
* General-Purpose Memory Controller for OMAP2
* Copyright (C) 2005-2006 Nokia Corporation
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#ifndef __OMAP2_GPMC_H
#define __OMAP2_GPMC_H
/* Maximum Number of Chip Selects */
#define GPMC_CS_NUM 8
#define GPMC_CS_CONFIG1 0x00
#define GPMC_CS_CONFIG2 0x04
#define GPMC_CS_CONFIG3 0x08
#define GPMC_CS_CONFIG4 0x0c
#define GPMC_CS_CONFIG5 0x10
#define GPMC_CS_CONFIG6 0x14
#define GPMC_CS_CONFIG7 0x18
#define GPMC_CS_NAND_COMMAND 0x1c
#define GPMC_CS_NAND_ADDRESS 0x20
#define GPMC_CS_NAND_DATA 0x24
#define GPMC_CONFIG 0x50
#define GPMC_STATUS 0x54
#define GPMC_CONFIG1_WRAPBURST_SUPP (1 << 31)
#define GPMC_CONFIG1_READMULTIPLE_SUPP (1 << 30)
#define GPMC_CONFIG1_READTYPE_ASYNC (0 << 29)
#define GPMC_CONFIG1_READTYPE_SYNC (1 << 29)
#define GPMC_CONFIG1_WRITEMULTIPLE_SUPP (1 << 28)
#define GPMC_CONFIG1_WRITETYPE_ASYNC (0 << 27)
#define GPMC_CONFIG1_WRITETYPE_SYNC (1 << 27)
#define GPMC_CONFIG1_CLKACTIVATIONTIME(val) ((val & 3) << 25)
#define GPMC_CONFIG1_PAGE_LEN(val) ((val & 3) << 23)
#define GPMC_CONFIG1_WAIT_READ_MON (1 << 22)
#define GPMC_CONFIG1_WAIT_WRITE_MON (1 << 21)
#define GPMC_CONFIG1_WAIT_MON_IIME(val) ((val & 3) << 18)
#define GPMC_CONFIG1_WAIT_PIN_SEL(val) ((val & 3) << 16)
#define GPMC_CONFIG1_DEVICESIZE(val) ((val & 3) << 12)
#define GPMC_CONFIG1_DEVICESIZE_16 GPMC_CONFIG1_DEVICESIZE(1)
#define GPMC_CONFIG1_DEVICETYPE(val) ((val & 3) << 10)
#define GPMC_CONFIG1_DEVICETYPE_NOR GPMC_CONFIG1_DEVICETYPE(0)
#define GPMC_CONFIG1_DEVICETYPE_NAND GPMC_CONFIG1_DEVICETYPE(2)
#define GPMC_CONFIG1_MUXADDDATA (1 << 9)
#define GPMC_CONFIG1_TIME_PARA_GRAN (1 << 4)
#define GPMC_CONFIG1_FCLK_DIV(val) (val & 3)
#define GPMC_CONFIG1_FCLK_DIV2 (GPMC_CONFIG1_FCLK_DIV(1))
#define GPMC_CONFIG1_FCLK_DIV3 (GPMC_CONFIG1_FCLK_DIV(2))
#define GPMC_CONFIG1_FCLK_DIV4 (GPMC_CONFIG1_FCLK_DIV(3))
#define GPMC_CONFIG7_CSVALID (1 << 6)
* Note that all values in this struct are in nanoseconds, while
* the register values are in gpmc_fck cycles.
struct gpmc_timings {
/* Minimum clock period for synchronous mode */
u16 sync_clk;
/* Chip-select signal timings corresponding to GPMC_CS_CONFIG2 */
u16 cs_on; /* Assertion time */
u16 cs_rd_off; /* Read deassertion time */
u16 cs_wr_off; /* Write deassertion time */
/* ADV signal timings corresponding to GPMC_CONFIG3 */
u16 adv_on; /* Assertion time */
u16 adv_rd_off; /* Read deassertion time */
u16 adv_wr_off; /* Write deassertion time */
/* WE signals timings corresponding to GPMC_CONFIG4 */
u16 we_on; /* WE assertion time */
u16 we_off; /* WE deassertion time */
/* OE signals timings corresponding to GPMC_CONFIG4 */
u16 oe_on; /* OE assertion time */
u16 oe_off; /* OE deassertion time */
/* Access time and cycle time timings corresponding to GPMC_CONFIG5 */
u16 page_burst_access; /* Multiple access word delay */
u16 access; /* Start-cycle to first data valid delay */
u16 rd_cycle; /* Total read cycle time */
u16 wr_cycle; /* Total write cycle time */
/* The following are only on OMAP3430 */
u16 wr_access; /* WRACCESSTIME */
u16 wr_data_mux_bus; /* WRDATAONADMUXBUS */
extern unsigned int gpmc_ns_to_ticks(unsigned int time_ns);
extern unsigned int gpmc_ticks_to_ns(unsigned int ticks);
extern unsigned int gpmc_round_ns_to_ticks(unsigned int time_ns);
extern unsigned long gpmc_get_fclk_period(void);
extern void gpmc_cs_write_reg(int cs, int idx, u32 val);
extern u32 gpmc_cs_read_reg(int cs, int idx);
extern int gpmc_cs_calc_divider(int cs, unsigned int sync_clk);
extern int gpmc_cs_set_timings(int cs, const struct gpmc_timings *t);
extern int gpmc_cs_request(int cs, unsigned long size, unsigned long *base);
extern void gpmc_cs_free(int cs);
extern int gpmc_cs_set_reserved(int cs, int reserved);
extern int gpmc_cs_reserved(int cs);
extern int gpmc_prefetch_enable(int cs, int dma_mode,
unsigned int u32_count, int is_write);
extern void gpmc_prefetch_reset(void);
extern int gpmc_prefetch_status(void);
extern void omap3_gpmc_save_context(void);
extern void omap3_gpmc_restore_context(void);
extern void __init gpmc_init(void);
#endif |
