今天想用FPGA的nios来测试我做的DAC900E。然后写的C代码如下:
#include <stdio.h>
#include "system.h"
typedef struct
unsigned long int DATA;
unsigned long int DIRECTION;
unsigned long int INTERRUPT_MASK;
unsigned long int EDGE_CAPTURE;
}PIO_STR;
#define DAC_CLK ((PIO_STR *) CLK_DAC900_BASE)
#define DAC_DATA ((PIO_STR *) DATA_DAC900_BASE)
#define Delay 10000
int main()
unsigned int sinTABLE[64]= {512,562,611,660,707,752,795,836,873,907,936,962,984,1000,1013,1020,1023,1020,1013,1000,984,962,936,907,873,836,795,752,707,660,611,562,\
511,461,412,363,316,271,228,187,150,116,87,61,39,23,10,3,1,3,10,23,39,61,87,116,150,187,228,271,316,363,412,461};
unsigned int count = 0;
DAC_CLK->DATA = 0;
printf("Hello from Nios II!\n");
//DAC_DATA->DATA = sinTABLE[count];
DAC_DATA->DATA = 600;
DAC_CLK->DATA = 1;
//usleep(Delay-10);
DAC_CLK->DATA = 0;
DAC_DATA->DATA = 511;
DAC_CLK->DATA = 1;
//if(count=count+1)>=64)
//count = 0;
return 0;
注释掉的代码是我原来测试正弦波用的。
代码中没有垃圾的代码。现在生成的方波才3M多。
所以用FPGA这么高级的芯片用nios就可惜了。
还有大家注意对quartusII的工程编辑后一定要重新下载软核,要不会因为system id好对应不上无法下载。 |
