现在屏幕一直是白屏,用LCD_ReadReg(0x00)能读出驱动芯片的型号为9320
各位能帮我看下我的代码有没有问题吗,现在是寄存器的数据写不进去,不明白是什么原因,个人觉得应该是硬件方面的问题。谢谢各位了!
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : lcd.c
* Author : MCD Application Team
* Version : V1.0.1
* Date : 03/07/2013
* Description : This file includes the LCD driver for AM-240320L8TNQW00H
* (LCD_ILI9320) Liquid Crystal Display Module of STM3210E-EVAL
* board.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
//#include "main.h"
//#include "fonts.h"
#include "etl240320.h"
#include "network.h"
#include "stm32f10x_gpio.h"
/* LCD is connected to the FSMC_Bank1_NOR/SRAM4 and NE4 is used as ship select signal */
//#define LCD_REG (*((vu16 *) 0x60000000)) /* RS = 0 */
//#define LCD_RAM (*((vu16 *) 0x60020000)) /* RS = 1 */
#define LCD_RAM (*((vu16 *) 0x60080000)) /* RS = 1 */
#define AM 1 //1:横屏, 0:竖屏(DS中为默认值)
#define ID 3 //屏扫方式
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Global variables to set the written text color */
static vu16 TextColor = 0x0000, BackColor = 0xFFFF;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name : Decrement_TimingDelay
* Description : Decrements the TimingDelay variable.
* Input : None
* Output : TimingDelay
* Return : None
void Decrement_TimingDelay(void)
if (TimingDelay != 0x00)
TimingDelay--;
* Function Name : Delay
* Description : Inserts a delay time.
* Input : nCount: specifies the delay time length (time base 10 ms).
* Output : None
* Return : None
void Delay(u32 nCount)
TimingDelay = nCount;
/* Enable the SysTick Counter */
SysTick_CounterCmd(SysTick_Counter_Enable);
while(TimingDelay != 0)
/* Disable the SysTick Counter */
SysTick_CounterCmd(SysTick_Counter_Disable);
/* Clear the SysTick Counter */
SysTick_CounterCmd(SysTick_Counter_Clear);
//* 函数名 : void delay ( u16 times )
//* 功能 : delay times
//* 输入参数 : 无
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
vu32 i;
while (times --)
for (i = 0x00; i < DELAYTIME; i ++)
i = i;
* Function Name : STM3210E_LCD_Init
* Description : Initializes the LCD.
* Input : None
* Output : None
* Return : None
void LCD_Init(void)
u16 i;
u16 a,b,c,d,e,f;
BackLight_Set();
/* Configure the LCD Control pins --------------------------------------------*/
// delay(1000);
LCD_CtrlLinesConfig();
// sea_printf("starting....LCD CtrlLineConfig\n");
/* Configure the FSMC Parallel interface -------------------------------------*/
// delay(10000);
LCD_FSMCConfig();
//a = LCD_ReadReg(0x00);
//while(a);
// sea_printf("starting....LCD FSMCConfig\n");
// delay(1000);
// delay(1000); /* delay 50 ms */
// sea_printf("starting.....LCD 1 \n");// %0x\n",LCD_ReadReg(0x00));
// delay(5000);
// LCD_WriteReg(0x0000,0x0001);
//GPIO_WriteBit(GPIOD, GPIO_Pin_10, Bit_SET);
//sea_printf("starting.....LCD 2\n");
// delay(5000);
// GPIO_WriteBit(GPIOD, GPIO_Pin_13, Bit_RESET);
// sea_printf("starting.....LCD 2\n");
LCD_WriteReg(0xe3,0x3008);
LCD_WriteReg(0xe7,0x0012);
LCD_WriteReg(0xef,0x1231);
// LCD_WriteReg(0xe5,0x8000);
LCD_WriteReg(0x00,0x0000);//0001
LCD_WriteReg(0x01,0x0100);
LCD_WriteReg(0x02,0x0700);
LCD_WriteReg(0x03,0x1030); //1038 1018//(1<<12)|(1<<5)|(1<<4)
LCD_WriteReg(0x04,0x0000);
LCD_WriteReg(0x08,0x0202);//020E//(2<<8)|(2<<0)
LCD_WriteReg(0x09,0x0000); /* set non-display area refresh cycle ISC[3:0] */
LCD_WriteReg(0x0a,0x0000);/* FMARK function */
LCD_WriteReg(0x0c,(1<<0));//0x0001/* RGB interface setting */
LCD_WriteReg(0x0d,0x0000);/* Frame marker Position */
LCD_WriteReg(0x0f,0x0000);/* RGB interface polarity */
delay(50);
LCD_WriteReg(0x07,0x0101);
delay(50);
LCD_WriteReg(0x10,(1<<12)|(0<<8)|(1<<7)|(1<<6)|(0<<4));//0x0000 //Power Control 1.(0x16b0)
LCD_WriteReg(0x11,0x0007); //Power Control 2.(0x0001)
LCD_WriteReg(0x12,(1<<8)|(1<<4)|(0<<0)); //0x0000//Power Control 3.(0x0138)
LCD_WriteReg(0x13,0x0b00); //Power Control 4.
//++delay(50);
// ++LCD_WriteReg(0x10,0x1290); //Power Control 1.(0x16b0)
//++LCD_WriteReg(0x11,0x0221); //Power Control 2.(0x0001)
//++delay(50);
//++LCD_WriteReg(0x12,0x001a); //Power Control 3.(0x0138)
//++delay(50);
//++LCD_WriteReg(0x13,0x1600);
LCD_WriteReg(0x29,0x0000);//0x0022
LCD_WriteReg(0x2b,(1<<14)|(1<<4)); //0x000a//frame rate and color control(0x0000) 0x0020
delay(50);
LCD_WriteReg(0x20, 0x0000); // GRAM horizontal Address
LCD_WriteReg(0x21, 0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
LCD_WriteReg(0x30, 0x0007);
LCD_WriteReg(0x31, 0x0302);
LCD_WriteReg(0x32, 0x0105);
LCD_WriteReg(0x35, 0x0206);
LCD_WriteReg(0x36, 0x0808);
LCD_WriteReg(0x37, 0x0206);
LCD_WriteReg(0x38, 0x0504);
LCD_WriteReg(0x39, 0x0007);
LCD_WriteReg(0x3c, 0x0105);
LCD_WriteReg(0x3d, 0x0808);
/* Set GRAM area -------------------------------------------------------------*/
LCD_WriteReg(0x50,0x0000);/* Horizontal GRAM Start Address */
LCD_WriteReg(0x51,0x00ef);/* Horizontal GRAM End Address */
LCD_WriteReg(0x52,0x0000);/* Vertical GRAM Start Address */
LCD_WriteReg(0x53,0x013f);/* Vertical GRAM End Address */
LCD_WriteReg(0x60,0x2700);/* Gate Scan Line (1<<15)|(0x27<<8)*/
LCD_WriteReg(0x61,0x0001); /* NDL,VLE, REV, 0x0000:互补色显示*/
LCD_WriteReg(0x6a,0x0000);/* set scrolling line */
/* Partial Display Control ---------------------------------------------------*/
LCD_WriteReg(0x80,0x0000);
LCD_WriteReg(0x81,0x0000);
LCD_WriteReg(0x82,0x0000);
LCD_WriteReg(0x83,0x0000);
LCD_WriteReg(0x84,0x0000);
LCD_WriteReg(0x85,0x0000);
/* Panel Control -------------------------------------------------------------*/
LCD_WriteReg(0x90,(0<<7)|(16<<0));//0x0010
LCD_WriteReg(0x92,0x0000);
LCD_WriteReg(0x93,0x0001);//0x0003
LCD_WriteReg(0x95,0x0110);
LCD_WriteReg(0x97,(0<<8));//0x0000
LCD_WriteReg(0x98,0x0000);
//LCD_WriteReg(0x03,0x1000);
//display on sequence
LCD_WriteReg(0x07,0x0173);/* 262K color and display ON */
//LCD_WriteReg(0x32,0x0000);
//LCD_WriteReg(0x33,0x013f);
//LCD_WriteReg(0x22,0x0022); // 写0x22寄存器,
LCD_Clear(White);
//LCD_Test();
* Function Name : LCD_SetTextColor
* Description : Sets the Text color.
* Input : - Color: specifies the Text color code RGB(5-6-5).
* Output : - TextColor: Text color global variable used by LCD_DrawChar
* and LCD_DrawPicture functions.
* Return : None
void LCD_SetTextColor(vu16 Color)
TextColor = Color;
* Function Name : LCD_SetBackColor
* Description : Sets the Background color.
* Input : - Color: specifies the Background color code RGB(5-6-5).
* Output : - BackColor: Background color global variable used by
* LCD_DrawChar and LCD_DrawPicture functions.
* Return : None
void LCD_SetBackColor(vu16 Color)
BackColor = Color;
void LCD_Test(void)
/* Set the LCD Back Color */
LCD_SetBackColor(Red);
/* Set the LCD Text Color */
LCD_SetTextColor(Red);
//LCD_DisplayStringLine(Line5," LCD TEST ");
LCD_SetTextColor(Green);
LCD_DrawCircle(50,50,10);
//void Button1(u16 Xpos, u8 Ypos, vu16 Color) //blocked by ray 10/06/28
// s16 i = 0;
// LCD_SetTextColor(Color);
// for(i = 0; i < 5; i++)
// LCD_DrawCircle(Xpos, Ypos, i);
//void Button(u16 Xpos, u8 Ypos, vu16 Color)
// LCD_DrawRect(Xpos, Ypos, 80, 40);
//void Manu(void)
// s16 i = 0;
// s16 j = 0;
// LCD_Clear(Yellow);
// delay(50);
// LCD_SetBackColor(Green);
// for (i = 0; i < 4; i++)
// for (j = 0; j < 6; j++)
// Button(i * 80, j * 40, Magenta);
* Function Name : LCD_ClearLine
* Description : Clears the selected line.
* Input : - Line: the Line to be cleared.
* This parameter can be one of the following values:
* - Linex: where x can be 0..9
* Output : None
* Return : None
//void LCD_ClearLine(u8 Line)
// LCD_DisplayStringLine(Line, " ");
* Description : Clears the hole LCD.
* Input : Color: the color of the background.
* Output : None
* Return : None
void LCD_Clear(u16 Color)
u32 index = 0;
LCD_SetCursor(0x00, 0x00);
LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
for(index = 0; index < 76800; index++)
LCD_RAM = Color;
* Function Name : LCD_SetCursor
* Description : Sets the cursor position.
* Input : - Xpos: specifies the X position.
* - Ypos: specifies the Y position.
* Output : None
* Return : None
void LCD_SetCursor(u16 Xpos, u8 Ypos)
LCD_WriteReg(0x20,Xpos); // 行
LCD_WriteReg(0x21,Ypos); // 列
* Function Name : LCD_DrawChar
* Description : Draws a character on LCD.
* Input : - Xpos: the Line where to display the character shape.
* - Ypos: start column address.
* - c: pointer to the character data.
* Output : None
* Return : None
void LCD_DrawChar(u16 x, u8 y, uc16 *c)
u16 index = 0;
s32 i = 0;
u16 Yaddress = 0;
Yaddress = y;
LCD_SetCursor(x,Yaddress);
for(index = 0; index < 24; index++)
for(i = 0; i < 16; i++)
if((c[index] & (1 << i)) == 0x00)
LCD_WriteRAM(BackColor);//BackColor
LCD_WriteRAM(TextColor);//TextColor
Yaddress++;
* Function Name : LCD_DisplayChar
* Description : Displays one character (16dots width, 24dots height).
* Input : - Line: the Line where to display the character shape .
* - Column: start column address.
* - Ascii: character ascii code, must be between 0x20 and 0x7E.
* Output : None
* Return : None
//void LCD_DisplayChar(u16 Column, u8 Line, u8 Ascii) //blocked by ray ASCII 10/06/28
// Ascii -= 32;
// LCD_DrawChar(Column, Line, &ASCII_Table[Ascii * 24]);
// LCD_DrawChar(Line, Column, &ASCII_Table[Ascii * 24]);
* Function Name : LCD_DisplayStringLine
* Description : Displays a maximum of 20 char on the LCD.
* - *ptr: pointer to string to display on LCD.
* Output : None
* Return : None
//void LCD_DisplayStringLine(u8 Line, u8 *ptr)
// u32 i = 0;
// u16 refcolumn = 0;
/* Send the string character by character on lCD */
// while ((*ptr != 0) & (i < 20))
// /* Display one character on LCD */
// LCD_DisplayChar(refcolumn, Line, *ptr);
// /* Decrement the column position by 16 */
// refcolumn += 16;
/* Point on the next character */
// ptr++;
/* Increment the character counter */
// i++;
* Function Name : LCD_SetDisplayWindow
* Description : Sets a display window
* Input : - Xpos: specifies the X buttom left position.
* - Ypos: specifies the Y buttom left position.
* - Height: display window height.
* - Width: display window width.
* Output : None
* Return : None
//void LCD_SetDisplayWindow(u16 Xpos, u8 Ypos, u8 Height, u16 Width)//需修改 blocked by ray 10/06/28
// /* Horizontal GRAM Start Address */
// if(Xpos >= Height)
// LCD_WriteReg(R80, (Xpos - Height + 1));
// else
// LCD_WriteReg(R80, 0);
// /* Horizontal GRAM End Address */
// LCD_WriteReg(R81, Xpos);
// /* Vertical GRAM Start Address */
// if(Ypos >= Width)
// LCD_WriteReg(R82, (Ypos - Width + 1));
// else
// LCD_WriteReg(R82, 0);
// /* Vertical GRAM End Address */
// LCD_WriteReg(R83, Ypos);
// LCD_SetCursor(Xpos, Ypos);
* Function Name : LCD_WindowModeDisable
* Description : Disables LCD Window mode.
* Input : None
* Output : None
* Return : None
void LCD_WindowModeDisable(void)//需修改
// LCD_SetDisplayWindow(239, 0x13F, 240, 320);
LCD_WriteReg(R3, 0x1038); //0x1030
* Function Name : LCD_DrawLine
* Description : Displays a line.
* - Length: line length.
* - Direction: line direction.
* This parameter can be one of the following values: Vertical
* or Horizontal.
* Output : None
* Return : None
void LCD_DrawLine(u16 Xpos, u8 Ypos, u16 Length, u8 Direction)
u32 i = 0;
if(Direction == Horizontal)
for(i = 0; i < Length; i++)
Ypos++;
* Function Name : LCD_DrawRect
* Description : Displays a rectangle.
* - Height: display rectangle height.
* - Width: display rectangle width.
* Output : None
* Return : None
//void LCD_DrawRect(u16 Xpos, u8 Ypos, u16 Width, u8 Height)
// LCD_DrawLine(Xpos, Ypos, Width, Horizontal);
// LCD_DrawLine(Xpos, (Ypos + Height) , Width, Horizontal);
// LCD_DrawLine(Xpos, Ypos, Height, Vertical);
// LCD_DrawLine((Xpos + Width - 1), Ypos , Height, Vertical);
* Function Name : LCD_DrawCircle
* Description : Displays a circle.
* Output : None
* Return : None
void LCD_DrawCircle(u16 Xpos, u8 Ypos, u16 Radius)
s32 D;/* Decision Variable */
u32 CurX;/* Current X Value */
u32 CurY;/* Current Y Value */
D = 3 - (Radius << 1);
CurX = 0;
CurY = Radius;
while (CurX <= CurY)
LCD_SetCursor(Xpos + CurX, Ypos + CurY);
LCD_SetCursor(Xpos + CurX, Ypos - CurY);
LCD_SetCursor(Xpos - CurX, Ypos + CurY);
LCD_SetCursor(Xpos - CurX, Ypos - CurY);
LCD_SetCursor(Xpos + CurY, Ypos + CurX);
LCD_SetCursor(Xpos + CurY, Ypos - CurX);
LCD_SetCursor(Xpos - CurY, Ypos + CurX);
LCD_SetCursor(Xpos - CurY, Ypos - CurX);
if (D < 0)
D += (CurX << 2) + 6;
D += ((CurX - CurY) << 2) + 10;
CurY--;
CurX++;
* Function Name : LCD_DrawMonoPict
* Description : Displays a monocolor picture.
* Input : - Pict: pointer to the picture array.
* Output : None
* Return : None
//void LCD_DrawMonoPict(uc32 *Pict) //blocked by ray 10/06/28
// u32 index = 0, i = 0;
// LCD_SetCursor(0, 0);
// LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
// for(index = 0; index < 2400; index++)
// for(i = 0; i < 32; i++)
// if((Pict[index] & (1 << i)) == 0x00)
// LCD_WriteRAM(BackColor);
// else
// LCD_WriteRAM(TextColor);
* Function Name : LCD_WriteBMP
* Description : Displays a bitmap picture loaded in the internal Flash.
* Input : - BmpAddress: Bmp picture address in the internal Flash.
* Output : None
* Return : None
void LCD_WriteBMP(u32 BmpAddress) //blocked by ray 10/06/28
u32 index = 0, size = 0;
/* Read bitmap size */
size = *(vu16 *) (BmpAddress + 2);
size |= (*(vu16 *) (BmpAddress + 4)) << 16;
/* Get bitmap data address offset */
index = *(vu16 *) (BmpAddress + 10);
index |= (*(vu16 *) (BmpAddress + 12)) << 16;
size = (size - index)/2;
BmpAddress += index;
/* Set GRAM write direction and BGR = 1 */
/* I/D=00 (Horizontal : decrement, Vertical : decrement) */
/* AM=1 (address is updated in vertical writing direction) */
LCD_WriteReg(R3, 0x1038);//0x1008
for(index = 0; index < size; index++)
LCD_WriteRAM(*(vu16 *)BmpAddress);
BmpAddress += 2;
/* I/D = 01 (Horizontal : increment, Vertical : decrement) */
/* AM = 1 (address is updated in vertical writing direction) */
LCD_WriteReg(R3, 0x1038);//0x1018
* Function Name : LCD_WriteReg
* Description : Writes to the selected LCD register.
* Input : - LCD_Reg: address of the selected register.
* - LCD_RegValue: value to write to the selected register.
* Output : None
* Return : None
void LCD_WriteReg(u8 LCD_Reg, u16 LCD_RegValue)
/* Write 16-bit Index, then Write Reg */
LCD_REG = LCD_Reg;
/* Write 16-bit Reg */
LCD_RAM = LCD_RegValue;
* Function Name : LCD_ReadReg
* Description : Reads the selected LCD Register.
* Input : None
* Output : None
* Return : LCD Register Value.
u16 LCD_ReadReg(u8 LCD_Reg)
/* Write 16-bit Index (then Read Reg) */
LCD_REG = LCD_Reg;
/* Read 16-bit Reg */
return (LCD_RAM);
* Function Name : LCD_WriteRAM_Prepare
* Description : Prepare to write to the LCD RAM.
* Input : None
* Output : None
* Return : None
void LCD_WriteRAM_Prepare(void)
// LCD_REG = R34;
LCD_REG = 0x22;
* Description : Writes to the LCD RAM.
* Input : - RGB_Code: the pixel color in RGB mode (5-6-5).
* Output : None
* Return : None
void LCD_WriteRAM(u16 RGB_Code)
/* Write 16-bit GRAM Reg */
LCD_RAM = RGB_Code;
* Function Name : LCD_ReadRAM
* Description : Reads the LCD RAM.
* Input : None
* Output : None
* Return : LCD RAM Value.
u16 LCD_ReadRAM(void)
LCD_REG = R34; /* Select GRAM Reg */
return LCD_RAM;
* Function Name : LCD_PowerOn
* Description : Power on the LCD.
* Input : None
* Output : None
* Return : None
void LCD_PowerOn(void) //需要修改
/* Power On sequence ---------------------------------------------------------*/
LCD_WriteReg(R16, 0x0000); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
LCD_WriteReg(R17, 0x0007); /* DC1[2:0], DC0[2:0], VC[2:0] */
LCD_WriteReg(R18, 0x0000); /* VREG1OUT voltage */
LCD_WriteReg(R19, 0x0000); /* VDV[4:0] for VCOM amplitude*/
delay(200); /* Dis-charge capacitor power voltage (200ms) */
LCD_WriteReg(R16, 0x17B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
LCD_WriteReg(R17, 0x0227); /* DC1[2:0], DC0[2:0], VC[2:0] 0x0001*/
delay(50); /* Delay 50 ms */
LCD_WriteReg(R18, 0x001c); /* VREG1OUT voltage 0x013e*/
LCD_WriteReg(R19, 0x1800); /* VDV[4:0] for VCOM amplitude 0x1c00*/
LCD_WriteReg(R41, 0x001c); /* VCM[4:0] for VCOMH 0x001e*/
LCD_WriteReg(R7, 0x0173); /* 262K color and display ON */
* Function Name : LCD_DisplayOn
* Description : Enables the Display.
* Input : None
* Output : None
* Return : None
void LCD_DisplayOn(void)//需要修改
/* Display On */
* Function Name : LCD_DisplayOff
* Description : Disables the Display.
* Input : None
* Output : None
* Return : None
void LCD_DisplayOff(void)//需要修改
/* Display Off */
LCD_WriteReg(R7, 0x0);
* Function Name : LCD_CtrlLinesConfig
* Description : Configures LCD Control lines (FSMC Pins) in alternate function
Push-Pull mode.
* Input : None
* Output : None
* Return : None
void LCD_CtrlLinesConfig(void)
/* Enable FSMC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB |
RCC_APB2Periph_GPIOC |RCC_APB2Periph_GPIOD |
RCC_APB2Periph_GPIOE |RCC_APB2Periph_GPIOF |
RCC_APB2Periph_GPIOG |RCC_APB2Periph_AFIO, ENABLE);
/* Set PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE), PD.08(D13), PD.09(D14),
PD.10(D15), PD.14(D0), PD.15(D1) as alternate
function push pull */
/*GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 |
GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);*/
/*2013.02.23 LCD FSMC模式下数据线与控制线配置*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_14|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOE, &GPIO_InitStructure);
/* Set PD.13(A18 (RS)) as alternate function push pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
/*背光控制*/
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);//GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Set PD.11(A16 (RS)) as alternate function push pull
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
//GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
//GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Set PD.7(NE1 (LCD/CS)) as alternate function push pull - CE3(LCD /CS) */
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
// Configure only the gpio relative to the led LD1
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//2013.02.23改 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
//GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
// clear (turn off) all the configured leds
//BackLight_Set();
BackLight_Clear();
* Function Name : LCD_FSMCConfig
* Description : Configures the Parallel interface (FSMC) for LCD(Parallel mode)
* Input : None
* Output : None
* Return : None
void LCD_FSMCConfig(void)
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef p;
/*-- FSMC Configuration ------------------------------------------------------*/
/*----------------------- SRAM Bank 1 ----------------------------------------*/
/* FSMC_Bank1_NORSRAM1 configuration */
#if 0
p.FSMC_AddressSetupTime = 0;
p.FSMC_AddressHoldTime = 0;
p.FSMC_DataSetupTime = 2;
p.FSMC_BusTurnAroundDuration = 0;
p.FSMC_CLKDivision = 0;
p.FSMC_DataLatency = 0;
p.FSMC_AccessMode = FSMC_AccessMode_B;
// p.FSMC_AddressSetupTime = 0x02;
// p.FSMC_AddressHoldTime = 0x00;
// p.FSMC_DataSetupTime = 0x05;
// p.FSMC_BusTurnAroundDuration = 0x00;
// p.FSMC_CLKDivision = 0x00;
// p.FSMC_DataLatency = 0x00;
// p.FSMC_AccessMode = FSMC_AccessMode_B;
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;//FSMC_Bank1_NORSRAM1; FSMC_Bank1_NORSRAM2
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;//++FSMC_MemoryType_SRAM; FSMC_MemoryType_NOR
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;//FSMC_ExtendedMode_Disable FSMC_ExtendedMode_Enable
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
/* Enable FSMC_Bank1_NORSRAM1 */
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
* Function Name : void BackLight_Set ( u32 ledsel )
* Description : Set BackLight
* Input : None
* Output : None
* Return : None
void BackLight_Set (void )
// GPIO_WriteBit(GPIOC, GPIO_Pin_6, Bit_RESET);
GPIO_WriteBit(GPIOC, GPIO_Pin_7, Bit_SET);
} // end BackLight_Set()
* Function Name : void BackLight_Clear ( u32 ledsel )
* Description : Clear BackLight
* Input : None
* Output : None
* Return : None
void BackLight_Clear ( void )
GPIO_WriteBit(GPIOC, GPIO_Pin_7, Bit_RESET);//GPIO_WriteBit(GPIOC, GPIO_Pin_6, Bit_RESET);
} // end BackLight_Clear()
/* 4 functions related to programe transplant */
//* 函数名 : void Ssd2119InitDisplay ( void )
//* 功能 : initialize lcd display
//* 输入参数 : 无
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
LCD_Init();
//* 函数名 : void Ssd2119PutPixel ( int x, int y, U16 color )
//* 功能 : LCD打点函数
//* 输入参数 : int x , int y坐标, u16 color 颜色
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
void Ssd2119PutPixel ( u16 x, u8 y, u16 color )
LCD_SetCursor(x, y);
LCD_WriteRAM( color );
//* 函数名 : void Ssd2119GetPixel ( int x, int y )
//* 功能 : get LCD color
//* 输入参数 : 无
//* 输出参数 : int color 颜色
//* 修改记录 : 无
//* 备注 : 无
u16 Ssd2119GetPixel ( u16 x, u8 y )
return LCD_ReadRAM();
//* 函数名 : void Ssd2119ClrScreen ( void )
//* 功能 : clear screen
//* 输入参数 : 无
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
u16 bkcolor = (u16)getbkcolor();
LCD_Clear( bkcolor );
//* 函数名 : void Etl240320InitDisplay ( void )
//* 输入参数 : 无
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
LCD_Init();
//* 函数名 : void Etl240320PutPixel ( int x, int y, U16 color )
//* 功能 : LCD打点函数
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
void Etl240320PutPixel ( u16 x, u8 y, u16 color )
//* 函数名 : void Etl240320GetPixel ( int x, int y )
//* 输入参数 : 无
//* 修改记录 : 无
//* 备注 : 无
u16 Etl240320GetPixel ( u16 x, u8 y )
//* 函数名 : void Etl240320ClrScreen ( void )
//* 输入参数 : 无
//* 输出参数 : 无
//* 修改记录 : 无
//* 备注 : 无
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
