显示程序是没问题的,我调试了。我调试的时候发现,adc的EOC端居然不输出高电平了,也就是说ADC总是处于正在装换阶段了,因此程序就到了WaitADCEnd()这个函数这里停止不前,把这个函数忽略了就有显示了,由于我之前没做个ADC的调试和写程序,所以特地问下有做个ADC给1602显示的这方面的经验,谢谢啦!
#include <reg52.h>
/*ADC转换处理---------------------*/
sbit ST =P2^0;
sbit EOC=P2^1;
sbit OE =P2^2;
sbit CLK=P3^0;
//#define P1data P1
#define uint unsigned int
uchar getdata;//从adc0809读取的数据
void Delay(uchar delay_ms)
for(delay_ms;delay_ms>0;delay_ms--)
uint i=120;
while(i--);
void ADC_Init()//AD初始化
P1=0xff;
OE =0;
ST =0;
//void StartADC (void)//开始转换
// ST=1;
void WaitADCEnd (void)//转换结束
while (!EOC); //EOC为1时,装换结束
void ReadData (void)//读取转换后的数据
// uint temp;
ST=0;
Delay(1);
ST=1;
Delay(1);
ST=0;
WaitADCEnd();
OE =1;
Delay(1);
getdata=P1;
// return(temp);
OE=0;
sbit Lcden=P3^4;
sbit RS =P3^5;
sbit RW =P3^6;
sbit duan =P2^6;
sbit wei =P2^7;
uchar code table[]="0123456789.UVIA=";
//显示读取的数处理
uchar date1,date2,date3,date4;
void DataProcessing()
uint temp1;
temp1=getdata;
date1=(temp1*50*9/255)/100;
date2=(temp1*50*9/255)%100/10;
date3=(temp1*50*9/255)%100%10;
void Lcd_write_com (uchar com) //根据硬件时序图写
RS=0;
P0=com;
Delay(3);
Lcden=1;
Delay(2);
Lcden=0;
void Lcd_write_date (uchar date)
RS=1;
P0=date;
Delay(3);
Lcden=1;
Delay(2);
Lcden=0;
void Lcd_Init()
duan =0;
wei =0;
Lcden=0;
RS =0;
RW =0;
Lcd_write_com(0x38);//设置16x2显示,5x7点阵,8位数据接口
Delay(1);
Lcd_write_com(0x0f);//开显示,光标,光标闪烁
Delay(1);
Lcd_write_com(0x06);//读或写一个字符地址指针加一,光标加一
Delay(1);
Lcd_write_com(0x01);//显示清屏,数据指针和所有显示清零
Delay(1);
Lcd_write_com(0x80);//数据指针初始化
void Display()
Lcd_write_com(0x80+1);
Delay(1);
Lcd_write_date(table[11]);
Delay(1);
Lcd_write_com(0x80+2);
Delay(1);
Lcd_write_date(table[15]);
Delay(1);;
Lcd_write_com(0x80+3);
Delay(1);
Lcd_write_date(table[date1]);
Delay(1);
Lcd_write_com(0x80+4);
Delay(1);
Lcd_write_date(table[date2]);
Delay(1);
Lcd_write_com(0x80+5);
Delay(1);
Lcd_write_date(table[10]);
Delay(1);
Lcd_write_com(0x80+6);
Delay(2);
Lcd_write_date(table[date3]);
Delay(2);
Lcd_write_com(0x80+7);
Delay(2);
Lcd_write_date(table[12]);
Delay(2);
//定时器0初始化
void TimerInit(void)
TMOD=0x05;//定时器0工作于模式一
TH0=(65536-10)/256;//频率为100khz
TL0=(65536-10)%256;
TR0=1;//启动定时器0
ET0=1;//打开定时器中断
EA=1;//开总中断
void main()
ADC_Init();//初始化
Lcd_Init();
TimerInit();
ReadData ();//adc读取数据
DataProcessing();//数据处理便于显示
Display();//数据数据显示
void Timer0irp (void) interrupt 1
CLK=~CLK;
TH0=(65536-10)/256;
TL0=(65536-10)%256;//定时器0频率为100khz
