发表于 2013-4-20 15:52:56
[µVision]
This MDK-ARM release is delivered with µVision V4.70.00 IDE.
New: Automatic Code Completion and Parameter Information.
New: Dynamic Syntax Checking.
Added: PA and PA Reset Performance Analyzer Commands in Command Window.
Refer to the Revision History for a more detailed list of changes.
[uVision Debugger]
New: Interface for Fast Models Debugger Driver. This driver allows debugging of applications simulated with Fast Models.
Upgraded: ULINK2 firmware to version 2.01.
When using a ULINK2 debug unit with MDK-ARM 4.70, the ULINK2 firmware will automatically be updated to version 2.01. This version of the firmware allows ULINK2 to be used as a CMSIS-DAP compliant debug unit in addition to the traditional ULINK2 operation mode.
A ULINK2 with upgraded firmware will not be detected by previous versions of MDK-ARM. To configure a ULINK2 for operation with previous versions of MDK-ARM, refer to the Configure Utility.
Updated: Segger J-Link driver for ARM devices to version 4.62.
以上是MDK4.7的更新说明,在Debuggger部分有提到使用MDK4.7的话ULINK2会自动升级固件到version 2.01,还有下面提到ULIKK2在固件升级后是不能被先前的MDK版本检测到的!
解决办法:
1.使用MDK4.7做开发
2.把ULINK2发回经销商,重新刷会低版本固件
3.因为MDK4.7也升级了Uvision,所以如果出现软件兼容性问题,就是时常崩溃或者编辑器显示异常,可考虑用C51安装包覆盖,使Uvision回滚到低版本! |
