发表于 2013-3-6 16:35:27
>> 请问这个功能包不包括所有的24C系列的存储器?
我个人的理解:使用 START 来 RESET I2C BUS 不是24C系列独有的,会适用到所有支恃 I2C 的元件:-
According to the I2C spec:
I2C-bus compatible devices must reset their bus logic
on receipt of a START or repeated START condition
such that they all anticipate the sending of a slave
address, even if these START conditions are not
positioned according to the proper format.
So·a·START condition is basically the same thing as a reset.
The "up to 9 clocks" are needed in case the other device is sending a zero byte
(hence holding SDA low for eight clocks). You don't HAVE to send all 9 clocks,
after each clock you are just looking for SDA to go high.
If SDA doesn't go high after 9 clocks, then something is really screwed up. |
