发表于 2013-2-16 07:20:19
pocker5200 发表于 2013-2-16 02:08 ![](static/image/common/back.gif)
不明所以……
看看 ALTERA 是这样骗使用者的,以下与memory大小无关
http://www.altera.com/support/kdb/solutions/rd03072012_576.html
Solution ID: rd03072012_576
Last Modified: Aug 13, 2012
Product Category: Design Software
Product Area: Design Entry/Planning
Product Sub-area: Megafunctions/MegaWizard
Version Found In: v10.0
Software: Quartus II Linux,Quartus II PC
Title
Could not create the Java virtual machine
Description
This error may be seen when starting the Quartus® II Megawizard™ Plug in Manager.
This error may be seen if you do not have sufficient physical memory in your computer. For details on required memory resources see the Quartus II device support release notes on the Quartus II Development Software Documentation page.
Workaround / Fix
To avoid this error, ensure your computer meets the minumum requirments in the device support release notes. If your computer meets the minimum requirements, but you are still seeing this problem, please contact mySupport for additional assistance. |
