首先,先贴代码
#include"W5100.h" /* 定义W5100的寄存器地址、状态 */
#include"REG51.h"
typedef unsigned char SOCKET;
#define S_RX_SIZE 2048 //定义Socket接收缓冲区的大小,可以根据W5100_RMSR的设置修改
#define S_TX_SIZE 2048 //定义Socket发送缓冲区的大小,可以根据W5100_TMSR的设置修改
#define FALSE 0
#define TRUE 1
sbit SPI_SCS= P1^5;
sbit SPI_SCK= P1^2;
sbit SPI_SO= P1^3;
sbit SPI_SI= P1^4;
sbit KEY= P1^7;
/* 端口数据缓冲区 */
unsigned char Rx_Buffer[16]; /* 端口接收数据缓冲区 */
unsigned char Tx_Buffer[16]; /* 端口发送数据缓冲区 */
/* 网络参数寄存器 */
unsigned char Gateway_IP[4]={192,168,10,1}; /* Gateway IP Address */
unsigned char Sub_Mask[4]={255,255,255,0}; /* Subnet Mask */
unsigned char Phy_Addr[6]={0x00,0x08,0xDC,0x01,0x02,0x03}; /* Physical Address */
unsigned char IP_Addr[4]={192,168,10,40}; /* Loacal IP Address */
unsigned char S0_Port[2]={0x1F,0x40}; /* Socket0 Port number 5000 */
unsigned char S0_DIP[4]={192,168,10,41}; /* Socket0 Destination IP Address */
unsigned char S0_DPort[2]={0x1F,0x40}; /* Socket0 Destination Port number 5000*/
unsigned char S0_State=0; /* Socket0 state recorder */
unsigned char S0_Data; /* Socket0 receive data and transmit OK */
unsigned char S_CONN=1;
unsigned char S_TRANSMITOK=2;
unsigned char S_RECEIVE=3 ;
unsigned char W5100_Interrupt;
/* UDP Destionation IP address and Port number */
unsigned char UDP_DIPR[4];
unsigned char UDP_DPORT[2];
void delayx10ms(unsigned int c)
unsigned int i,j,k;
for(i=0;i<c;i++)
for(j=0;j<10;j++)
for(k=0;k<120;k++);
void SPI_SendByte(unsigned char dat)
unsigned char i;
for(i=0;i<8;i++)
if(dat&0x80)
SPI_SI=1;
SPI_SI=0;
SPI_SCK=1;
dat<<=1;
SPI_SCK=0;
unsigned char Read_W5100(unsigned short addr)
unsigned char i,j;
/* 置W5100的CS为低电平 */
SPI_SCS=0;
/* 发送读命令 */
SPI_SendByte(0x0f);
/* 发送地址 */
SPI_SendByte(addr/256);
SPI_SendByte(addr);
/* 读取数据 */
j=0;
for(i=0;i<8;i++)
SPI_SCK=1;
j<<=1;
if(SPI_SO)
j|=0x01;
SPI_SCK=0;
/* 置W5100的CS为高电平 */
SPI_SCS=1;
return j;
void Write_W5100(unsigned short addr, unsigned char dat)
/* 置W5100的CS为低电平 */
SPI_SCS=0;
/* 发送写命令 */
SPI_SendByte(0xf0);
/* 发送地址 */
SPI_SendByte(addr);
/* 写入数据 */
SPI_SendByte(dat);
/* 置W5100的CS为高电平 */
SPI_SCS=1;
void W5100_Init(void)
unsigned char i;
SPI_SCK=0;SPI_SCS=1;SPI_SO=1;
Write_W5100(W5100_MODE,MODE_RST); /*软复位W5100*/
delayx10ms(10); /*延时100ms,自己定义该函数*/
/*设置网关(Gateway)的IP地址,4字节 */
/*使用网关可以使通信突破子网的局限,通过网关可以访问到其它子网或进入Internet*/
for(i=0;i<4;i++)
Write_W5100(W5100_GAR+i,Gateway_IP[i]); /*Gateway_IP为4字节unsigned char数组,自己定义*/
for(i=0;i<4;i++)
Gateway_IP[i]=Read_W5100(W5100_GAR+i);
/*设置子网掩码(MASK)值,4字节。子网掩码用于子网运算*/
for(i=0;i<4;i++)
Write_W5100(W5100_SUBR+i,Sub_Mask[i]); /*SUB_MASK为4字节unsigned char数组,自己定义*/
/*设置物理地址,6字节,用于唯一标识网络设备的物理地址值
该地址值需要到IEEE申请,按照OUI的规定,前3个字节为厂商代码,后三个字节为产品序号
如果自己定义物理地址,注意第一个字节必须为偶数*/
for(i=0;i<6;i++)
Write_W5100(W5100_SHAR+i,Phy_Addr[i]); /*PHY_ADDR6字节unsigned char数组,自己定义*/
/*设置本机的IP地址,4个字节
注意,网关IP必须与本机IP属于同一个子网,否则本机将无法找到网关*/
for(i=0;i<4;i++)
Write_W5100(W5100_SIPR+i,IP_Addr[i]); /*IP_ADDR为4字节unsigned char数组,自己定义*/
/*设置发送缓冲区和接收缓冲区的大小,参考W5100数据手册*/
Write_W5100(W5100_RMSR,0x55); /*Socket Rx memory size=2k*/
Write_W5100(W5100_TMSR,0x55); /*Socket Tx mempry size=2k*/
/* 设置重试时间,默认为2000(200ms) */
Write_W5100(W5100_RTR,0x07);
Write_W5100(W5100_RTR+1,0xd0);
/* 设置重试次数,默认为8次 */
Write_W5100(W5100_RCR,8);
/* 启动中断,参考W5100数据手册确定自己需要的中断类型
IMR_CONFLICT是IP地址冲突异常中断
IMR_UNREACH是UDP通信时,地址无法到达的异常中断
其它是Socket事件中断,根据需要添加 */
Write_W5100(W5100_IMR,(IMR_CONFLICT|IMR_UNREACH|IMR_S0_INT));
void Socket_Init(SOCKET s)
unsigned int i;
/*设置分片长度,参考W5100数据手册,该值可以不修改*/
Write_W5100((W5100_S0_MSS+s*0x100),0x00); /*最大分片字节数=16*/
Write_W5100((W5100_S0_MSS+s*0x100+1),0x10);
/* Set Socket Port number */
switch(s)
case 0:
Write_W5100(W5100_S0_PORT,S0_Port[0]); /* Set Local Socket Port number */
Write_W5100(W5100_S0_PORT+1,S0_Port[1]);
Write_W5100(W5100_S0_DPORT,S0_DPort[0]); /* Set Destination port number */
Write_W5100(W5100_S0_DPORT+1,S0_DPort[1]);
for(i=0;i<4;i++)
Write_W5100(W5100_S0_DIPR+i,S0_DIP[i]); /* Set Destination IP Address */
case 1:
case 2:
case 3:
default:
* @brief 设置Socket为客户端与远程服务器连接
*当本机Socket工作在客户端模式时,引用该程序,与远程服务器建立连接
*如果启动连接后出现超时中断,则与服务器连接失败,需要重新调用该程序连接
*该程序每调用一次,就与服务器产生一次连接
unsigned char Socket_Connect(SOCKET s)
Write_W5100((W5100_S0_MR+s*0x100), S_MR_TCP); /*设置socket为TCP模式 */
Write_W5100((W5100_S0_CR+s*0x100), S_CR_OPEN); /*打开Socket*/
if(Read_W5100(W5100_S0_SSR+s*0x100)!=S_SSR_INIT)
Write_W5100(W5100_S0_CR+s*0x100,S_CR_CLOSE); /*打开不成功,关闭Socket,然后返回*/
return FALSE;
Write_W5100((W5100_S0_CR+s*0x100),S_CR_CONNECT); /*设置Socket为Connect模式*/
return TRUE;
/*至此完成了Socket的打开连接工作,至于它是否与远程服务器建立连接,则需要等待Socket中断,
以判断Socket的连接是否成功。参考W5100数据手册的Socket中断状态*/
* @brief 设置Socket作为服务器等待远程主机的连接
*当本机Socket工作在服务器模式时,引用该程序,等等远程主机的连接
*该程序只调用一次,就使W5100设置为服务器模式
* @return 如果设置成功则返回true, 否则返回false
unsigned char Socket_Listen(SOCKET s)
Write_W5100(W5100_S0_PORT,S0_Port[0]); /* Set source Socket Port number */
Write_W5100((W5100_S0_CR+s*0x100),S_CR_CLOSE); /*打开不成功,关闭Socket,然后返回*/
return FALSE;
Write_W5100((W5100_S0_CR+s*0x100), S_CR_LISTEN); /*设置Socket为侦听模式*/
if(Read_W5100(W5100_S0_SSR+s*0x100)!=S_SSR_LISTEN)
Write_W5100((W5100_S0_CR+s*0x100), S_CR_CLOSE); /*设置不成功,关闭Socket,然后返回*/
return FALSE;
return TRUE;
/*至此完成了Socket的打开和设置侦听工作,至于远程客户端是否与它建立连接,则需要等待Socket中断,
在服务器侦听模式不需要设置目的IP和目的端口号*/
* @brief 设置Socket为UDP模式
*如果Socket工作在UDP模式,引用该程序。在UDP模式下,Socket通信不需要建立连接
*该程序只调用一次,就使W5100设置为UDP模式
unsigned short S_rx_process(SOCKET s)
unsigned short i,j;
unsigned short rx_size,rx_offset;
/*读取接收数据的字节数*/
rx_size=Read_W5100(W5100_S0_RX_RSR+s*0x100);
rx_size*=256;
rx_size+=Read_W5100(W5100_S0_RX_RSR+s*0x100+1);
/*读取接收缓冲区的偏移量*/
rx_offset=Read_W5100(W5100_S0_RX_RR+s*0x100);
rx_offset*=256;
rx_offset+=Read_W5100(W5100_S0_RX_RR+s*0x100+1);
i=rx_offset/S_RX_SIZE; /*计算实际的物理偏移量,S0_RX_SIZE需要在前面#define中定义*/
/*注意S_RX_SIZE的值在W5100_Init()函数的W5100_RMSR中确定*/
rx_offset=rx_offset-i*S_RX_SIZE;
j=W5100_RX+s*S_RX_SIZE+rx_offset; /*实际物理地址为W5100_RX+rx_offset*/
for(i=0;i<rx_size;i++)
if(rx_offset>=S_RX_SIZE)
j=W5100_RX+s*S_RX_SIZE;
rx_offset=0;
Rx_Buffer[i]=Read_W5100(j); /*将数据缓存到Rx_buffer数组中*/
j++;
rx_offset++;
/*计算下一次偏移量*/
rx_offset*=256;
rx_offset+=rx_size;
Write_W5100((W5100_S0_RX_RR+s*0x100), (rx_offset/256));
Write_W5100((W5100_S0_RX_RR+s*0x100+1), rx_offset);
Write_W5100((W5100_S0_CR+s*0x100), S_CR_RECV); /*设置RECV命令,等等下一次接收*/
return rx_size; /*返回接收的数据字节数*/
* @brief 如果要通过Socket发送数据,则引用该程序
*要发送的数据缓存在Tx_buffer中, size则是要发送的字节长度
* @author stmsky
* @param[in] socket nummber
* @param[out] none
* @return
* @note
unsigned char S_tx_process(SOCKET s, unsigned int size)
unsigned short i,j;
unsigned short tx_free_size,tx_offset;
/*如果是UDP模式,可以在此设置目的主机的IP和端口号*/
if((Read_W5100(W5100_S0_MR+s*0x100)&0x0f)==0x02)
for(i=0;i<4;i++) /* 设置目的主机IP*/
Write_W5100((W5100_S0_DIPR+s*0x100+i), UDP_DIPR[i]);
Write_W5100((W5100_S0_DPORT+s*0x100), UDP_DPORT[0]);
Write_W5100((W5100_S0_DPORT+s*0x100+1), UDP_DPORT[1]);
/*读取缓冲区剩余的长度*/
tx_free_size=Read_W5100(W5100_S0_TX_FSR+s*0x100);
tx_free_size*=256;
tx_free_size+=Read_W5100(W5100_S0_TX_FSR+s*0x100+1);
if(tx_free_size<size) /*如果剩余的字节长度小于发送字节长度,则返回*/
return FALSE;
/*读取发送缓冲区的偏移量*/
tx_offset=Read_W5100(W5100_S0_TX_WR+s*0x100);
tx_offset*=256;
tx_offset+=Read_W5100(W5100_S0_TX_WR+s*0x100+1);
i=tx_offset/S_TX_SIZE; /*计算实际的物理偏移量,S0_TX_SIZE需要在前面#define中定义*/
/*注意S0_TX_SIZE的值在W5100_Init()函数的W5100_TMSR中确定*/
tx_offset=tx_offset-i*S_TX_SIZE;
j=W5100_TX+s*S_TX_SIZE+tx_offset; /*实际物理地址为W5100_TX+tx_offset*/
for(i=0;i<size;i++)
if(tx_offset>=S_TX_SIZE)
j=W5100_TX+s*S_TX_SIZE;
tx_offset=0;
Write_W5100(j,Tx_Buffer[i]); /*将Tx_buffer缓冲区中的数据写入到发送缓冲区*/
j++;
tx_offset++;
/*计算下一次的偏移量*/
tx_offset*=256;
tx_offset+=size;
Write_W5100((W5100_S0_TX_WR+s*0x100),(tx_offset/256));
Write_W5100((W5100_S0_TX_WR+s*0x100+1),tx_offset);
Write_W5100((W5100_S0_CR+s*0x100), S_CR_SEND); /*设置SEND命令,启动发送*/
return TRUE; /*返回成功*/
* @brief W5100中断处理程序框架
* @note
void vPrintString(unsigned char *ucpString)
unsigned int i=0;
while(ucpString[i]!=0x00)
Tx_Buffer[i]=ucpString[i];
i++;
S_tx_process(0,i);
void W5100_Interrupt_Process(void)
unsigned char i,j;
W5100_Interrupt=0;
i=Read_W5100(W5100_IR);
Write_W5100(W5100_IR, (i&0xf0)); /*回写清除中断标志*/
//GPIO_SetBits(GPIOB, GPIO_Pin_0);
if((i & IR_CONFLICT) == IR_CONFLICT) /*IP地址冲突异常处理,自己添加代码*/
if((i & IR_UNREACH) == IR_UNREACH) /*UDP模式下地址无法到达异常处理,自己添加代码*/
/* Socket事件处理 */
if((i & IR_S0_INT) == IR_S0_INT)
j=Read_W5100(W5100_S0_IR);
Write_W5100(W5100_S0_IR, j); /* 回写清中断标志 */
if(j&S_IR_CON) /* 在TCP模式下,Socket0成功连接 */
S0_State|=S_CONN;
if(j&S_IR_DISCON) /* 在TCP模式下Socket断开连接处理,自己添加代码 */
Write_W5100(W5100_S0_CR, S_CR_CLOSE); /* 关闭端口,等待重新打开连接 */
S0_State=0;
if(j&S_IR_SENDOK) /* Socket0数据发送完成,可以再次启动S_tx_process()函数发送数据 */
S0_Data|=S_TRANSMITOK;
if(j&S_IR_RECV) /* Socket接收到数据,可以启动S_rx_process()函数 */
S0_Data|=S_RECEIVE;
if(j&S_IR_TIMEOUT) /* Socket连接或数据传输超时处理 */
S0_State=0;
/* Socket1事件处理 */
if((i&IR_S1_INT)==IR_S1_INT)
j=Read_W5100(W5100_S1_IR);
Write_W5100(W5100_S1_IR, j); /* 回写清中断标志 */
/* Socket2事件处理 */
if((i&IR_S2_INT)==IR_S2_INT)
j=Read_W5100(W5100_S2_IR);
Write_W5100(W5100_S2_IR, j); /*回写清中断标志 */
/* Socket3事件处理 */
if((i&IR_S3_INT)==IR_S3_INT)
j=Read_W5100(W5100_S3_IR);
Write_W5100(W5100_S3_IR, j); /* 回写清中断标志 */
W5100_Init();
Socket_Init(0);
Socket_Listen(0);
KEY=0;
W5100_Interrupt_Process();
if(S0_State==S_CONN) break;
vPrintString("SOCKET0 opened.");
KEY=1;
if(KEY==1)
vPrintString("Switch is on!");
else vPrintString("Switch is off!");
说明下:很明显我是用spi 的w5100 进行读写。里面的KEY是用来找程序运行到哪里的,没实际意义。
问题是:现在程序直接卡在第一个 while(1)里面。我利用网络助手连接一直连接不上,但是能ping通192.168.10.40 ,能不能前辈抽空帮我看下是哪里出错了?小的不胜感激。
另外付电脑设置截图 |
