我使用了obdev.at的V-USB进行修改。但是有个问题,就是obdev的V-USB中的底层汇编代码,指令速度有差别的我全部都加了NOP。然后IO口读出写入的我也注意到了IO同步的问题。可是现在这个20M的东西下载到MCU里就是不工作。但是12M的却工作的很好。
希望那个移植的工程师出来赐教一下。
我自己移植的代码:- /* Name: usbdrvasm20.inc
- * Project: V-USB, virtual USB port for Atmel's(r) AVR(r) microcontrollers
- * Author: Jeroen Benschop
- * Based on usbdrvasm16.inc from Christian Starkjohann
- * Creation Date: 2008-03-05
- * Tabsize: 4
- * Copyright: (c) 2008 by Jeroen Benschop and OBJECTIVE DEVELOPMENT Software GmbH
- * License: GNU GPL v2 (see License.txt), GNU GPL v3 or proprietary (CommercialLicense.txt)
- * Revision: $Id: usbdrvasm20.inc 740 2009-04-13 18:23:31Z cs $
- /* Do not link this file! Link usbdrvasm.S instead, which includes the
- * appropriate implementation!
- General Description:
- This file is the 20 MHz version of the asssembler part of the USB driver. It
- requires a 20 MHz crystal (not a ceramic resonator and not a calibrated RC
- oscillator).
- See usbdrv.h for a description of the entire driver.
- Since almost all of this code is timing critical, don't change unless you
- really know what you are doing! Many parts require not only a maximum number
- of CPU cycles, but even an exact number of cycles!
- #define leap2 x3
- #ifdef __IAR_SYSTEMS_ASM__
- #define nextInst $+2
- #else
- #define nextInst .+0
- #endif
- ;max stack usage: [ret(2), YL, SREG, YH, bitcnt, shift, x1, x2, x3, x4, cnt] = 12 bytes
- ;nominal frequency: 20 MHz -> 13.333333 cycles per bit, 106.666667 cycles per byte
- ; Numbers in brackets are clocks counted from center of last sync bit
- ; when instruction starts
- ;register use in receive loop:
- ; shift assembles the byte currently being received
- ; x1 holds the D+ and D- line state
- ; x2 holds the previous line state
- ; x4 (leap) is used to add a leap cycle once every three bytes received
- ; X3 (leap2) is used to add a leap cycle once every three stuff bits received
- ; bitcnt is used to determine when a stuff bit is due
- ; cnt holds the number of bytes left in the receive buffer
- USB_INTR_VECTOR:
- sbrs bootcot,0 //如果bootcot的0位被设置
- jmp UNUSED1_vtr //跳转到真正的int0(bootcot=0)
- ;order of registers pushed: YL, SREG YH, [sofError], bitcnt, shift, x1, x2, x3, x4, cnt
- push YL ;[-28] push only what is necessary to sync with edge ASAP
- in YL, SREG ;[-26]
- push YL ;[-25]
- push YH ;[-23]
- ; Synchronize with sync pattern:
- ;sync byte (D-) pattern LSb to MSb: 01010100 [1 = idle = J, 0 = K]
- ;sync up with J to K edge during sync pattern -- use fastest possible loops
- ;The first part waits at most 1 bit long since we must be in sync pattern.
- ;YL is guarenteed to be < 0x80 because I flag is clear. When we jump to
- ;waitForJ, ensure that this prerequisite is met.
- waitForJ:
- inc YL
- ;sbis USBIN, USBMINUS
- in YL,USBIN
- sbrs YL ,USBMINUS
- brne waitForJ ; just make sure we have ANY timeout
- waitForK:
- ;The following code results in a sampling window of < 1/4 bit which meets the spec.
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK ;[-18]
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- in YL, USBIN
- sbrs YL, USBMINUS
- rjmp foundK
- #if USB_COUNT_SOF
- lds YL, usbSofCount
- inc YL
- sts usbSofCount, YL
- #endif /* USB_COUNT_SOF */
- #ifdef USB_SOF_HOOK
- USB_SOF_HOOK
- #endif
- rjmp sofError
- foundK: ;[-16]
- ;{3, 5} after falling D- edge, average delay: 4 cycles
- ;bit0 should be at 34 for center sampling. Currently at 4 so 30 cylces till bit 0 sample
- ;use 1 bit time for setup purposes, then sample again. Numbers in brackets
- ;are cycles from center of first sync (double K) bit after the instruction
- push bitcnt ;[-16]
- nop ;[-15]
- lds YL, usbInputBufOffset;[-14]
- nop ;[-13]
- clr YH ;[-12]
- subi YL, lo8(-(usbRxBuf));[-11] [rx loop init]
- sbci YH, hi8(-(usbRxBuf));[-10] [rx loop init]
- push shift ;[-9]
- nop ;[-8]
- ldi shift,0x40 ;[-7] set msb to "1" so processing bit7 can be detected
- nop2 ;[-6]
- nop ;[-5]
- ldi bitcnt, 5 ;[-4] [rx loop init]
- ;sbis USBIN, USBMINUS ;[-3] we want two bits K (sample 3 cycles too early)
- in x1, USBIN ;1 [8]
- sbrs x1, USBMINUS ;1 [9]
- rjmp haveTwoBitsK ;[-2]
- pop shift ;[-1] undo the push from before
- pop bitcnt ;[1]
- nop ;[2]
- rjmp waitForK ;[3] this was not the end of sync, retry
- ; The entire loop from waitForK until rjmp waitForK above must not exceed two
- ; bit times (= 27 cycles).
- ; push more registers and initialize values while we sample the first bits:
- haveTwoBitsK:
- push x1 ;[0]
- nop ;[1]
- push x2 ;[2]
- nop ;[3]
- push x3 ;[4] (leap2)
- nop ;[5]
- ldi leap2, 0x55 ;[6] add leap cycle on 2nd,5th,8th,... stuff bit
- push x4 ;[7] == leap
- nop ;[8]
- ldi leap, 0x55 ;[9] skip leap cycle on 2nd,5th,8th,... byte received
- push cnt ;[10]
- nop ;[11]
- ldi cnt, USB_BUFSIZE ;[12] [rx loop init]
- ldi x2, 1<<USBPLUS ;[13] current line state is K state. D+=="1", D-=="0"
- bit0:
- in x1, USBIN ;[0] sample line state
- andi x1, USBMASK ;[1] filter only D+ and D- bits
- nop ;[2]
- rjmp handleBit ;[3] make bit0 14 cycles long
- ; Process bit7. However, bit 6 still may need unstuffing.
- b6checkUnstuff:
- dec bitcnt ;[9]
- breq unstuff6 ;[10]
- bit7:
- subi cnt, 1 ;[11] cannot use dec becaus it does not affect the carry flag
- brcs overflow ;[12] Too many bytes received. Ignore packet
- cpse x1, x2 ;[2] when previous line state equals current line state, handle "1"
- rjmp b7handle0 ;[3] when line state differs, handle "0"
- sec ;[4]
- ror shift ;[5] shift "1" into the data
- st y+, shift ;[6] store the data into the buffer
- ldi shift, 0x40 ;[7] reset data for receiving the next byte
- subi leap, 0x55 ;[9] trick to introduce a leap cycle every 3 bytes
- brcc nextInst ;[10 or 11] it will fail after 85 bytes. However low speed can only receive 11
- dec bitcnt ;[11 or 12]
- brne bit0 ;[12 or 13]
- ldi x1, 1 ;[13 or 14] unstuffing bit 7
- in bitcnt, USBIN ;[1] sample stuff bit
- rjmp unstuff ;[2]
- b7handle0:
- mov x2,x1 ;[5] Set x2 to current line state
- ldi bitcnt, 6 ;[6]
- lsr shift ;[7] shift "0" into the data
- st y+, shift ;[8] store data into the buffer
- ldi shift, 0x40 ;[10] reset data for receiving the next byte
- subi leap, 0x55 ;[11] trick to introduce a leap cycle every 3 bytes
- brcs bit0 ;[12] it will fail after 85 bytes. However low speed can only receive 11
- rjmp bit0 ;[13]
- ; Handle unstuff
- ; x1==0xFF indicate unstuffing bit6
- unstuff6:
- ldi x1,0xFF ;[12] indicate unstuffing bit 6
- in bitcnt, USBIN ;[0] sample stuff bit
- nop ;[1] fix timing
- unstuff: ;b0-5 b6 b7
- mov x2,bitcnt ;[3] [2] [3] Set x2 to match line state
- subi leap2, 0x55 ;[4] [3] [4] delay loop
- brcs nextInst ;[5] [4] [5] add one cycle every three stuff bits
- sbci leap2,0 ;[6] [5] [6]
- ldi bitcnt,6 ;[7] [6] [7] reset bit stuff counter
- andi x2, USBMASK ;[8] [7] [8] only keep D+ and D-
- cpi x1,0 ;[9] [8] [9]
- brmi bit7 ;[10] [9] [10] finished unstuffing bit6 When x1<0
- breq bitloop ;[11] --- [11] finished unstuffing bit0-5 when x1=0
- nop ;--- --- [12]
- in x1, USBIN ;--- --- [0] sample line state for bit0
- andi x1, USBMASK ;--- --- [1] filter only D+ and D- bits
- nop ;--- --- [2]
- rjmp handleBit ;--- --- [3] make bit0 14 cycles long
- ; Receiver loop (numbers in brackets are cycles within byte after instr)
- bitloop:
- breq se0 ;[2] both lines are low so handle se0
- handleBit:
- cpse x1, x2 ;[3] when previous line state equals current line state, handle "1"
- rjmp handle0 ;[4] when line state differs, handle "0"
- sec ;[5]
- ror shift ;[6] shift "1" into the data
- brcs b6checkUnstuff ;[7] When after shift C is set, next bit is bit7
- nop2 ;[8]
- dec bitcnt ;[10]
- brne bitloop ;[11]
- ldi x1,0 ;[12] indicate unstuff for bit other than bit6 or bit7
- nop ;[1]
- rjmp unstuff ;[2]
- handle0:
- mov x2, x1 ;[6] Set x2 to current line state
- ldi bitcnt, 6 ;[7] reset unstuff counter.
- lsr shift ;[8] shift "0" into the data
- brcs bit7 ;[9] When after shift C is set, next bit is bit7
- nop2 ;[10]
- rjmp bitloop ;[12]
- ; End of receive loop. Now start handling EOP
- macro POP_STANDARD ; 14 cycles
- pop cnt
- pop x4
- pop x3
- pop x2
- pop x1
- pop shift
- pop bitcnt
- endm
- macro POP_RETI ; 7 cycles
- pop YH
- pop YL
- out SREG, YL
- pop YL
- endm
- #include "asmcommon.inc"
- ; USB spec says:
- ; idle = J
- ; J = (D+ = 0), (D- = 1)
- ; K = (D+ = 1), (D- = 0)
- ; Spec allows 7.5 bit times from EOP to SOP for replies
- ; 7.5 bit times is 100 cycles. This implementation arrives a bit later at se0
- ; then specified in the include file but there is plenty of time
- bitstuffN:
- eor x1, x4 ;[8]
- ldi x2, 0 ;[9]
- nop2 ;[10]
- out USBOUT, x1 ;[12] <-- out
- nop ;[0]
- rjmp didStuffN ;[1]
- bitstuff7:
- eor x1, x4 ;[6]
- ldi x2, 0 ;[7] Carry is zero due to brcc
- rol shift ;[8] compensate for ror shift at branch destination
- nop2 ;[9]
- nop ;[11]
- rjmp didStuff7 ;[12]
- sendNakAndReti:
- ldi x3, USBPID_NAK ;[-18]
- nop ;[-17]
- rjmp sendX3AndReti ;[-16]
- sendAckAndReti:
- ldi cnt, USBPID_ACK ;[-17]
- sendCntAndReti:
- mov x3, cnt ;[-16]
- sendX3AndReti:
- ldi YL, 20 ;[-15] x3==r20 address is 20
- ldi YH, 0 ;[-14]
- ldi cnt, 2 ;[-13]
- ; rjmp usbSendAndReti fallthrough
- ;usbSend:
- ;pointer to data in 'Y'
- ;number of bytes in 'cnt' -- including sync byte [range 2 ... 12]
- ;uses: x1...x4, btcnt, shift, cnt, Y
- ;Numbers in brackets are time since first bit of sync pattern is sent
- ;We don't match the transfer rate exactly (don't insert leap cycles every third
- ;byte) because the spec demands only 1.5% precision anyway.
- usbSendAndReti: ; 12 cycles until SOP
- in x2, USBDDR ;[-12]
- ori x2, USBMASK ;[-11]
- sbi USBOUT, USBMINUS;[-10] prepare idle state; D+ and D- must have been 0 (no pullups)
- nop ;[-9]
- in x1, USBOUT ;[-8] port mirror for tx loop
- out USBDDR, x2 ;[-7] <- acquire bus
- ; need not init x2 (bitstuff history) because sync starts with 0
- ldi x4, USBMASK ;[-6] exor mask
- ldi shift, 0x80 ;[-5] sync byte is first byte sent
- txByteLoop:
- ldi bitcnt, 0x49 ;[-4] [10] binary 01001001
- txBitLoop:
- sbrs shift, 0 ;[-3] [10] [11]
- eor x1, x4 ;[-2] [11] [12]
- out USBOUT, x1 ;[-1] [12] [13] <-- out N
- ror shift ;[0] [13] [14]
- ror x2 ;[1]
- didStuffN:
- nop2 ;[2]
- nop ;[4]
- cpi x2, 0xfc ;[5]
- brcc bitstuffN ;[6]
- lsr bitcnt ;[7]
- brcc txBitLoop ;[8]
- brne txBitLoop ;[9]
- sbrs shift, 0 ;[10]
- eor x1, x4 ;[11]
- didStuff7:
- out USBOUT, x1 ;[-1] [13] <-- out 7
- ror shift ;[0] [14]
- ror x2 ;[1]
- nop ;[2]
- cpi x2, 0xfc ;[3]
- brcc bitstuff7 ;[4]
- ld shift, y+ ;[5]
- nop ;[6]
- dec cnt ;[7]
- brne txByteLoop ;[8]
- ;make SE0:
- cbr x1, USBMASK ;[9] prepare SE0 [spec says EOP may be 25 to 30 cycles]
- lds x2, usbNewDeviceAddr;[10]
- lsl x2 ;[12] we compare with left shifted address
- out USBOUT, x1 ;[13] <-- out SE0 -- from now 2 bits = 22 cycles until bus idle
- subi YL, 20 + 2 ;[0] Only assign address on data packets, not ACK/NAK in x3
- sbci YH, 0 ;[1]
- ;2006-03-06: moved transfer of new address to usbDeviceAddr from C-Code to asm:
- ;set address only after data packet was sent, not after handshake
- breq skipAddrAssign ;[2]
- sts usbDeviceAddr, x2; if not skipped: SE0 is one cycle longer
- skipAddrAssign:
- ;end of usbDeviceAddress transfer
- ldi x2, 1<<USB_INTR_PENDING_BIT;[4] int0 occurred during TX -- clear pending flag
- USB_STORE_PENDING(x2) ;[5]
- ori x1, USBIDLE ;[6]
- in x2, USBDDR ;[7]
- cbr x2, USBMASK ;[8] set both pins to input
- mov x3, x1 ;[9]
- cbr x3, USBMASK ;[10] configure no pullup on both pins
- ldi x4, 5 ;[11]
- se0Delay:
- dec x4 ;[12] [15] [18] [21] [24]
- brne se0Delay ;[13] [16] [19] [22] [25]
- out USBOUT, x1 ;[26] <-- out J (idle) -- end of SE0 (EOP signal)
- out USBDDR, x2 ;[27] <-- release bus now
- out USBOUT, x3 ;[28] <-- ensure no pull-up resistors are active
- nop ;[29]
- rjmp doReturn ;[30]
复制代码 |
