最近开始接触 RTT,下了1.1.0 版的程序,编译环境是 MDK4.53,直接运行 BSP下的 SAM7X 里的工程,使用JLINK 仿真,
点仿真后程序下载是可以,但仿真光标直接进了 DISASSEMBLY 的框里,
0x00000004 E59FF018 LDR PC,[PC,#0x0018]
0x00000008 E59FF018 LDR PC,[PC,#0x0018]
0x0000000C E59FF018 LDR PC,[PC,#0x0018]
0x00000010 E59FF018 LDR PC,[PC,#0x0018]
0x00000014 E1A00000 NOP
0x00000018 E59FF018 LDR PC,[PC,#0x0018]
0x0000001C E59FF018 LDR PC,[PC,#0x0018]
从上面看应该是 从0地址开始执行的, 程序也能通过mdk控制run stop,运行结果也对,但调试的光标始终是对应的汇编语句,对不到C语言上。
有没有遇到同样问题的?如何解决呢?
ProjectFile = D:\RT-Thread\bsp\sam7x\JLinkArm_RT-Thread/AT91SAM7X256.ini
***JLink Error: Could not save file [D:\\RT-Thread\bsp\sam7x\JLinkArm_RT-Thread/AT91SAM7X256.ini]
Path not found!
Device = AT91SAM7X256
Info: Device "AT91SAM7X256" selected (256 KB flash, 64 KB RAM).
VTarget = 3.319V
Info: TotalIRLen = 4, IRPrint = 0x01
Info: RTCK seems to be bridged with TCK
Info: Auto JTAG speed: 8000 kHz
Info: Core does not stop after Reset, setting WP to stop it.
***JLink Warning: PC of target system has unexpected value of 0x00200004 after reset.
DLL version V4.50i, compiled Jun 22 2012 13:07:53
Firmware: J-Link ARM V7 compiled Jun 20 2012 19:45:53
Hardware: V7.00
Hardware-Breakpoints: 2
Software-Breakpoints: 8192
Watchpoints: 0
Found 1 JTAG device, Total IRLen = 4:
Id of device #0: 0x3F0F0F0F
ARM7 identified.
S/N :
Feature(s) : RDI, FlashBP, FlashDL, JFlash, GDBFull
VTarget = 3.319V
***JLink Warning: PC of target system has unexpected value of 0x00200000 after reset.
JTAG speed: 1000 kHz
Load "D:\\RT-Thread\\bsp\\sam7x\\objs\\project.AXF"
Info: J-Link: Flash download: Flash programming performed for 0 ranges (0 bytes)
Info: J-Link: Flash download: Total time needed: 1.440s (Prepare: 0.836s, Compare: 0.099s, Program: 0.000s, Verify: 0.000s, Restore: 0.503s)
JTAG speed: 1000 kHz |
