回复: 67
我的STM32核心板启动uClinux成功了
发表于 2013-1-22 10:34:29 | 显示全部楼层 |阅读模式
板子是我自己做的,外扩了flash和大容量pSRAM(4M Byte)。FSMC的片选按照ST3210E-EVAL设计的,使用了ST官方发布的uClinux针对我的板子进行修改。只是苦于ST提供的bootloader没有源码,为了启动我修改后的uClinux费了不少功夫,最后分析上网搜索linux的启动步骤,自己写了一个bootloader,顺利的启动了uClinux。虽然还有些小问题,别的不说了先上启动信息(后面有板子的照片)
Linux version 2.6.26-uc0 (root@localhost.localdomain) (gcc version 4.5.2 (Sourcery G++ Lite 2011.03-46) ) #18 Mon Jan 21 14:36:20 CST 2013
CPU: ARMv7-M Processor [411fc231] revision 1 (ARMv?(11)M)
Machine: STM3210E-EVAL
SRAM Config: bank[0] @ 0x68000000 (size: 4096KB) - bank[1] @ 0x20000000 (size: 64KB).
Ignoring unrecognised tag 0x00000000
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 1016
Kernel command line: noinitrd root=mtd1 rootfstype=jffs2 init=/linuxrc console=ttyS0
PID hash table entries: 16 (order: 4, 64 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 4MB 0MB = 4MB total
Memory: 4052KB available (492K code, 56K data, 8K init)
JFFS2 version 2.2. 漏 2001-2006 Red Hat, Inc.
kobject_add_internal failed for P/ with -EEXIST, don't try to register things with the same name in the same directory.
simple-gpio: now handling 16 GPIOs: 0 - 15
ttyS0 at MMIO 0x40013800 (irq = 37) is a STM32 USART1 Port
Probed and found the STM3210E-EVAL NOR flash chip
Creating 4 MTD partitions on "S29GL064N NOR FLASH":
0x00000000-0x00100000 : "Kernel raw data"
0x00100000-0x00160000 : "rootfs"
0x00160000-0x00190000 : "rawdata"
0x00190000-0x001c0000 : "cramfs_partition"
rtc-stm3210e_eval rtc-stm3210e_eval.0: rtc core: registered rtc-stm3210e_eval as rtc0
rtc-stm3210e_eval rtc-stm3210e_eval.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
VFS: Mounted root (jffs2 filesystem) readonly.
Bad page state in process 'swapper'
page:68001040 flags:0x00000000 mapping:00000000 mapcount:1 count:0
Trying to fix it up, but a reboot is needed
Backtrace:
page:68001060 flags:0x00000000 mapping:00000000 mapcount:1 count:0
Backtrace:
Freeing init memory: 8K
Mounting proc fs
Mounting sysfs
Welcome to
       ____ _  _
      /  __| ||_|
_   _| |  | | _ ___   _   _ _    _
| | | | |  | || |  _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/    \
| ___ \____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
http://www.st.com/stm32
发表于 2013-1-22 10:36:29 | 显示全部楼层
顶下,4M PSRAM可以做很多事情了
发表于 2013-1-22 10:39:18 | 显示全部楼层
顶。
不错。
发表于 2013-1-22 10:43:54 | 显示全部楼层
这个BGA太霸气了!!!
手工可以焊接吗?
 楼主| 发表于 2013-1-22 10:47:30 | 显示全部楼层
zgxcom123 发表于 2013-1-22 10:43
这个BGA太霸气了!!!
手工可以焊接吗?
可以手工焊接的。
发表于 2013-1-22 10:52:25 | 显示全部楼层
htjgdw 发表于 2013-1-22 10:47
可以手工焊接的。
是这种封装的吗?
感觉LZ的layout功底很强悍……………………
发表于 2013-1-22 10:59:57 | 显示全部楼层
楼主的焊接倒是灰常霸气。。。
发表于 2013-1-22 11:39:57 | 显示全部楼层
楼主应该直接上F407啊。。那个配置到楼主这个水平可以直接替代arm9了
 楼主| 发表于 2013-1-22 11:40:29 | 显示全部楼层
zgxcom123 发表于 2013-1-22 10:52
是这种封装的吗?
您真是内行。
发表于 2013-1-22 11:49:55 | 显示全部楼层
htjgdw 发表于 2013-1-22 11:40
您真是内行。
=,=有时候觉得taobao这玩意确实好用……………………
发表于 2013-1-22 11:51:59 | 显示全部楼层
楼主有没有研究过不外扩sram能不能跑uclinux?
另外弱弱的问一句cortex-m3的这套系统比arm9的方案好在哪里?更低成本吗?
发表于 2013-1-22 11:56:11 | 显示全部楼层
焊接是霸气侧漏啊!!!
发表于 2013-1-22 12:04:56 | 显示全部楼层
大容量pSRAM(4M Byte),大概的价格是多少呀?
发表于 2013-1-22 12:35:12 | 显示全部楼层
牛叉啊,一直想知道怎么焊接BGA
 楼主| 发表于 2013-1-22 12:53:28 | 显示全部楼层
手工焊接BGA的话就是热风枪了,就是焊接时得仔细。
发表于 2013-1-22 12:57:45 | 显示全部楼层
牛.
发表于 2013-1-22 13:00:09 | 显示全部楼层
很霸气,,,,,,,,,,,,,,
发表于 2013-1-22 13:01:41 | 显示全部楼层
同问.
发表于 2013-1-22 13:16:31 | 显示全部楼层
楼主强悍
发表于 2013-1-22 13:25:44 | 显示全部楼层
uclinux
发表于 2013-1-22 13:57:02 | 显示全部楼层
uclinux启动后,还剩多少资源呢(RAM)?
 楼主| 发表于 2013-1-22 14:00:31 | 显示全部楼层
还有3M多。
/ # free
              total         used         free       shared      buffers
  Mem:         4060          624         3436            0            0
发表于 2013-1-22 14:36:46 | 显示全部楼层
板子不错,有卖么?
发表于 2013-1-22 15:00:13 | 显示全部楼层
很好,很强大。
发表于 2013-1-22 15:02:41 | 显示全部楼层
htjgdw 发表于 2013-1-22 14:00
还有3M多。
有配套底板吗?有兴趣搞块玩玩
 楼主| 发表于 2013-1-22 15:23:47 | 显示全部楼层
底板还没有,况且人们的需求真的是千差万别,STM32有很多功能是复用IO的,所以底板还是根据用户自己的需要专门设计比较好。
这也是我先做核心板的原因。
出110入8汤圆
发表于 2013-1-22 17:45:46 | 显示全部楼层
楼主的有什么好的做锡球的工具吗?
发表于 2013-1-22 17:58:42 | 显示全部楼层
MCP    有感觉哦   具体型号有木有呢?
发表于 2013-1-22 20:23:20 | 显示全部楼层
有才,有才,佩服佩服!
发表于 2013-1-22 21:45:40 | 显示全部楼层
请问这个psram多少钱?什么型号?
发表于 2013-1-22 21:47:51 | 显示全部楼层
LZ,这是上次很相中你的核心板的那个ID,记得上次你说这块核心板试运UCLinux成功后会考虑出售核心板,现在俺是终于等到了,怎么样,还有打算出售么现在?
 楼主| 发表于 2013-1-22 22:11:10 | 显示全部楼层
现在uClinux是成功启动了,但是启动信息里有错误。我觉得怎么也得把这些bug去掉才好吧。
发表于 2013-1-22 23:18:54 | 显示全部楼层
同求PSRAM的信号和价格
发表于 2013-1-23 09:37:10 来自手机 | 显示全部楼层
F4的cpu没有cache,速度远不如ARM9。。。
 楼主| 发表于 2013-1-23 10:00:05 | 显示全部楼层
是的,据我所知cortex-m的mcu绝大多数都没有cache,速度肯定无法与ARM9相比了。
STM32和ARM9相比唯一的亮点就是大大降低硬件的复杂度,降低了跑linux的门槛。
发表于 2013-1-23 10:35:18 | 显示全部楼层
弱弱的请教一下,UcLinux和Linux最大的区别在哪里呢?
发表于 2013-1-24 09:54:53 | 显示全部楼层
htjgdw 发表于 2013-1-22 22:11
现在uClinux是成功启动了,但是启动信息里有错误。我觉得怎么也得把这些bug去掉才好吧。 ...
这样子啊,那也行,继续等你,希望能能快点完成。不过软件上的跑系统,和硬件上的核心板,有什么直接关系么?资源够跑得好迟早的事吧~~~我只是想买LZ的核心板而已~~~哈哈
 楼主| 发表于 2013-1-24 12:21:59 | 显示全部楼层
bbosliyang 发表于 2013-1-24 09:54
这样子啊,那也行,继续等你,希望能能快点完成。不过软件上的跑系统,和硬件上的核心板,有什么直接关系 ...
好的,等我完善了硬件测试程序后,测好一块核心板通知你。
发表于 2013-1-24 12:52:08 | 显示全部楼层
不错啊,PCB是4层板吗?
如果整个核心板大概多少钱呢?STM32可以跑linux,很多事情就省事了
发表于 2013-1-25 00:08:02 | 显示全部楼层
好的,你研究吧,敬候佳音
发表于 2013-1-31 20:49:05 | 显示全部楼层
可以手工焊接的。
啊,什么是BGA,看上去好像是QFN的
发表于 2013-2-2 04:03:50 来自手机 | 显示全部楼层
楼主的bootloader是什么思路?
 楼主| 发表于 2013-2-2 23:50:29 来自手机 | 显示全部楼层
引导linux系统都需要bootloader的。你可以把它与pc的bios画等号
发表于 2013-2-3 00:01:54 | 显示全部楼层
虽然还没学到 但是感觉LZ还是很强大的样子 顶
 楼主| 发表于 2013-2-20 09:57:16 | 显示全部楼层
楼上过奖了,谢谢!
发表于 2013-2-21 11:40:13 | 显示全部楼层
这么小体积,楼主太棒了!用到BGA,是4层板吗?
另外,BGA芯片是什么型号呢?
发表于 2013-2-21 11:54:20 | 显示全部楼层
uCLinux主要是针对目标处理器没有存储管理单元MMU(Memory Management Unit)的嵌入式系统而设计的
----转自度娘
发表于 2013-2-21 12:56:10 | 显示全部楼层
关注中~
 楼主| 发表于 2013-2-21 14:19:51 | 显示全部楼层
另外,BGA芯片是什么型号呢? ...
如果是4层的就没什么难度了,不是4层的。
 楼主| 发表于 2013-2-21 14:22:22 | 显示全部楼层
前些年S3C44B0流行的时候,uCLinux曾经活跃过一段时间。后来随着Cortex-M3代替ARM7, uClinux也就沉寂了,原因是芯片厂商推出的带外部总线的MCU少了,没有大一点的存储器uClinux是跑不了的。
发表于 2013-5-2 11:03:17 | 显示全部楼层
板卖吗  联系我
发表于 2013-5-2 12:07:01 | 显示全部楼层
不错不错,想要想要。
 楼主| 发表于 2013-5-6 10:03:57 | 显示全部楼层
zishiquan 发表于 2013-5-2 11:03
板卖吗  联系我
联系我请看我的签名。
 楼主| 发表于 2013-5-6 10:04:18 | 显示全部楼层
yangliu212 发表于 2013-5-2 12:07
不错不错,想要想要。
联系我请看我的签名。
发表于 2013-5-6 10:52:33 | 显示全部楼层
不知道速度咋样啊,特别是接入以太网以后
 楼主| 发表于 2013-5-6 14:32:54 | 显示全部楼层
javabean 发表于 2013-5-6 10:52
不知道速度咋样啊,特别是接入以太网以后
这需要做以太网的扩展板(一般用DM9000A)然后再移植驱动测试才能知道。。。
发表于 2013-12-25 17:26:19 | 显示全部楼层
手工焊接BGA。。pitch多大呀
发表于 2013-12-25 20:26:39 | 显示全部楼层
按键在背面?
发表于 2013-12-25 20:29:53 来自手机 | 显示全部楼层
MCP型号是什么,楼主说下尼
发表于 2014-3-19 12:54:37 | 显示全部楼层
htjgdw 发表于 2013-1-22 15:23
底板还没有,况且人们的需求真的是千差万别,STM32有很多功能是复用IO的,所以底板还是根据用户自己的需要 ...
对于如何搭建stm32开发环境 很有兴趣 还没成功
楼主可否指点
发表于 2014-3-19 14:14:38 | 显示全部楼层
linux有没有学习的必要?还是自己搭建一套从头来?
 楼主| 发表于 2014-3-20 22:15:55 | 显示全部楼层
楼主可否指点
ST官方有个PDF文档,介绍了如何搭建uclinux的编译环境。我就是按照那个文档做的,你可以去ST的网站找到的。
发表于 2014-3-21 03:14:44 | 显示全部楼层
htjgdw 发表于 2014-3-20 22:15
ST官方有个PDF文档,介绍了如何搭建uclinux的编译环境。我就是按照那个文档做的,你可以去ST的网站找到的 ...
请问您的内核版本是多少的
我的是 3.11 就一直不成功功过
最后打path 的时候 老是在那里循环提示
我不懂是怎么回事
具体描述 已经在开贴求助了 希望楼主有时间帮忙瞅一下
http://www.amobbs.com/forum.php? ... p;page=1#pid7394420
小白 非常感谢
 楼主| 发表于 2014-3-24 22:16:18 | 显示全部楼层
闷鱼 发表于 2014-3-21 03:14
请问您的内核版本是多少的
我的是 3.11 就一直不成功功过
谈不上指点。我下载的STM32F103的uclinux内核版本没这么新,2.6.x,具体的我不记得了。
发表于 2016-4-21 14:49:31 | 显示全部楼层
求教,stm32外扩flash,一般是用来存放参数文件等,不知道可以用来作代码空间吗???
 楼主| 发表于 2016-4-25 16:20:24 | 显示全部楼层
syj0925 发表于 2016-4-21 14:49
求教,stm32外扩flash,一般是用来存放参数文件等,不知道可以用来作代码空间吗??? ...
可以的。STM32通过FSMC外接NOR FLASH就可以做代码空间执行程序。
发表于 2016-4-26 14:36:54 | 显示全部楼层
javabean 发表于 2013-1-24 12:52
不错啊,PCB是4层板吗?
如果整个核心板大概多少钱呢?STM32可以跑linux,很多事情就省事了 ...
能省哪些事呀,很多驱动都不完善
发表于 2017-1-18 20:20:25 | 显示全部楼层
有才!佩服
GMT+8, 2024-7-18 03:49
