我移植了AVRCDC到LGT上。正常认出COM口。但是打开发送数据的时候,输出端并没有任何数据。这个让我觉得非常奇怪。
我移植后的代码是:
- /* Name: main.c
- * Project: AVR USB driver for CDC-SPI interface on Low-Speed USB
- * for ATmega8/48/88/168
- * Author: Osamu Tamura
- * Creation Date: 2010-01-26
- * Tabsize: 4
- * Copyright: (c) 2010 by Recursion Co., Ltd.
- * License: Proprietary, free under certain conditions. See Documentation.
- #include <string.h>
- #include <avr/io.h>
- #include <avr/interrupt.h>
- #include <avr/pgmspace.h>
- #include <avr/wdt.h>
- #include <util/delay.h>
- #include "usbdrv.h"
- #include "oddebug.h"
- #include "iolgt8f0xa.h"
- #define SPI_DDR DDRB
- #define SPI_PORT PORTB
- #define SPI_SS 1 // b2:DTS, b1:Break
- #define SPI_DO 3
- #define SPI_DI 4
- #define SPI_SCK 5 // F_CPU/64 (187.5KHz)
- #define SPI_PIN PINC
- #define SPI_MODE 0 // 11:mode0
- #define HW_CDC_BULK_OUT_SIZE 8
- #define HW_CDC_BULK_IN_SIZE 8
- enum {
- SEND_ENCAPSULATED_COMMAND = 0,
- GET_ENCAPSULATED_RESPONSE,
- SET_COMM_FEATURE,
- GET_COMM_FEATURE,
- CLEAR_COMM_FEATURE,
- SET_LINE_CODING = 0x20,
- GET_LINE_CODING,
- SET_CONTROL_LINE_STATE,
- SEND_BREAK
- static PROGMEM char configDescrCDC[] = { /* USB configuration descriptor */
- 9, /* sizeof(usbDescrConfig): length of descriptor in bytes */
- USBDESCR_CONFIG, /* descriptor type */
- 67,
- 0, /* total length of data returned (including inlined descriptors) */
- 2, /* number of interfaces in this configuration */
- 1, /* index of this configuration */
- 0, /* configuration name string index */
- #if USB_CFG_IS_SELF_POWERED
- (1 << 7) | USBATTR_SELFPOWER, /* attributes */
- #else
- (1 << 7), /* attributes */
- #endif
- USB_CFG_MAX_BUS_POWER/2, /* max USB current in 2mA units */
- /* interface descriptor follows inline: */
- 9, /* sizeof(usbDescrInterface): length of descriptor in bytes */
- USBDESCR_INTERFACE, /* descriptor type */
- 0, /* index of this interface */
- 0, /* alternate setting for this interface */
- USB_CFG_HAVE_INTRIN_ENDPOINT, /* endpoints excl 0: number of endpoint descriptors to follow */
- USB_CFG_INTERFACE_CLASS,
- USB_CFG_INTERFACE_SUBCLASS,
- USB_CFG_INTERFACE_PROTOCOL,
- 0, /* string index for interface */
- /* CDC Class-Specific descriptor */
- 5, /* sizeof(usbDescrCDC_HeaderFn): length of descriptor in bytes */
- 0x24, /* descriptor type */
- 0, /* header functional descriptor */
- 0x10, 0x01,
- 4, /* sizeof(usbDescrCDC_AcmFn): length of descriptor in bytes */
- 2, /* abstract control management functional descriptor */
- 0x06, /* SEND_BREAK,SET_LINE_CODING,GET_LINE_CODING,SET_CONTROL_LINE_STATE */
- 5, /* sizeof(usbDescrCDC_UnionFn): length of descriptor in bytes */
- 6, /* union functional descriptor */
- 0, /* CDC_COMM_INTF_ID */
- 1, /* CDC_DATA_INTF_ID */
- 5, /* sizeof(usbDescrCDC_CallMgtFn): length of descriptor in bytes */
- 1, /* call management functional descriptor */
- 3, /* allow management on data interface, handles call management by itself */
- /* Endpoint Descriptor */
- 7, /* sizeof(usbDescrEndpoint) */
- USBDESCR_ENDPOINT, /* descriptor type = endpoint */
- 0x80|USB_CFG_EP3_NUMBER, /* IN endpoint number */
- 0x03, /* attrib: Interrupt endpoint */
- 8, 0, /* maximum packet size */
- USB_CFG_INTR_POLL_INTERVAL, /* in ms */
- /* Interface Descriptor */
- 1, /* index of this interface */
- 2, /* endpoints excl 0: number of endpoint descriptors to follow */
- 0x0A, /* Data Interface Class Codes */
- 0,
- 0, /* Data Interface Class Protocol Codes */
- 0x01, /* OUT endpoint number 1 */
- 0x02, /* attrib: Bulk endpoint */
- HW_CDC_BULK_OUT_SIZE, 0, /* maximum packet size */
- 0, /* in ms */
- 0x81, /* IN endpoint number 1 */
- HW_CDC_BULK_IN_SIZE, 0, /* maximum packet size */
- 0, /* in ms */
- uchar usbFunctionDescriptor(usbRequest_t *rq)
- if(rq->wValue.bytes[1] == USBDESCR_DEVICE){
- usbMsgPtr = (uchar *)usbDescriptorDevice;
- return usbDescriptorDevice[0];
- }else{ /* must be config descriptor */
- usbMsgPtr = (uchar *)configDescrCDC;
- return sizeof(configDescrCDC);
- static uchar modeBuffer[7];
- static uchar sendEmptyFrame;
- static uchar intr3Status; /* used to control interrupt endpoint transmissions */
- /* ----------------------------- USB interface ----------------------------- */
- uchar usbFunctionSetup(uchar data[8])
- usbRequest_t *rq = (void *)data;
- if((rq->bmRequestType & USBRQ_TYPE_MASK) == USBRQ_TYPE_CLASS){ /* class request type */
- uchar value;
- if( rq->bRequest==GET_LINE_CODING || rq->bRequest==SET_LINE_CODING ){
- // return 0xff;
- return USB_NO_MSG;
- /* GET_LINE_CODING -> usbFunctionRead() */
- /* SET_LINE_CODING -> usbFunctionWrite() */
- value = rq->wValue.word;
- /* DTR => SPI_SS+1 */
- if( rq->bRequest==SET_CONTROL_LINE_STATE ) {
- SPI_PORT = (SPI_PORT&~(1<<(SPI_SS+1)))|((rq->wValue.word&1)<<(SPI_SS+1));
- #if USB_CFG_HAVE_INTRIN_ENDPOINT3
- /* Report serial state (carrier detect). On several Unix platforms,
- * tty devices can only be opened when carrier detect is set.
- if( intr3Status==0 )
- intr3Status = 2;
- #endif
- /* Break => SPI_SS */
- else if( rq->bRequest==SEND_BREAK )
- SPI_PORT = (SPI_PORT&~(1<<SPI_SS))|((value&1)<<SPI_SS);
- #if 1
- /* Prepare bulk-in endpoint to respond to early termination */
- if((rq->bmRequestType & USBRQ_DIR_MASK) == USBRQ_DIR_HOST_TO_DEVICE)
- sendEmptyFrame = 1;
- #endif
- return 0;
- /* spi buffer */
- static uchar rx_buf[HW_CDC_BULK_IN_SIZE];
- static uchar tx_buf[HW_CDC_BULK_OUT_SIZE];
- static uchar iwptr, uwptr;
- /* usbFunctionRead */
- uchar usbFunctionRead( uchar *data, uchar len )
- memcpy( data, modeBuffer, 7 );
- return 7;
- /* usbFunctionWrite */
- uchar usbFunctionWrite( uchar *data, uchar len )
- memcpy( modeBuffer, data, 7 );
- return 1;
- /* spi buffer */
- void usbFunctionWriteOut( uchar *data, uchar len )
- PORTA=0xFF;//这句代码为啥就是不执行呢?
- /* host -> spi */
- while( len-- )
- tx_buf[uwptr++] = *data++;
- /* postpone receiving next data */
- usbDisableAllRequests();
- static void hardwareInit(void)
- /* activate pull-ups except on USB lines */
- USB_CFG_IOPORT = (uchar)~((1<<USB_CFG_DMINUS_BIT)|(1<<USB_CFG_DPLUS_BIT));
- /* all pins input except USB (-> USB reset) */
- #ifdef USB_CFG_PULLUP_IOPORT /* use usbDeviceConnect()/usbDeviceDisconnect() if available */
- USBDDR = 0; /* we do RESET by deactivating pullup */
- usbDeviceDisconnect();
- #else
- USBDDR = (1<<USB_CFG_DMINUS_BIT)|(1<<USB_CFG_DPLUS_BIT);
- #endif
- /* keep 300 mS */
- _delay_ms( 300.0 );
- usbDeviceConnect();
- #else
- USBDDR = 0; /* remove USB reset condition */
- #endif
- void clockInit()
- uchar i,j;
- DDRC = DDRC & 0xFC;
- DDRA=0xFF;
- PORTA=0x00;
- //USB初始化……
- // b. 打开外部晶振
- PMCR = (1 << RC16MEN) ;//| (1 << OSCMEN);
- i=255;
- while(i--)
- j=255;while(j--);
- // d. 切换时钟到外部晶体
- PMCR = (1 << EXTMSEL)|(1 << RC16MEN);
- int main(void)
- uchar i;
- clockInit();
- SP=0x2ff;
- wdt_enable( WDTO_1S );
- //odDebugInit();
- //hardwareInit();
- usbInit();
- intr3Status = 0;
- sendEmptyFrame = 0;
- /* Set MOSI, SCK and /SS output, all others input */
- //SPI_DDR = (1<<SPI_DO)|(1<<SPI_SCK)|(3<<SPI_SS);
- //SPI_PORT = (~SPI_DDR)|(3<<SPI_SS);
- /* Enable SPI, Master, set clock rate fck/64 */
- // SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1);
- usbDeviceDisconnect(); // 复位
- for(i = 0; i<100; i++) // 等待 500 ms
- wdt_reset(); // 复位WDT
- _delay_ms(1);
- sei(); // 开中断
- PORTA=0x01;
- for(;;){ /* main event loop */
- wdt_reset();
- usbPoll();
- /* host => device */
- if( uwptr!=0 && iwptr==0 ) {
- usbEnableAllRequests();
- // set SPI mode
- // SPCR &= ~(3<<CPHA);
- // SPCR |= (((~SPI_PIN)>>SPI_MODE)&3)<<CPHA;
- while( iwptr<uwptr ) {
- iwptr++;
- /* Start transmission */
- // SPDR = tx_buf[iwptr];
- /* while( !(SPSR&(1<<SPIF)) )
- wdt_reset();
- rx_buf[iwptr++] = SPDR;*/
- uwptr = 0;
- /* host <= device */
- if( usbInterruptIsReady() && (iwptr|sendEmptyFrame) ) {
- usbSetInterrupt(rx_buf, iwptr);
- sendEmptyFrame = iwptr & HW_CDC_BULK_IN_SIZE;
- iwptr = 0;
- /* We need to report rx and tx carrier after open attempt */
- if(intr3Status != 0 && usbInterruptIsReady3()){
- static uchar serialStateNotification[10] = {0xa1, 0x20, 0, 0, 0, 0, 2, 0, 3, 0};
- if(intr3Status == 2){
- usbSetInterrupt3(serialStateNotification, 8);
- }else{
- usbSetInterrupt3(serialStateNotification+8, 2);//PORTA=-PORTA;
- intr3Status--;
- #endif
- return 0;
复制代码 usbconfig.h- /* Name: usbconfig.h
- * Project: V-USB, virtual USB port for Atmel's(r) AVR(r) microcontrollers
- * Author: Christian Starkjohann
- * Creation Date: 2005-04-01
- * Tabsize: 4
- * Copyright: (c) 2005 by OBJECTIVE DEVELOPMENT Software GmbH
- * License: GNU GPL v2 (see License.txt), GNU GPL v3 or proprietary (CommercialLicense.txt)
- * This Revision: $Id: usbconfig-prototype.h 740 2009-04-13 18:23:31Z cs $
- #ifndef __usbconfig_h_included__
- #define __usbconfig_h_included__
- General Description:
- This file is an example configuration (with inline documentation) for the USB
- driver. It configures V-USB for USB D+ connected to Port D bit 2 (which is
- also hardware interrupt 0 on many devices) and USB D- to Port D bit 4. You may
- wire the lines to any other port, as long as D+ is also wired to INT0 (or any
- other hardware interrupt, as long as it is the highest level interrupt, see
- section at the end of this file).
- + To create your own usbconfig.h file, copy this file to your project's
- + firmware source directory) and rename it to "usbconfig.h".
- + Then edit it accordingly.
- /* ---------------------------- Hardware Config ---------------------------- */
- /* #define USB_CFG_IOPORTNAME D */
- /* This is the port where the USB bus is connected. When you configure it to
- * "B", the registers PORTB, PINB and DDRB will be used.
- /* #define USB_CFG_DMINUS_BIT 4 */
- /* This is the bit number in USB_CFG_IOPORT where the USB D- line is connected.
- * This may be any bit in the port.
- /* #define USB_CFG_DPLUS_BIT 2 */
- /* This is the bit number in USB_CFG_IOPORT where the USB D+ line is connected.
- * This may be any bit in the port. Please note that D+ must also be connected
- * to interrupt pin INT0! [You can also use other interrupts, see section
- * "Optional MCU Description" below, or you can connect D- to the interrupt, as
- * it is required if you use the USB_COUNT_SOF feature. If you use D- for the
- * interrupt, the USB interrupt will also be triggered at Start-Of-Frame
- * markers every millisecond.]
- #define USB_CFG_IOPORTNAME D
- #define USB_CFG_DMINUS_BIT 6
- #define USB_CFG_DPLUS_BIT 2
- #define USB_CFG_CLOCK_KHZ (F_CPU/1000)
- /* Clock rate of the AVR in kHz. Legal values are 12000, 12800, 15000, 16000,
- * 16500 and 20000. The 12.8 MHz and 16.5 MHz versions of the code require no
- * crystal, they tolerate +/- 1% deviation from the nominal frequency. All
- * other rates require a precision of 2000 ppm and thus a crystal!
- * Default if not specified: 12 MHz
- #define USB_CFG_CHECK_CRC 0
- /* Define this to 1 if you want that the driver checks integrity of incoming
- * data packets (CRC checks). CRC checks cost quite a bit of code size and are
- * currently only available for 18 MHz crystal clock. You must choose
- * USB_CFG_CLOCK_KHZ = 18000 if you enable this option.
- /* ----------------------- Optional Hardware Config ------------------------ */
- /* #define USB_CFG_PULLUP_IOPORTNAME D */
- /* If you connect the 1.5k pullup resistor from D- to a port pin instead of
- * V+, you can connect and disconnect the device from firmware by calling
- * the macros usbDeviceConnect() and usbDeviceDisconnect() (see usbdrv.h).
- * This constant defines the port on which the pullup resistor is connected.
- /* #define USB_CFG_PULLUP_BIT 4 */
- /* This constant defines the bit number in USB_CFG_PULLUP_IOPORT (defined
- * above) where the 1.5k pullup resistor is connected. See description
- * above for details.
- /* --------------------------- Functional Range ---------------------------- */
- #define USB_CFG_HAVE_INTRIN_ENDPOINT 1
- /* Define this to 1 if you want to compile a version with two endpoints: The
- * default control endpoint 0 and an interrupt-in endpoint (any other endpoint
- * number).
- #define USB_CFG_HAVE_INTRIN_ENDPOINT3 1
- /* Define this to 1 if you want to compile a version with three endpoints: The
- * default control endpoint 0, an interrupt-in endpoint 3 (or the number
- * configured below) and a catch-all default interrupt-in endpoint as above.
- * You must also define USB_CFG_HAVE_INTRIN_ENDPOINT to 1 for this feature.
- #define USB_CFG_EP3_NUMBER 3
- /* If the so-called endpoint 3 is used, it can now be configured to any other
- * endpoint number (except 0) with this macro. Default if undefined is 3.
- /* #define USB_INITIAL_DATATOKEN USBPID_DATA1 */
- /* The above macro defines the startup condition for data toggling on the
- * interrupt/bulk endpoints 1 and 3. Defaults to USBPID_DATA1.
- * Since the token is toggled BEFORE sending any data, the first packet is
- * sent with the oposite value of this configuration!
- #define USB_CFG_IMPLEMENT_HALT 0
- /* Define this to 1 if you also want to implement the ENDPOINT_HALT feature
- * for endpoint 1 (interrupt endpoint). Although you may not need this feature,
- * it is required by the standard. We have made it a config option because it
- * bloats the code considerably.
- #define USB_CFG_SUPPRESS_INTR_CODE 0
- /* Define this to 1 if you want to declare interrupt-in endpoints, but don't
- * want to send any data over them. If this macro is defined to 1, functions
- * usbSetInterrupt() and usbSetInterrupt3() are omitted. This is useful if
- * you need the interrupt-in endpoints in order to comply to an interface
- * (e.g. HID), but never want to send any data. This option saves a couple
- * of bytes in flash memory and the transmit buffers in RAM.
- #define USB_CFG_INTR_POLL_INTERVAL 255
- /* If you compile a version with endpoint 1 (interrupt-in), this is the poll
- * interval. The value is in milliseconds and must not be less than 10 ms for
- * low speed devices.
- #define USB_CFG_IS_SELF_POWERED 0
- /* Define this to 1 if the device has its own power supply. Set it to 0 if the
- * device is powered from the USB bus.
- #define USB_CFG_MAX_BUS_POWER 100
- /* Set this variable to the maximum USB bus power consumption of your device.
- * The value is in milliamperes. [It will be divided by two since USB
- * communicates power requirements in units of 2 mA.]
- #if defined (__AVR_ATtiny2313__)
- #define USB_CFG_IMPLEMENT_FN_WRITE 0
- #else
- #define USB_CFG_IMPLEMENT_FN_WRITE 1
- #endif
- /* Set this to 1 if you want usbFunctionWrite() to be called for control-out
- * transfers. Set it to 0 if you don't need it and want to save a couple of
- * bytes.
- #define USB_CFG_IMPLEMENT_FN_READ 1
- /* Set this to 1 if you need to send control replies which are generated
- * "on the fly" when usbFunctionRead() is called. If you only want to send
- * data from a static buffer, set it to 0 and return the data from
- * usbFunctionSetup(). This saves a couple of bytes.
- #define USB_CFG_IMPLEMENT_FN_WRITEOUT 1
- /* Define this to 1 if you want to use interrupt-out (or bulk out) endpoints.
- * You must implement the function usbFunctionWriteOut() which receives all
- * interrupt/bulk data sent to any endpoint other than 0. The endpoint number
- * can be found in 'usbRxToken'.
- #define USB_CFG_HAVE_FLOWCONTROL 1
- /* Define this to 1 if you want flowcontrol over USB data. See the definition
- * of the macros usbDisableAllRequests() and usbEnableAllRequests() in
- * usbdrv.h.
- #define USB_CFG_LONG_TRANSFERS 0
- /* Define this to 1 if you want to send/receive blocks of more than 254 bytes
- * in a single control-in or control-out transfer. Note that the capability
- * for long transfers increases the driver size.
- /* #define USB_RX_USER_HOOK(data, len) if(usbRxToken == (uchar)USBPID_SETUP) blinkLED(); */
- /* This macro is a hook if you want to do unconventional things. If it is
- * defined, it's inserted at the beginning of received message processing.
- * If you eat the received message and don't want default processing to
- * proceed, do a return after doing your things. One possible application
- * (besides debugging) is to flash a status LED on each packet.
- /* #define USB_RESET_HOOK(resetStarts) if(!resetStarts){hadUsbReset();} */
- /* This macro is a hook if you need to know when an USB RESET occurs. It has
- * one parameter which distinguishes between the start of RESET state and its
- * end.
- /* #define USB_SET_ADDRESS_HOOK() hadAddressAssigned(); */
- /* This macro (if defined) is executed when a USB SET_ADDRESS request was
- * received.
- #define USB_COUNT_SOF 0
- /* define this macro to 1 if you need the global variable "usbSofCount" which
- * counts SOF packets. This feature requires that the hardware interrupt is
- * connected to D- instead of D+.
- /* #ifdef __ASSEMBLER__
- * macro myAssemblerMacro
- * in YL, TCNT0
- * sts timer0Snapshot, YL
- * endm
- * #endif
- * #define USB_SOF_HOOK myAssemblerMacro
- * This macro (if defined) is executed in the assembler module when a
- * Start Of Frame condition is detected. It is recommended to define it to
- * the name of an assembler macro which is defined here as well so that more
- * than one assembler instruction can be used. The macro may use the register
- * YL and modify SREG. If it lasts longer than a couple of cycles, USB messages
- * immediately after an SOF pulse may be lost and must be retried by the host.
- * What can you do with this hook? Since the SOF signal occurs exactly every
- * 1 ms (unless the host is in sleep mode), you can use it to tune OSCCAL in
- * designs running on the internal RC oscillator.
- * Please note that Start Of Frame detection works only if D- is wired to the
- * interrupt, not D+. THIS IS DIFFERENT THAN MOST EXAMPLES!
- #define USB_CFG_CHECK_DATA_TOGGLING 1
- /* define this macro to 1 if you want to filter out duplicate data packets
- * sent by the host. Duplicates occur only as a consequence of communication
- * errors, when the host does not receive an ACK. Please note that you need to
- * implement the filtering yourself in usbFunctionWriteOut() and
- * usbFunctionWrite(). Use the global usbCurrentDataToken and a static variable
- * for each control- and out-endpoint to check for duplicate packets.
- #if USB_CFG_CLOCK_KHZ==16500 || USB_CFG_CLOCK_KHZ==12800
- #define USB_CFG_HAVE_MEASURE_FRAME_LENGTH 1
- #include "osccal.h"
- #else
- #define USB_CFG_HAVE_MEASURE_FRAME_LENGTH 0
- #endif
- /* define this macro to 1 if you want the function usbMeasureFrameLength()
- * compiled in. This function can be used to calibrate the AVR's RC oscillator.
- #define USB_USE_FAST_CRC 0
- /* The assembler module has two implementations for the CRC algorithm. One is
- * faster, the other is smaller. This CRC routine is only used for transmitted
- * messages where timing is not critical. The faster routine needs 31 cycles
- * per byte while the smaller one needs 61 to 69 cycles. The faster routine
- * may be worth the 32 bytes bigger code size if you transmit lots of data and
- * run the AVR close to its limit.
- /* -------------------------- Device Description --------------------------- */
- #define USB_CFG_VENDOR_ID 0xc0, 0x16 /* = 0x16c0 = 5824 = voti.nl */
- /* USB vendor ID for the device, low byte first. If you have registered your
- * own Vendor ID, define it here. Otherwise you may use one of obdev's free
- * shared VID/PID pairs. Be sure to read USB-IDs-for-free.txt for rules!
- * *** IMPORTANT NOTE ***
- * This template uses obdev's shared VID/PID pair for Vendor Class devices
- * with libusb: 0x16c0/0x5dc. Use this VID/PID pair ONLY if you understand
- * the implications!
- #define USB_CFG_DEVICE_ID 0xe1, 0x05 /* = 0x05e1 = 1505 */
- /* This is the ID of the product, low byte first. It is interpreted in the
- * scope of the vendor ID. If you have registered your own VID with usb.org
- * or if you have licensed a PID from somebody else, define it here. Otherwise
- * you may use one of obdev's free shared VID/PID pairs. See the file
- * USB-IDs-for-free.txt for details!
- #define USB_CFG_DEVICE_VERSION 0x00, 0x01
- /* Version number of the device: Minor number first, then major number.
- #define USB_CFG_VENDOR_NAME 'w', 'w', 'w', '.', 'r', 'e', 'c', 'u', 'r', 's', 'i', 'o', 'n', '.', 'j', 'p'
- #define USB_CFG_VENDOR_NAME_LEN 16
- /* These two values define the vendor name returned by the USB device. The name
- * must be given as a list of characters under single quotes. The characters
- * are interpreted as Unicode (UTF-16) entities.
- * If you don't want a vendor name string, undefine these macros.
- * ALWAYS define a vendor name containing your Internet domain name if you use
- * obdev's free shared VID/PID pair. See the file USBID-License.txt for
- * details.
- #define USB_CFG_DEVICE_NAME 'U', 'S', 'B', '-', 'S', 'P', 'I'
- #define USB_CFG_DEVICE_NAME_LEN 7
- /* Same as above for the device name. If you don't want a device name, undefine
- * the macros. See the file USB-IDs-for-free.txt before you assign a name if
- * you use a shared VID/PID.
- /*#define USB_CFG_SERIAL_NUMBER 'N', 'o', 'n', 'e' */
- /*#define USB_CFG_SERIAL_NUMBER_LEN 0 */
- /* Same as above for the serial number. If you don't want a serial number,
- * undefine the macros.
- * It may be useful to provide the serial number through other means than at
- * compile time. See the section about descriptor properties below for how
- * to fine tune control over USB descriptors such as the string descriptor
- * for the serial number.
- #define USB_CFG_DEVICE_CLASS 2 /* set to 0 if deferred to interface */
- #define USB_CFG_DEVICE_SUBCLASS 0
- /* See USB specification if you want to conform to an existing device class.
- * Class 0xff is "vendor specific".
- #define USB_CFG_INTERFACE_CLASS 2 /* CDC class */
- #define USB_CFG_INTERFACE_SUBCLASS 2 /* Abstract (Modem) */
- #define USB_CFG_INTERFACE_PROTOCOL 1 /* AT-Commands */
- /* See USB specification if you want to conform to an existing device class or
- * protocol. The following classes must be set at interface level:
- * HID class is 3, no subclass and protocol required (but may be useful!)
- * CDC class is 2, use subclass 2 and protocol 1 for ACM
- /* #define USB_CFG_HID_REPORT_DESCRIPTOR_LENGTH 42 */
- /* Define this to the length of the HID report descriptor, if you implement
- * an HID device. Otherwise don't define it or define it to 0.
- * If you use this define, you must add a PROGMEM character array named
- * "usbHidReportDescriptor" to your code which contains the report descriptor.
- * Don't forget to keep the array and this define in sync!
- /* #define USB_PUBLIC static */
- /* Use the define above if you #include usbdrv.c instead of linking against it.
- * This technique saves a couple of bytes in flash memory.
- /* ------------------- Fine Control over USB Descriptors ------------------- */
- /* If you don't want to use the driver's default USB descriptors, you can
- * provide our own. These can be provided as (1) fixed length static data in
- * flash memory, (2) fixed length static data in RAM or (3) dynamically at
- * runtime in the function usbFunctionDescriptor(). See usbdrv.h for more
- * information about this function.
- * Descriptor handling is configured through the descriptor's properties. If
- * no properties are defined or if they are 0, the default descriptor is used.
- * Possible properties are:
- * + USB_PROP_IS_DYNAMIC: The data for the descriptor should be fetched
- * at runtime via usbFunctionDescriptor(). If the usbMsgPtr mechanism is
- * used, the data is in FLASH by default. Add property USB_PROP_IS_RAM if
- * you want RAM pointers.
- * + USB_PROP_IS_RAM: The data returned by usbFunctionDescriptor() or found
- * in static memory is in RAM, not in flash memory.
- * + USB_PROP_LENGTH(len): If the data is in static memory (RAM or flash),
- * the driver must know the descriptor's length. The descriptor itself is
- * found at the address of a well known identifier (see below).
- * List of static descriptor names (must be declared PROGMEM if in flash):
- * char usbDescriptorDevice[];
- * char usbDescriptorConfiguration[];
- * char usbDescriptorHidReport[];
- * char usbDescriptorString0[];
- * int usbDescriptorStringVendor[];
- * int usbDescriptorStringDevice[];
- * int usbDescriptorStringSerialNumber[];
- * Other descriptors can't be provided statically, they must be provided
- * dynamically at runtime.
- * Descriptor properties are or-ed or added together, e.g.:
- * #define USB_CFG_DESCR_PROPS_DEVICE (USB_PROP_IS_RAM | USB_PROP_LENGTH(18))
- * The following descriptors are defined:
- * USB_CFG_DESCR_PROPS_DEVICE
- * USB_CFG_DESCR_PROPS_CONFIGURATION
- * USB_CFG_DESCR_PROPS_STRINGS
- * USB_CFG_DESCR_PROPS_STRING_0
- * USB_CFG_DESCR_PROPS_STRING_VENDOR
- * USB_CFG_DESCR_PROPS_STRING_PRODUCT
- * USB_CFG_DESCR_PROPS_STRING_SERIAL_NUMBER
- * USB_CFG_DESCR_PROPS_HID
- * USB_CFG_DESCR_PROPS_HID_REPORT
- * USB_CFG_DESCR_PROPS_UNKNOWN (for all descriptors not handled by the driver)
- * Note about string descriptors: String descriptors are not just strings, they
- * are Unicode strings prefixed with a 2 byte header. Example:
- * int serialNumberDescriptor[] = {
- * USB_STRING_DESCRIPTOR_HEADER(6),
- * 'S', 'e', 'r', 'i', 'a', 'l'
- #define USB_CFG_DESCR_PROPS_DEVICE 0
- #define USB_CFG_DESCR_PROPS_CONFIGURATION USB_PROP_IS_DYNAMIC
- #define USB_CFG_DESCR_PROPS_STRINGS 0
- #define USB_CFG_DESCR_PROPS_STRING_0 0
- #define USB_CFG_DESCR_PROPS_STRING_VENDOR 0
- #define USB_CFG_DESCR_PROPS_STRING_PRODUCT 0
- #define USB_CFG_DESCR_PROPS_STRING_SERIAL_NUMBER 0
- #define USB_CFG_DESCR_PROPS_HID 0
- #define USB_CFG_DESCR_PROPS_HID_REPORT 0
- #define USB_CFG_DESCR_PROPS_UNKNOWN 0
- /* ----------------------- Optional MCU Description ------------------------ */
- /* The following configurations have working defaults in usbdrv.h. You
- * usually don't need to set them explicitly. Only if you want to run
- * the driver on a device which is not yet supported or with a compiler
- * which is not fully supported (such as IAR C) or if you use a differnt
- * interrupt than INT0, you may have to define some of these.
- /* #define USB_INTR_CFG MCUCR */
- /* #define USB_INTR_CFG_SET ((1 << ISC00) | (1 << ISC01)) */
- /* #define USB_INTR_CFG_CLR 0 */
- /* #define USB_INTR_ENABLE GIMSK */
- /* #define USB_INTR_ENABLE_BIT INT0 */
- /* #define USB_INTR_PENDING GIFR */
- /* #define USB_INTR_PENDING_BIT INTF0 */
- /* #define USB_INTR_VECTOR SIG_INTERRUPT0 */
- #if defined (__AVR_ATtiny45__) || defined (__AVR_ATtiny85__)
- #define USB_INTR_CFG PCMSK
- #define USB_INTR_CFG_SET (1<<USB_CFG_DPLUS_BIT)
- #define USB_INTR_ENABLE_BIT PCIE
- #define USB_INTR_PENDING_BIT PCIF
- #define USB_INTR_VECTOR SIG_PIN_CHANGE
- #endif
- #endif /* __usbconfig_h_included__ */
复制代码 |
