本人想利用delphi接收单片机采样得到的数据,然后进行绘图。但是根据delphi接收的数据发现几个问题,由于刚开始接触所以询问下阿莫论坛的各位坛友了:
问题1:定时器定时不准,timer1.Interval:=125; 定时125或是250的时候记录的定时时间是比较准确的;但是改用100或其他数据时候,定时的时间出现偏差;
问题2:delphi记录的数据,一个数据重复几次,之后该出现的数据连续丢失几个,该现象一直都是这样;比如:102 102 102 105 105 105 105 107 107 107 ...
希望大家能帮个忙,这个元旦都在调试这个程序,实在是没有招了我,具体的delphi程序如下:
unit Unit1;
interface
uses
Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
Dialogs, StdCtrls, Buttons, TeEngine, Series, ExtCtrls, TeeProcs, Chart,
SPComm,DateUtils,math, ComCtrls;
type
TForm1 = class(TForm)
Button1: TButton;
Chart1: TChart;
Label1: TLabel;
Series1: TFastLineSeries;
BitBtn1: TBitBtn;
Edit1: TEdit;
Label2: TLabel;
Timer1: TTimer;
BitBtn2: TBitBtn;
Shape1: TShape;
Label3: TLabel;
Label4: TLabel;
UpDown1: TUpDown;
Label7: TLabel;
Edit2: TEdit;
Comm1: TComm;
Label9: TLabel;
Label10: TLabel;
ComboBox2: TComboBox;
Label11: TLabel;
Edit4: TEdit;
Label12: TLabel;
Edit5: TEdit;
ComboBox1: TComboBox;
Edit3: TEdit;
Edit6: TEdit;
Button2: TButton;
Label5: TLabel;
Label6: TLabel;
Series2: TFastLineSeries;
procedure Button1Click(Sender: TObject);
procedure FormCreate(Sender: TObject);
procedure BitBtn1Click(Sender: TObject);
procedure Comm1ReceiveData(Sender: TObject; Buffer: Pointer;
BufferLength: Word);
procedure Timer1Timer(Sender: TObject);
procedure BitBtn2Click(Sender: TObject);
procedure UpDown1Changing(Sender: TObject; var AllowChange: Boolean);
procedure Edit4Change(Sender: TObject);
procedure ComboBox2Change(Sender: TObject);
procedure ComboBox1Change(Sender: TObject);
procedure Button2Click(Sender: TObject);
private
{ Private declarations }
public
{ Public declarations }
end;
var
Form1: TForm1;
implementation
var //设置全局变量
starttime:TDatetime;
starttime1:TDatetime;
filename:string;
picturename:string;
xuhao:integer;
real_bxz:double;
// real_hw:double;
//real_dl:double;
real_time:double;
bottom_adj:integer;
Inadata:Integer;
zt:integer=0;
{$R *.dfm}
procedure TForm1.Button1Click(Sender: TObject); //过程
//var
//temp:array[0..3] of byte;
begin
Comm1.StartComm;
timer1.Enabled:=true;
starttime:=now(); //
edit3.Text:=datetimetostr(now); //显示程序开始的日期和时间
//edit3.Text:=timetostr(now()); // 显示程序的开始时间
Inadata:=StrToint(Edit4.Text); //接受输入的初始值
filename:=extractfiledir(Application.ExeName)+'\data'+'\'+edit1.Text+'.txt'; //创建txt文件
picturename:=extractfiledir(Application.ExeName)+'\data'+'\'+edit1.Text+'_'+inttostr(xuhao)+'.bmp';
//创建照片
end;
//初始化对应的程序
procedure TForm1.FormCreate(Sender: TObject);
begin
chart1.LeftAxis.Automatic:=false; //设置左边不自动变化长短
chart1.BottomAxis.Automatic:=false; //设置底部不自动变化长短
chart1.LeftAxis.Maximum:=400; //量程为400
chart1.LeftAxis.Minimum:=0;
//chart1.RightAxis.Automatic:=false;
//chart1.RightAxis.Maximum:=40;
//chart1.RightAxis.Minimum:=0;
//chart1.BottomAxis.Automatic:=false;
chart1.BottomAxis.Maximum:=10; //底部最大值10,也就是为10s时间
chart1.BottomAxis.Minimum:=0; //底部最小值0;
series1.Clear; //曲线1清除
series2.Clear; //曲线2清除
timer1.Enabled:=false; //定时器1不使能
timer1.Interval:=125; //定时器1每隔0.125s触发一次
xuhao:=1;
try
// EnumcomPorts(ComboBOX1.Items);
Comm1.stopComm;
ComboBOX1.ItemIndex:=0;
Form1.Comm1.CommName:=ComboBox1.Text;//默认'COM1';
ComboBOX2.ItemIndex:=3; //默认波特率9600
Form1.Comm1.BaudRate:=StrToInt(ComboBox2.Text);//9600;
Comm1.ByteSize:=_8;
Comm1.StopBits:=_1;
Comm1.ParityCheck:=false;
Comm1.Parity:=none;
sleep(1); //SLEEP是停止工作的意思 SLEEP(1000)就是停止1秒
except
showmessage('信号处理器串口打开异常');
exit;//退出程序
end;
real_bxz:=0;
// real_hw:=0;
real_time:=0;
bottom_adj:=0;
end;
//退出按钮
procedure TForm1.BitBtn1Click(Sender: TObject);
begin
Comm1.stopComm;
comm1.Free;
sleep(2);
close;
end;
procedure TForm1.Comm1ReceiveData(Sender: TObject; Buffer: Pointer;
var
i:integer;
rece_array:array[0..20]of byte;
data_array:array[0..1] of byte;
begin
//starttime:=now();
sleep(2);
move(buffer^,rece_array,bufferlength);
if (bufferlength=2) then //信号处理器
begin
for i:=0 to (bufferlength-1) do
begin
data_array[i]:=rece_array[i];
end;
real_bxz:=(data_array[0]*256+data_array[1])/1.0;
//series1.Addxy(real_time,real_bxz);
// Edit2.Text:=FloatToStr(real_bxz);
// real_bxz:=data_array[0]/1.0;
{ real_time:=roundto(secondspan(now,starttime),-3);//四舍五入,保留三位小数
// 画图
if real_time>100 then
begin
chart1.BottomAxis.Maximum:=real_time+100; //满图之后,开始左移
end;
starttime1:=now();
edit6.Text:=timetostr(starttime1); }
//real_hw:=(data_array[5]*256+data_array[4])/10.0;
end;
end;
//定时器1设置
procedure TForm1.Timer1Timer(Sender: TObject);
var
txtfile:textfile;
begin
Timer1.Enabled:=false;
// 画图
if real_time>10 then // 当时间大于10s
begin
chart1.BottomAxis.Maximum:=real_time+10; //满图之后,开始左移
//chart1.BottomAxis.Minimum:=real_time-5;
end;
edit2.Text:=floattostr(roundto(real_bxz,-1));
starttime1:=now();
edit6.Text:=datetimetostr(starttime1);
series2.Addxy(real_time,Inadata);
// edit3.Text:=floattostr(roundto(real_hw,-1));
// 保存为TXT
if not FileExists(filename) then
begin
AssignFile(TxtFile,filename);
rewrite(TxtFile);
//try ... finally 的作用在于:如果出错误了,不管前面的错误如果,
//都将执行finally块的代码,这样代码可能更健壮
try
Writeln(TxtFile,'时间 表显值');
finally
closefile(txtfile);
end;
end
begin
try
assignfile(txtfile,filename);
Append(txtfile); //打开存在的文件并把文件指针定位在文件尾
writeln(txtfile,format('%.3f',[real_time])+' '+format('%.1f',[real_bxz]));
finally
closefile(txtfile);
end;
end;
Timer1.Enabled:=true;
end;
procedure TForm1.BitBtn2Click(Sender: TObject);
begin
BitBtn2.Enabled:=false;
chart1.SaveToBitmapFile(picturename);
xuhao:=xuhao+1;
BitBtn2.Enabled:=true;
end;
procedure TForm1.UpDown1Changing(Sender: TObject;
begin
bottom_adj:=UpDown1.Position*10;
if bottom_adj<(real_time-10) then
begin
chart1.BottomAxis.Minimum:=bottom_adj;
end;
end;
procedure TForm1.Edit4Change(Sender: TObject);
begin
//real_dl:=StrToFloat(Edit4.Text);
end;
procedure TForm1.ComboBox2Change(Sender: TObject);
var
BaudRate: Integer;
begin
if ComboBox2.Text = 'Custom' then
begin
ComboBox2.Style := csDropDown;
ComboBox2.SetFocus;
// unit1.Form1.Button2.Enabled := false;
end
begin
if ComboBox2.ItemIndex > 0 then
ComboBox2.Style := csDropDownList;
//下面是自定义波特率的
if TryStrToInt(ComboBox2.Text, BaudRate) then
begin
Form1.Comm1.BaudRate := BaudRate;
//Form1.Button2.Enabled := true;
end
end;
end;
procedure TForm1.ComboBox1Change(Sender: TObject);
begin
Form1.Comm1.CommName := '//./'+ComboBox1.Text;
end;
//暂停程序
procedure TForm1.Button2Click(Sender: TObject);
begin
zt:=zt+1;
if zt Mod 2=1 then
begin
sleep(5000);
end;
end;
end.
