发表于 2012-12-27 10:32:29
该GPS模块采用的是UART接口,默认波特率是9600,对应的是arduino的UART1,因此我将Cookie板的UART1设为9600,8,1,0.同时采用中断接收,GPS的数据帧都是以'$'为开头标志,以'\n'为结束标志,在接收时我们就以这为根据一次接收一帧数据,同时申请一个全局标志,当接收完成,该标志置1,当接收到的数据处理完成,该标志置0. 串口中断初始化与接收程序如下:
//! \brief UART1 Interrupt Receive Service.
//! \param None.
//! \return None.
unsigned char num = 0;
//! You need to define these variables in the main.c and initialize to 0.
extern char rev_buf[80]; //Receive Buffer
extern unsigned char rev_start, //Receiving start flag
rev_stop, //Receiving end flag
gps_flag; //GPS Processed flag
unsigned long
uart1CallbackFunc(void *pvCBData, unsigned long ulEvent,
unsigned long ulMsgParam, void *pvMsgData)
unsigned char ch;
ch = UARTCharGet(sUART_BASE);
if ((ch == '$') && (gps_flag == 0))
rev_start = 1;
rev_stop = 0;
if (rev_start == 1)
rev_buf[num++] = ch;
if (ch == '\n')
rev_buf[num] = '\0';
rev_start = 0;
rev_stop = 1;
gps_flag = 1;
num = 0;
return 0;
//! \brief UART1 Initialize.
//! \param ulBaudrate is the baud rate of UART1.
//! \return None.
void
UART1_Init(unsigned long ulBaudrate)
xSysCtlPeripheralReset(xSYSCTL_PERIPH_UART1);
xSysCtlPeripheralEnable(xSYSCTL_PERIPH_UART1);
xSysCtlPeripheralClockSourceSet(xSYSCTL_UART0_MAIN, 1);
xSysCtlPeripheralEnable(xGPIOSPinToPeripheralId(sD0));
sPinTypeUART(sUART_BASE);
xUARTConfigSet(sUART_BASE, ulBaudrate, (UART_CONFIG_WLEN_8 |
UART_CONFIG_STOP_ONE |
UART_CONFIG_PAR_NONE));
xUARTIntEnable(sUART_BASE, xUART_INT_RX);
UARTIntCallbackInit(sUART_BASE, uart1CallbackFunc);
xUARTEnable(sUART_BASE, (UART_BLOCK_UART | UART_BLOCK_TX | UART_BLOCK_RX));
xIntEnable(xINT_UART1);
//! \brief GPS Initialize.
//! \param ulBaudrate is the baud rate of GPS.
//! \return None.
void
GPS_Init(unsigned long ulBaudrate)
UART1_Init(ulBaudrate); // 默认是9600
现在正在调试各个数据帧的解析程序,调试成功将一起上传。 |
