#include <iom8v.h>
#include <macros.h>
#define uint8 unsigned char
#define uint16 unsigned int
/*-----------------RN8209--------------------------*/
uint8 Write_enable[1]={0xE5};// 写使能
uint8 IARMS[3]={0};//通道A电流有效值
#define RN8209_MOSI 3
#define RN8209_MISO 4
#define RN8209_SCK 5
#define CLR8209 PORTB&=~(1<<PB0); //CS为低电平,使能SPI
#define SET8209 PORTB|= (1<<PB0);
#define RN8209_IARMS 0x7f//通道A电流有效值
//数码管定义15E显示板 0-9 空
uint8 SegTab[19]={0x77,0x12,0xD5,0xD6,0xB2,0xE6,0xE7,0x52,0xF7,0xF6,0x00,0x80,0xF1,0x65,0x61,0xF3,0x97,0xA7,0x81};
uint8 Up_Disbuff[4]={1};
uint8 Middle_Disbuff[4]={1};
uint8 Down_Disbuff[4]={1};
/* -----------------数码显示扫描缓冲区------------------*/
uint8 Axx[4]={0x00,0x04,0x02,0x06};//译码地址
/*--------------------延时---------------------*/
void delay_us(uint16 us)
uint16 i;
us=us*5/4;
for(i=0;i<us;i++);
void delay_ms(uint16 ms)
uint16 i,j;
for(i=0;i<ms;i++)
for(j=0;j<1141;j++);
/*--------------------74HC164输入数据----------------*/
void write_164(uint8 ChrDat)
uint8 i;
for(i=8;i>0;i--)
if(ChrDat&0x80)// 输出数据
PORTD|=(1<<PD5);//PD5为74HC164的数据输入端,置1
PORTD&=~(1<<PD5);//置0
ChrDat<<=1;
PORTD&=~(1<<PD7); //PD7为74HC164的时钟信号,置0
PORTD|=(1<<PD7); //时钟给上升延信号,置1
/*-------------------74F138输入口数据--------------------*/
void out138(uint8 x)
uint8 i;
i = PORTC & 0xF8 ;
x = x & 0x07 ;
PORTC = i | x ;
/*--------------------刷新显示一次的程序--------------------*/
void display(void)
uint8 temp_address = 0 ;
for(temp_address=0;temp_address<4;temp_address++)
PORTC=0x07;//消影
write_164(SegTab[Down_Disbuff[temp_address]]);
write_164(SegTab[Middle_Disbuff[temp_address]]);
write_164(SegTab[Up_Disbuff[temp_address]]);
out138(Axx[temp_address]); //显示
delay_ms(1);//延时1ms
/*-----------RN8209读写函数-----------------------*/
void Reset_RN8209(void)
SET8209;
delay_us(10);
PORTB&=~(1<<RN8209_SCK);//时钟拉低
CLR8209;//拉低
delay_us(10);
void Write_RN8209_Byte(uint8 wdata)
uint8 i ;
for(i=0;i<8;i++)
if(wdata&0x80)//先发高位,上升沿
PORTB|=(1<<RN8209_MOSI);
PORTB&=~(1<<RN8209_MOSI);
delay_us(10);
PORTB|=(1<<RN8209_SCK);//时钟拉高
wdata<<=1;
uint8 Read_RN8209_Byte(void)
uint8 i,rdata;
for(i=0;i<8;i++)
rdata<<1;
PORTB|=(1<<RN8209_SCK); //读数据时为下降沿读出
delay_us(10);
delay_us(10);
if(PINB&(1<<RN8209_MISO))
rdata|=0x01;
return rdata;
void Write_RN8209_Reg(uint8 regn, uint8 *data, uint8 num)
Reset_RN8209();
Write_RN8209_Byte(regn|0x80);//命令寄存器最高位为1表示写,写命令寄存器+芯片解析+响应命令
while(num--)
Write_RN8209_Byte(data[num]);//单字节高位在前地位在后。多字节高字节在前,低字节在后
PORTB&=~(1<<RN8209_SCK);//拉低时钟端
delay_us(10);
SET8209;//拉高片选端
void Read_RN8209_Reg(uint8 regn,uint8 *data,uint8 num)
Reset_RN8209();
Write_RN8209_Byte(regn&0x7f);//命令寄存器最高位为0表示读
while(num--)
data[num] = Read_RN8209_Byte();//以字节为传输 高比特在前,低比特在后;多字节传输先传高字节再传低字节
delay_us(10);
SET8209;//拉高片选端
/*long Hex_To_Dex(uint8 *data,uint8 num)
uint8 i;
long k=0;
for(i=0;i<(num-1);i++)
k|=data[i];
k<<=8;
return k;
void Init_RN8209(void)
Write_RN8209_Reg(0xEA,Write_enable,1);//写使能
//long temp;
PORTB=0x00;
DDRB=0x2D;//设置MISO(PB4)为输入,高电平;MOSI(PB3) ,SCK(PB5) 和SS(PB2)为输出,高电平
//0010 1101
PORTC=0x07;
DDRC=0x07;//74HC138控制端CBA输为输出
PORTD=0xE0;//74HC164的CLR为PD6刚开始为高
DDRD=0xE0;
Init_RN8209();
if(PIND&(1<<PD2))
Read_RN8209_Reg(RN8209_IARMS,IARMS,3);
//temp=Hex_To_Dex(IARMS,3);
Up_Disbuff[3]=IARMS[2]>>4;
Up_Disbuff[3]=IARMS[2]&0x0f;
Up_Disbuff[2]=IARMS[1]>>4;
Up_Disbuff[2]=IARMS[1]&0x0f;
Middle_Disbuff[1]=IARMS[0]>>4;
Middle_Disbuff[1]=IARMS[0]&0x0f;
display();
