发表于 2012-12-13 13:57:56
smset 发表于 2012-12-13 13:17 ![](static/image/common/back.gif)
请贴出完整代码。
- * @file Project/main.c
- * @author Holts
- * @version V1.0.0
- * @date 2012-12-9
- * @brief Main program body
- /* Includes ----------------------------------------------*/
- #include "stm8s.h"
- #include "parameter.h"
- #include "ptask.h"
- #include "main.h"
- #include "HD44780.h"
- #include "delay.h"
- /* Private typedef ---------------------------------------*/
- /* Private macro -----------------------------------------*/
- /* Private variables -------------------------------------*/
- u8 temp_AD_H; // temporary registers for reading ADC result
- u8 temp_AD_L; // temporary registers for reading ADC result
- u8 ADInit; // flag for ADC initialized
- u8 ADSampRdy; // flag for filed of samples ready
- u8 AD_samp; // counter of stored samples
- u16 AD_sample[NUMB_SAMP]; // store samples field
- u16 AD_avg_value; // average of ADC result
- u8 peak_memo; // variables for peak level detector
- u8 peak_filt; // variables for peak level detector*/
- volatile u8 currid;
- volatile u8 timers[MAXTASKS];
- u8 Trg;
- u8 Cont;
- u8 Mode = MODE_R;
- u8 Frq = SEL_100;
- volatile bool event = TRUE;
- volatile u16 ten_ms = 0;
- volatile u16 sec = 0;
- volatile u16 min = 0;
- /* Define 6 custom characters to display bar graph*/
- char STCustom[48] =
- 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Blank
- 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, // 1column |
- 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, // 2columns ||
- 0x1c, 0x1c, 0x1c, 0x1c, 0x1c, 0x1c, 0x1c, 0x1c, // 3columns |||
- 0x1e, 0x1e, 0x1e, 0x1e, 0x1e, 0x1e, 0x1e, 0x1e, // 4columns ||||
- 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, 0x1f, // 5columns |||||
- /* Define DDS */
- //查询表中不可装载零值,否则会造成无中断产生
- u8 sinB[256] =
- 255,255,255,255,255,255,254,254,253,252,252,251,250,249,248,247,246,245,243,242,240,239,237,236,234,232,230,229,227,225,222,220,
- 218,216,214,211,209,206,204,201,199,196,194,191,188,185,183,180,177,174,171,168,165,162,159,156,153,150,147,144,140,137,134,131,
- 128,125,122,119,116,112,109,106,103,100, 97, 94, 91, 88, 85, 82, 79, 76, 73, 71, 68, 65, 62, 60, 57, 55, 52, 50, 47, 45, 42, 40,
- 38, 36, 34, 31, 29, 27, 26, 24, 22, 20, 19, 17, 16, 14, 13, 11, 10, 9, 8, 7, 6, 5, 4, 4, 3, 2, 2, 1, 1, 1, 1, 1,
- 1, 1, 1, 1, 1, 1, 2, 2, 3, 4, 4, 5, 6, 7, 8, 9, 10, 11, 13, 14, 16, 17, 19, 20, 22, 24, 26, 27, 29, 31, 34, 36,
- 38, 40, 42, 45, 47, 50, 52, 55, 57, 60, 62, 65, 68, 71, 73, 76, 79, 82, 85, 88, 91, 94, 97,100,103,106,109,112,116,119,122,125,
- 128,131,134,137,140,144,147,150,153,156,159,162,165,168,171,174,177,180,183,185,188,191,194,196,199,201,204,206,209,211,214,216,
- 218,220,222,225,227,229,230,232,234,236,237,239,240,242,243,245,246,247,248,249,250,251,252,252,253,254,254,255,255,255,255,255
- u16 i, count;
- u8 char_pos, roll;
- /* Custom characters can be 8 max. user defined characters from 0 to 7*/
- /* disp[] string is here to generate the display of custom characters on LCD*/
- /* of the bar graph using 8 characters pattern*/
- /* Example: printing "\0\0\0\0\0\0\0\0\n" will display 8 times character 0*/
- /* which is the blank character*/
- /* Example: printing "\5\5\5\5\5\5\5\5\n" will display 8 times character 5*/
- /* which is the 5 columns character*/
- char disp[] = "\0\0\0\0\0\0\0\0\n";
- char message[5][7] = {"STM8S", "Value", "Line", "8-Bit", "Micro"};
- /* Private function prototypes ---------------------------*/
- * @brief Count average of samples stored in the u16 field
- * @par Parameters:
- * *p: pointer to the begin of the field
- * smp: number of samples in the field
- * @retval Average u16 value
- u16 u16_average(u16 *p, u8 smp)
- u8 i;
- u16 sum;
- for(i=0, sum= 0; i < smp; ++i)
- sum+= *p++;
- return sum / smp;
- * @brief Prepare data for four LED bar of signal and peak indicator
- * val: Level of the mesured signal [0-4]
- * @retval 4 bits (low nibble) of the composite bar graph information
- u8 signal_and_peak_level(u8 val) {
- u8 signal;
- u8 peak;
- switch(val) {
- case 0: peak= 0; signal= 0; break; //set peak and signal levels
- case 1: peak= 1; signal= 1; break;
- case 2: peak= 2; signal= 3; break;
- case 3: peak= 4; signal= 7; break;
- case 4: peak= 8; signal= 15; break;
- default: peak= signal= 15;
- if(peak_filt == 0) { // slow fall of peak level indicator
- if(peak_memo) {
- peak_memo>>= 1;
- peak_filt= PEAK_FILTER;
- else
- --peak_filt;
- if(peak >= peak_memo) { // check the highest level value
- peak_memo= peak; // and copy it to peak indicator
- peak_filt= PEAK_FILTER; // with fall speed refresh
- return (signal | peak_memo); // return bar graph information
- * @brief Configures clocks
- * @par Parameters: None
- * @retval void None
- * @par Required preconditions: None
- void CLK_Configuration(void)
- { /* Fmaster = 16MHz */
- CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
- * @brief Configures GPIOs
- void GPIO_Configuration(void)
- /* GPIO reset */
- GPIO_DeInit(LCDPort);
- /* Configure LCDPort D0 output push-pull low LCD Bus*/
- GPIO_Init(LCDPort, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
- /* Configure LCDPort D1 output push-pull low LCD Bus*/
- GPIO_Init(LCDPort, GPIO_PIN_1, GPIO_MODE_OUT_PP_LOW_FAST);
- /* Configure LCDPort D2 output push-pull low LCD Bus*/
- GPIO_Init(LCDPort, GPIO_PIN_2, GPIO_MODE_OUT_PP_LOW_FAST);
- /* Configure LCDPort D3 output push-pull low LCD Bus*/
- GPIO_Init(LCDPort, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
- /* GPIO reset */
- GPIO_DeInit(LCDControlPort);
- /* Configure LCDPort E output push-pull low LCD Enable Pin*/
- GPIO_Init(LCDControlPort, LCD_Enable, GPIO_MODE_OUT_PP_LOW_FAST);
- /* Configure LCDPort RS output push-pull low LCD RS Pin*/
- GPIO_Init(LCDControlPort, LCD_RS, GPIO_MODE_OUT_PP_LOW_FAST);
- /* GPIO reset */
- GPIO_DeInit(LCDPwrPort);
- /* Configure LCDPwrOnPort VDD output push-pull low LCD Power Supply*/
- GPIO_Init(LCDPwrPort, LCDPwrPin, GPIO_MODE_OUT_PP_LOW_FAST);
- /* GPIOD reset */
- //GPIO_DeInit(BUTTON_PORT);
- /* Configure PC4 (push button) as input floating */
- GPIO_Init(BUTTON_PORT, BUTTON_PIN, GPIO_MODE_IN_PU_NO_IT);
- /* Configure PD0 (LED1) as output push-pull low (led switched on) */
- //GPIO_Init(GPIOD, GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
- /* ADC reset */
- GPIO_DeInit(ADC_GPIO_PORT);
- GPIO_Init(ADC_GPIO_PORT, ADC_INPUT, GPIO_MODE_IN_FL_NO_IT);
- * @brief TIM1 init
- void TIM1_Config(void)
- TIM1_DeInit();
- /* Time Base configuration */
- TIM1_Prescaler = 8 分频 16/8 = 2000 KHz
- TIM1_Period = 8000 频率 2000 KHz /(7999 + 1) = 250KHz
- TIM1_CounterMode = TIM1_COUNTERMODE_UP
- TIM1_RepetitionCounter = 0
- TIM1_TimeBaseInit(8, TIM1_COUNTERMODE_UP, AUTORELOAD - 1, 0);
- /* Channel 2 Configuration in PWM mode */
- TIM1_OCMode = TIM1_OCMODE_PWM2
- TIM1_OutputState = TIM1_OUTPUTSTATE_ENABLE
- TIM1_OutputNState = TIM1_OUTPUTNSTATE_ENABLE
- TIM1_Pulse = DutyCycle
- TIM1_OCPolarity = TIM1_OCPOLARITY_LOW
- TIM1_OCNPolarity = TIM1_OCNPOLARITY_HIGH
- TIM1_OCIdleState = TIM1_OCIDLESTATE_SET
- TIM1_OCNIdleState = TIM1_OCIDLESTATE_RESET
- TIM1_OC1Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE, FRQ_100HZ/2,
- TIM1_OCPOLARITY_LOW, TIM1_OCNPOLARITY_HIGH, TIM1_OCIDLESTATE_SET,
- TIM1_OCNIDLESTATE_RESET);
- TIM1_OC2Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE, FRQ_100HZ/2,
- TIM1_OC3Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE, FRQ_100HZ/2,
- TIM1_OC4Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, FRQ_100HZ/2, TIM1_OCPOLARITY_LOW,
- TIM1_OCIDLESTATE_SET);
- /* TIM1 counter enable */
- TIM1_Cmd(ENABLE);
- /* TIM1 Main Output Enable */
- TIM1_CtrlPWMOutputs(ENABLE);
- * @brief TIM2 init
- void TIM2_Config(void)
- TIM2_DeInit();
- TIM1_Prescaler = 8 分频16/8 = 2 MHz
- TIM1_Period = 20 频率 2000 K /(20-1) = 100KHz
- TIM2_TimeBaseInit(TIM2_PRESCALER_8, AD_STAB);
- /* auto reload register is buferred */
- TIM2_ARRPreloadConfig(ENABLE);
- TIM1_Cmd(ENABLE);
- * @brief Configure TIM4 to generate an update interrupt each 1ms
- * @param None
- * @retval None
- void TIM4_Config(void)
- /* TIM4 configuration:
- - TIM4CLK is set to 16 MHz, the TIM4 Prescaler is equal to 128 so the TIM1 counter
- clock used is 16 MHz / 128 = 125 000 Hz
- - With 125 000 Hz we can generate time base:
- max time base is 2.048 ms if TIM4_PERIOD = 255 --> (255 + 1) / 125000 = 2.048 ms
- min time base is 0.016 ms if TIM4_PERIOD = 1 --> ( 1 + 1) / 125000 = 0.016 ms
- - In this example we need to generate a time base equal to 1 ms
- so TIM4_PERIOD = (0.001 * 125000 - 1) = 124 */
- /* Time base configuration */
- TIM4_TimeBaseInit(TIM4_PRESCALER_128, TIM4_PERIOD_MS);
- /* Clear TIM4 update flag */
- TIM4_ClearFlag(TIM4_FLAG_UPDATE);
- /* Enable update interrupt */
- TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);
- /* Enable TIM4 */
- TIM4_Cmd(ENABLE);
- * @brief Key Read
- void KeyRead( void )
- //unsigned char ReadData = GPIO_ReadInputData(KEY_GPIO_PORT)^0xFF;
- //ReadData = ReadData & 0x0E;
- u8 ReadData = (GPIO_ReadInputData(BUTTON_PORT)^0x80) & 0x80;
- Trg = ReadData & (ReadData ^ Cont);
- Cont = ReadData;
- * @brief Delay before completing the action
- * @param[in] function action() to be performed once the delay past
- * @param[in] None
- void Key_thread()
- PTH_BEGIN
- KeyRead();
- if (Trg)
- WaitX(20);
- KeyRead();
- if(Cont)
- if (Cont & BUTTON_PIN)
- { Mode = (Mode + 1) % 3; }
- if (Cont & KEY_FRQ)
- { Frq = (Frq + 1) % 3; }
- if (Cont & KEY_REDUCE)
- { Mode = MODE_R; }
- if (Cont & KEY_PLUS)
- PTH_END
- /* Public functions --------------------------------------*/
- * @brief Validation firmware main entry point.
- void main(void)
- /* Init CLK */
- CLK_Configuration();
- /* Init GPIOs*/
- /* This function sets GPIOs pins according to LCD pins assignment in main.h*/
- GPIO_Configuration();
- /* BEEP calibration */
- //BEEP_LSICalibrationConfig(9000);
- //TIM1_Config();
- /* TIM4 configuration */
- TIM4_Config();
- //GPIOC->DDR|= 0x02; // PC.1 as push-pull outputs
- //GPIOC->CR1|= 0x02;
- //GPIOE->CR1&=~0x40; // PE.6 as a floating input
- //GPIOE->DDR&=~0x40;
- // *** ADC INITIALIZATION ***
- // set autoreload register for trigger period
- //TIM1->ARRH= (u8)(AUTORELOAD >> 8);
- //TIM1->ARRL= (u8)(AUTORELOAD);
- TIM1_SetAutoreload(AUTORELOAD);
- // set compare register for trigger period
- //TIM1->CCR1H= (u8)((AUTORELOAD-AD_STAB) >> 8);
- //TIM1->CCR1L= (u8)(AUTORELOAD-AD_STAB);
- TIM1_SetCompare1(AUTORELOAD-AD_STAB);
- // auto reload register is buferred
- //TIM1->CR1|= TIM1_CR1_ARPE;
- TIM1_ARRPreloadConfig(ENABLE);
- // CC1REF is used as TRGO
- //TIM1->CR2= (4<<4) & TIM1_CR2_MMS;
- TIM1_SelectOutputTrigger(TIM1_TRGOSOURCE_OC1REF);
- // CC1REF in PWM 1 mode
- //TIM1->CCMR1= (6<<4) & TIM1_CCMR_OCM;
- TIM1_SelectOCxM(TIM1_CHANNEL_1, TIM1_OCMODE_PWM1);
- // CC1 interrupt enable
- //TIM1->IER|= TIM1_IER_CC1IE;
- TIM1_ITConfig(TIM1_IT_CC1, ENABLE);
- // CC1 negative polarity
- //TIM1->CCER1|= TIM1_CCER1_CC1P;
- TIM1_OC1PolarityConfig(TIM1_OCPOLARITY_LOW);
- // CC1 output enable
- //TIM1->CCER1|= TIM1_CCER1_CC1E;
- TIM1_CCxCmd(TIM1_CHANNEL_1, ENABLE);
- //TIM1->BKR|= TIM1_BKR_MOE;
- // synchronization of TRGO with ADC
- //TIM2->SMCR|= TIM2_SMCR_MSM;
- TIM1_SelectMasterSlaveMode(ENABLE);
- // timer 1 enable
- //TIM1->CR1|= TIM1_CR1_CEN;
- TIM1_Cmd(ENABLE);
- ADC1->CSR= ADC1_CSR_EOCIE | (3 & ADC1_CSR_CH); // ADC EOC interrupt enable, channel 3
- ADC1->CR1= 4<<4 & ADC1_CR1_SPSEL; // master clock/8, single conversion
- ADC1->CR2= ADC1_CR2_EXTTRIG; // external trigger on timer 1 TRGO, left alignment
- ADC1->TDRH= 2; // disable Schmitt trigger on AD input 9
- ADC1->TDRL= 0; //
- // init ADC variables
- AD_samp= 0; // number of stored samples 0
- ADInit= TRUE; // ADC initialized
- ADSampRdy= FALSE; // No sample
- ADC1->CR1|= ADC1_CR1_ADON; // ADC on
- enableInterrupts(); // enable all interrupts
- /* Set power supply on LCD via LCD Power Pin */
- //LCD_PWRON();
- /* Min. delay to wait before initialization after LCD power ON */
- /* Value is ms units*/
- Delay(100);
- /* Initialization of LCD */
- LCD_INIT();
- /* LCD Clear Display */
- LCD_CLEAR_DISPLAY();
- /* Set @CGRAM address start */
- LCD_CMD(CGRAM_address_start);
- /* Loading 6 characters @CGRAM address from STCustom tab */
- LCD_LOAD_CGRAM(STCustom, 6);
- /* Welcome application message while delay 3000ms */
- /* Set cursor to the chosen position*/
- LCD_LOCATE(1, 1);
- /* Print string on LCD (must be ended with \n)*/
- LCD_printstring(" LCR 2.0 \n");
- LCD_LOCATE(2, 2);
- LCD_printstring("XJW Putian,2011\n");
- Delay(3000);
- /* Init local variables*/
- roll = 0;
- count = 0;
- /* Init global variables*/
- ten_ms = 0;
- sec = 0;
- min = 0;
- //*** MAIN LOOP ***
- while (1)
- /* 键盘处理 */
- RunTask(Key_thread,1);
- /* 声音处理 */
- //Beep_thread(&pt2);
- /* ADC取样 */
- if (ADSampRdy == TRUE) // field of ADC samples is ready?
- { // average of samples
- AD_avg_value= u16_average(&AD_sample[0], AD_samp);
- AD_samp= 0; // reinitalize ADC variables
- ADSampRdy= FALSE;
- // setting LED status
- //leds= signal_and_peak_level((u8)((AD_avg_value + 128) / 256));
- /* Display ADC value at the top right*/
- LCD_LOCATE(1, 11);
- /* Uses special mask*/
- LCD_printf("%5d", AD_avg_value);
- if (Frq == SEL_100)
- LCD_LOCATE(1, 1);
- LCD_printf("%s", "F 100");
- if (Frq == SEL_1K)
- LCD_LOCATE(1, 1);
- LCD_printf("%s", "F 1K ");
- if (Frq == SEL_7K8)
- LCD_LOCATE(1, 1);
- LCD_printf("%s", "F 7K8");
- if (Mode == MODE_R)
- LCD_LOCATE(1, 10);
- LCD_printf("%s", "R");
- if (Mode == MODE_C)
- LCD_printf("%s", "C");
- if (Mode == MODE_L)
- LCD_printf("%s", "L");
- /* If event true (1 sec elapsed) then display rolling messages*/
- if (event == TRUE)
- event = FALSE;
- LCD_LOCATE(2, 11);
- /* Message is displayed at the bottom right*/
- LCD_printf("%5s", message[roll]);
- /* Message changes every time (5 times) then return to first word*/
- /* Table index "roll" is set accordingly*/
- roll = (roll + 1) % 5;
- /* Display time counter Min:Sec:Ten ms at the bottom left*/
- LCD_LOCATE(2, 1);
- LCD_printf("%02d:%02d:%02d", min, sec, ten_ms);
- /* Display each 6 (0 to 5) custom characters at same LCD position*/
- //char_pos = 0;
- //while (char_pos < 8)
- //for (i = 0;i < 6;i++)
- /* Display bar graph at the top left*/
- //LCD_LOCATE(1, 1);
- //LCD_printstring(disp);
- /* Change custom character to be displayed 0->1->2->3->4->5*/
- //disp[char_pos] = (disp[char_pos] + 1);
- /* if custom character 5 reached (all columns filled) maintain it display */
- //disp[char_pos] = 5;
- /* and move to next position of bar graph*/
- //char_pos++;
- /* Reset bar graph display to blank*/
- //for (i = 0;i < 8;i++)
- //disp[i] = 0;
- /* Blink display and wait for a while*/
- //LCD_DISP_OFF();
- //Delay(300);
- //LCD_DISP_ON();
- //Delay(1000);
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval : None
- void assert_failed(u8* file, u32 line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
复制代码 |
