回复: 5
求助液晶问题,2.4寸tft 9325驱动,MCU是Atmega 32-16.
发表于 2012-11-17 11:25:03 | 显示全部楼层 |阅读模式
首先液晶是好的,我放在我的LY-51s开发板上工作是正常的。后来将液晶插在我的Atmega32最小系统上就不工作了,只有白屏,哎,纠结死了。希望大家能指点一下到底是哪不对。。。。我就编了很简单的液晶初始化以及刷屏函数,一点反应都没有,上代码
  名称:彩屏
  内容:
#include<mega32.h>
                  全局变量
/* LCD color */
#define White          0xFFFF
#define Black          0x0000
#define Blue           0x001F
#define Blue2          0x051F
#define Red            0xF800
#define Magenta        0xF81F
#define Green          0x07E0
#define Cyan           0x7FFF
#define Yellow         0xFFE0
#define WINDOW_XADDR_START    0x0050 // Horizontal Start Address Set
#define WINDOW_XADDR_END    0x0051 // Horizontal End Address Set
#define WINDOW_YADDR_START    0x0052 // Vertical Start Address Set
#define WINDOW_YADDR_END    0x0053 // Vertical End Address Set
#define GRAM_XADDR            0x0020 // GRAM Horizontal Address Set
#define GRAM_YADDR            0x0021 // GRAM Vertical Address Set
#define GRAMWR                 0x0022 // memory write
#define DataPort PORTD                //数据口使用DataPort
                           定义硬件端口
#define RW  PORTC.1
//#define _RD  PORTC.2
#define CS  PORTC.0
#define RS  PORTC.6
#define RES  PORTC.7 //端口设置
void ILI9325_Initial(void);
void Write_Cmd_Data(unsigned char x, unsigned int y);
void Write_Cmd(unsigned char DH,unsigned char DL);
void Write_Data(unsigned char DH,unsigned char DL);
void delayms(unsigned int tt);
void Show_RGB (unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1,unsigned int Color);
void  Write_Data_U16(unsigned int y);
static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1);
void CLR_Screen(unsigned int bColor);
void Put_pixel(unsigned char x,unsigned char y,unsigned int color);
void Line(    unsigned char X0,unsigned char Y0,
            unsigned char X1,
            unsigned char Y1,
void Rectangle( unsigned char left,
                unsigned char top,
                unsigned char right,
                unsigned char bottom,
                      主函数
main()
        unsigned char x,y;
        DDRD=0XFF;
        DDRC=0XFF;
       ILI9325_Initial(); //初始化LCD
       CLR_Screen(White); //用背景色清屏
       //绘制矩形平面
       delayms(1000);
       Show_RGB(0,240,0,320,White);
       Rectangle(0,240,240,0,Black);
       for(x=0;x<240;x+=30)
            for(y=0;y<240;y+=2)
                Put_pixel(x,y,Black);
       for(y=0;y<240;y+=30)
            for(x=0;x<240;x+=2)
            for(y=0;y<120;y++)
                x=174;
            //delayms(1000);
            for(y=0;y<120;y++)
                x=74;
            //Show_RGB(0,240,0,320,White);
                           写命令
    CS=0;
    RS=0;
    DataPort=DH;
    RW=0;
    RW=1;
    DataPort=DL;
    RW=0;
    RW=1;
    CS=1;
                           写数据 双8位
    CS=0;
    RS=1;
    DataPort=DH;
    RW=0;
    RW=1;
    DataPort=DL;
    RW=0;
    RW=1;
    CS=1;
                         写命令、写数据
输入参数:x 需要输入的命令 16位
          y 需要输入的数据 16位
void  Write_Cmd_Data (unsigned char x,unsigned int y)
    unsigned char m,n;
    m=y>>8;
    n=y;
    Write_Cmd(0x00,x);
    Write_Data(m,n);
                         写16位数据
    unsigned char m,n;
    m=y>>8;
    n=y;
    Write_Data(m,n);
                        延时函数
void delayms(unsigned int count)
    int i,j;
    for(i=0;i<count;i++)
         for(j=0;j<260;j++);
                            液晶初始化
    CS=1;
    delayms(5);
    RES=0;
    delayms(5);
    RES=1;
delayms(50);
Write_Cmd_Data(0x0001,0x0100);
Write_Cmd_Data(0x0002,0x0700);
Write_Cmd_Data(0x0003,0x1030);
Write_Cmd_Data(0x0004,0x0000);
Write_Cmd_Data(0x0008,0x0207);
Write_Cmd_Data(0x0009,0x0000);
Write_Cmd_Data(0x000A,0x0000);
Write_Cmd_Data(0x000C,0x0000);
Write_Cmd_Data(0x000D,0x0000);
Write_Cmd_Data(0x000F,0x0000);
//power on sequence VGHVGL
Write_Cmd_Data(0x0010,0x0000);
Write_Cmd_Data(0x0011,0x0007);
Write_Cmd_Data(0x0012,0x0000);
Write_Cmd_Data(0x0013,0x0000);
//vgh
Write_Cmd_Data(0x0010,0x1290);
Write_Cmd_Data(0x0011,0x0227);
//delayms(100);
//vregiout
Write_Cmd_Data(0x0012,0x001d); //0x001b
//delayms(100);
//vom amplitude
Write_Cmd_Data(0x0013,0x1500);
//delayms(100);
//vom H
Write_Cmd_Data(0x0029,0x0018);
Write_Cmd_Data(0x002B,0x000D);
//gamma
Write_Cmd_Data(0x0030,0x0004);
Write_Cmd_Data(0x0031,0x0307);
Write_Cmd_Data(0x0032,0x0002);// 0006
Write_Cmd_Data(0x0035,0x0206);
Write_Cmd_Data(0x0036,0x0408);
Write_Cmd_Data(0x0037,0x0507);
Write_Cmd_Data(0x0038,0x0204);//0200
Write_Cmd_Data(0x0039,0x0707);
Write_Cmd_Data(0x003C,0x0405);// 0504
Write_Cmd_Data(0x003D,0x0F02);
//ram
Write_Cmd_Data(0x0050,0x0000);
Write_Cmd_Data(0x0051,0x00EF);
Write_Cmd_Data(0x0052,0x0000);
Write_Cmd_Data(0x0053,0x013F);
Write_Cmd_Data(0x0060,0xA700);
Write_Cmd_Data(0x0061,0x0001);
Write_Cmd_Data(0x006A,0x0000);
Write_Cmd_Data(0x0080,0x0000);
Write_Cmd_Data(0x0081,0x0000);
Write_Cmd_Data(0x0082,0x0000);
Write_Cmd_Data(0x0083,0x0000);
Write_Cmd_Data(0x0084,0x0000);
Write_Cmd_Data(0x0085,0x0000);
Write_Cmd_Data(0x0090,0x0010);
Write_Cmd_Data(0x0092,0x0600);
Write_Cmd_Data(0x0093,0x0003);
Write_Cmd_Data(0x0095,0x0110);
Write_Cmd_Data(0x0097,0x0000);
Write_Cmd_Data(0x0098,0x0000);
Write_Cmd_Data(0x0007,0x0133);
//    Write_Cmd_Data(0x0022);//
                         设置坐标
  Write_Cmd_Data(WINDOW_XADDR_START,x0);
  Write_Cmd_Data(WINDOW_XADDR_END,x1);
  Write_Cmd_Data(WINDOW_YADDR_START,y0);
  Write_Cmd_Data(WINDOW_YADDR_END,y1);
  Write_Cmd_Data(GRAM_XADDR,x0);
  Write_Cmd_Data(GRAM_YADDR,y0);
  Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR);
                           在屏幕上画线
输入参数:  起始坐标X0,Y0,终止坐标X1,Y1
            color 线颜色
            unsigned char Y0,
            unsigned char X1,
            unsigned char Y1,
            unsigned int color)
    int dx = X1 - X0;
    int dy = Y1 - Y0;
    int P  = 2 * dy - dx;
    int dobDy = 2 * dy;
    int dobD = 2 * (dy - dx);
    int PointX = 0,PointY = 0;
    int incx = 0,incy = 0;
    int distance = 0,xerr = 0,yerr = 0;
    unsigned int i = 0;
    if(dx == 0)        //k=1斜率为1
        PointX = X0;
        if(Y0 < Y1)
            PointY = Y0;
            PointY = Y1;
        for(i = 0;i <= ((Y0<Y1) ? (Y1-Y0) : (Y0-Y1));i++)
                Put_pixel(PointX,PointY,color);
            PointY++;
        return;
    if(dy == 0)        //k=0斜率为0
        PointY = Y0;
        if(X0 < X1)
            PointX = X0;
            PointX = X1;
        for(i = 0;i <= ((X0<X1) ? (X1-X0) : (X0-X1));i++)
            PointX++;
        return;
    if(dx > 0)
        incx = 1;
    else if(dx == 0)
        incx = 0;
        incx = -1;
    if(dy > 0)
        incy = 1;
    else if(dy == 0)
        incy = 0;
        incy = -1;
    dx = ((X0>X1) ? (X0-X1) : (X1-X0));
    dy = ((Y0>Y1) ? (Y0-Y1) : (Y1-Y0));
    if(dx>dy) distance=dx;
    else distance=dy;
    PointX = X0;
    PointY = Y0;
    for(i=0;i<=distance+1;i++)
        xerr+=dx;
        yerr+=dy;
        if(xerr>distance)
            xerr-=distance;
            PointX+=incx;
        if(yerr>distance)
            yerr-=distance;
            PointY+=incy;
                            绘制矩形框
输入参数:矩形的起始位置left,top
           矩形的结束位置right,bottom
          矩形框的颜色color
                unsigned char top,
                unsigned int color)
    Line(left,top,right,top,color);
    Line(left,top,left,bottom,color);
    Line(right,top,right,bottom,color);
    Line(left,bottom,right,bottom,color);
                           清屏函数
输入参数:bColor 清屏所使用的背景色
unsigned int i,j;
LCD_SetPos(0,240,0,320);//320x240
for (i=0;i<320;i++)
       for (j=0;j<240;j++)
           Write_Data_U16(bColor);
                            显示RGB颜色
输入参数:x0,y0 起始坐标
          x1,y1 结束坐标
          Color  背景颜色
    unsigned int i,j;
    LCD_SetPos(x0,x1,y0,y1);
    for (i=y0;i<=y1;i++)
       for (j=x0;j<=x1;j++)
           Write_Data_U16(Color);
                            画点
输入参数:x,y 需要画点坐标
          color 点的颜色
        LCD_SetPos(x,x,y,y);
        Write_Data_U16(color);
发表于 2012-11-24 20:17:40 | 显示全部楼层
AVR做的最小系统,为毛不把这晶振和电容焊好点啊?看着可难受啊。
 楼主| 发表于 2012-11-26 22:10:54 | 显示全部楼层
新手,还请谅解。。。。
发表于 2012-11-26 22:13:26 | 显示全部楼层
下午用51点亮我的HY2.4无鸭梨。。。。
 楼主| 发表于 2012-11-26 22:16:56 | 显示全部楼层
也是用9325主控芯片吗?
发表于 2013-1-17 19:03:38 | 显示全部楼层
用jtag调试一下,看看读出来的tft型号是不是正确的,如果正确向上找写命令的那个函数,曾遇到过类似的 重点检查写指令 写数据的那几个函数 还有端口的定义是否有问题。
GMT+8, 2024-7-24 05:15
