首先液晶是好的,我放在我的LY-51s开发板上工作是正常的。后来将液晶插在我的Atmega32最小系统上就不工作了,只有白屏,哎,纠结死了。希望大家能指点一下到底是哪不对。。。。我就编了很简单的液晶初始化以及刷屏函数,一点反应都没有,上代码
名称:彩屏
内容:
#include<mega32.h>
全局变量
/* LCD color */
#define White 0xFFFF
#define Black 0x0000
#define Blue 0x001F
#define Blue2 0x051F
#define Red 0xF800
#define Magenta 0xF81F
#define Green 0x07E0
#define Cyan 0x7FFF
#define Yellow 0xFFE0
#define WINDOW_XADDR_START 0x0050 // Horizontal Start Address Set
#define WINDOW_XADDR_END 0x0051 // Horizontal End Address Set
#define WINDOW_YADDR_START 0x0052 // Vertical Start Address Set
#define WINDOW_YADDR_END 0x0053 // Vertical End Address Set
#define GRAM_XADDR 0x0020 // GRAM Horizontal Address Set
#define GRAM_YADDR 0x0021 // GRAM Vertical Address Set
#define GRAMWR 0x0022 // memory write
#define DataPort PORTD //数据口使用DataPort
定义硬件端口
#define RW PORTC.1
//#define _RD PORTC.2
#define CS PORTC.0
#define RS PORTC.6
#define RES PORTC.7 //端口设置
void ILI9325_Initial(void);
void Write_Cmd_Data(unsigned char x, unsigned int y);
void Write_Cmd(unsigned char DH,unsigned char DL);
void Write_Data(unsigned char DH,unsigned char DL);
void delayms(unsigned int tt);
void Show_RGB (unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1,unsigned int Color);
void Write_Data_U16(unsigned int y);
static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1);
void CLR_Screen(unsigned int bColor);
void Put_pixel(unsigned char x,unsigned char y,unsigned int color);
void Line( unsigned char X0,unsigned char Y0,
unsigned char X1,
unsigned char Y1,
void Rectangle( unsigned char left,
unsigned char top,
unsigned char right,
unsigned char bottom,
主函数
main()
unsigned char x,y;
DDRD=0XFF;
DDRC=0XFF;
ILI9325_Initial(); //初始化LCD
CLR_Screen(White); //用背景色清屏
//绘制矩形平面
delayms(1000);
Show_RGB(0,240,0,320,White);
Rectangle(0,240,240,0,Black);
for(x=0;x<240;x+=30)
for(y=0;y<240;y+=2)
Put_pixel(x,y,Black);
for(y=0;y<240;y+=30)
for(x=0;x<240;x+=2)
for(y=0;y<120;y++)
x=174;
//delayms(1000);
for(y=0;y<120;y++)
x=74;
//Show_RGB(0,240,0,320,White);
写命令
CS=0;
RS=0;
DataPort=DH;
RW=0;
RW=1;
DataPort=DL;
RW=0;
RW=1;
CS=1;
写数据 双8位
CS=0;
RS=1;
DataPort=DH;
RW=0;
RW=1;
DataPort=DL;
RW=0;
RW=1;
CS=1;
写命令、写数据
输入参数:x 需要输入的命令 16位
y 需要输入的数据 16位
void Write_Cmd_Data (unsigned char x,unsigned int y)
unsigned char m,n;
m=y>>8;
n=y;
Write_Cmd(0x00,x);
Write_Data(m,n);
写16位数据
unsigned char m,n;
m=y>>8;
n=y;
Write_Data(m,n);
延时函数
void delayms(unsigned int count)
int i,j;
for(i=0;i<count;i++)
for(j=0;j<260;j++);
液晶初始化
CS=1;
delayms(5);
RES=0;
delayms(5);
RES=1;
delayms(50);
Write_Cmd_Data(0x0001,0x0100);
Write_Cmd_Data(0x0002,0x0700);
Write_Cmd_Data(0x0003,0x1030);
Write_Cmd_Data(0x0004,0x0000);
Write_Cmd_Data(0x0008,0x0207);
Write_Cmd_Data(0x0009,0x0000);
Write_Cmd_Data(0x000A,0x0000);
Write_Cmd_Data(0x000C,0x0000);
Write_Cmd_Data(0x000D,0x0000);
Write_Cmd_Data(0x000F,0x0000);
//power on sequence VGHVGL
Write_Cmd_Data(0x0010,0x0000);
Write_Cmd_Data(0x0011,0x0007);
Write_Cmd_Data(0x0012,0x0000);
Write_Cmd_Data(0x0013,0x0000);
//vgh
Write_Cmd_Data(0x0010,0x1290);
Write_Cmd_Data(0x0011,0x0227);
//delayms(100);
//vregiout
Write_Cmd_Data(0x0012,0x001d); //0x001b
//delayms(100);
//vom amplitude
Write_Cmd_Data(0x0013,0x1500);
//delayms(100);
//vom H
Write_Cmd_Data(0x0029,0x0018);
Write_Cmd_Data(0x002B,0x000D);
//gamma
Write_Cmd_Data(0x0030,0x0004);
Write_Cmd_Data(0x0031,0x0307);
Write_Cmd_Data(0x0032,0x0002);// 0006
Write_Cmd_Data(0x0035,0x0206);
Write_Cmd_Data(0x0036,0x0408);
Write_Cmd_Data(0x0037,0x0507);
Write_Cmd_Data(0x0038,0x0204);//0200
Write_Cmd_Data(0x0039,0x0707);
Write_Cmd_Data(0x003C,0x0405);// 0504
Write_Cmd_Data(0x003D,0x0F02);
//ram
Write_Cmd_Data(0x0050,0x0000);
Write_Cmd_Data(0x0051,0x00EF);
Write_Cmd_Data(0x0052,0x0000);
Write_Cmd_Data(0x0053,0x013F);
Write_Cmd_Data(0x0060,0xA700);
Write_Cmd_Data(0x0061,0x0001);
Write_Cmd_Data(0x006A,0x0000);
Write_Cmd_Data(0x0080,0x0000);
Write_Cmd_Data(0x0081,0x0000);
Write_Cmd_Data(0x0082,0x0000);
Write_Cmd_Data(0x0083,0x0000);
Write_Cmd_Data(0x0084,0x0000);
Write_Cmd_Data(0x0085,0x0000);
Write_Cmd_Data(0x0090,0x0010);
Write_Cmd_Data(0x0092,0x0600);
Write_Cmd_Data(0x0093,0x0003);
Write_Cmd_Data(0x0095,0x0110);
Write_Cmd_Data(0x0097,0x0000);
Write_Cmd_Data(0x0098,0x0000);
Write_Cmd_Data(0x0007,0x0133);
// Write_Cmd_Data(0x0022);//
设置坐标
Write_Cmd_Data(WINDOW_XADDR_START,x0);
Write_Cmd_Data(WINDOW_XADDR_END,x1);
Write_Cmd_Data(WINDOW_YADDR_START,y0);
Write_Cmd_Data(WINDOW_YADDR_END,y1);
Write_Cmd_Data(GRAM_XADDR,x0);
Write_Cmd_Data(GRAM_YADDR,y0);
Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR);
在屏幕上画线
输入参数: 起始坐标X0,Y0,终止坐标X1,Y1
color 线颜色
unsigned char Y0,
unsigned char X1,
unsigned char Y1,
unsigned int color)
int dx = X1 - X0;
int dy = Y1 - Y0;
int P = 2 * dy - dx;
int dobDy = 2 * dy;
int dobD = 2 * (dy - dx);
int PointX = 0,PointY = 0;
int incx = 0,incy = 0;
int distance = 0,xerr = 0,yerr = 0;
unsigned int i = 0;
if(dx == 0) //k=1斜率为1
PointX = X0;
if(Y0 < Y1)
PointY = Y0;
PointY = Y1;
for(i = 0;i <= ((Y0<Y1) ? (Y1-Y0) : (Y0-Y1));i++)
Put_pixel(PointX,PointY,color);
PointY++;
return;
if(dy == 0) //k=0斜率为0
PointY = Y0;
if(X0 < X1)
PointX = X0;
PointX = X1;
for(i = 0;i <= ((X0<X1) ? (X1-X0) : (X0-X1));i++)
PointX++;
return;
if(dx > 0)
incx = 1;
else if(dx == 0)
incx = 0;
incx = -1;
if(dy > 0)
incy = 1;
else if(dy == 0)
incy = 0;
incy = -1;
dx = ((X0>X1) ? (X0-X1) : (X1-X0));
dy = ((Y0>Y1) ? (Y0-Y1) : (Y1-Y0));
if(dx>dy) distance=dx;
else distance=dy;
PointX = X0;
PointY = Y0;
for(i=0;i<=distance+1;i++)
xerr+=dx;
yerr+=dy;
if(xerr>distance)
xerr-=distance;
PointX+=incx;
if(yerr>distance)
yerr-=distance;
PointY+=incy;
绘制矩形框
输入参数:矩形的起始位置left,top
矩形的结束位置right,bottom
矩形框的颜色color
unsigned char top,
unsigned int color)
Line(left,top,right,top,color);
Line(left,top,left,bottom,color);
Line(right,top,right,bottom,color);
Line(left,bottom,right,bottom,color);
清屏函数
输入参数:bColor 清屏所使用的背景色
unsigned int i,j;
LCD_SetPos(0,240,0,320);//320x240
for (i=0;i<320;i++)
for (j=0;j<240;j++)
Write_Data_U16(bColor);
显示RGB颜色
输入参数:x0,y0 起始坐标
x1,y1 结束坐标
Color 背景颜色
unsigned int i,j;
LCD_SetPos(x0,x1,y0,y1);
for (i=y0;i<=y1;i++)
for (j=x0;j<=x1;j++)
Write_Data_U16(Color);
画点
输入参数:x,y 需要画点坐标
color 点的颜色
LCD_SetPos(x,x,y,y);
Write_Data_U16(color);
