发表于 2012-11-20 21:18:07
我也来一起学习,都好几楼了,怎么还没看到实质性的东西,我开个头:
这个函数使用最多,先来研究这个函数
INT8U OSTaskCreateExt (void (*task)(void *p_arg),
void *p_arg,
OS_STK *ptos,
INT8U prio,
INT16U id,
OS_STK *pbos,
INT32U stk_size,
void *pext,
INT16U opt)
OS_STK *psp;
INT8U err;
#if OS_CRITICAL_METHOD == 3 /* Allocate storage for CPU status register */
OS_CPU_SR cpu_sr = 0;
#if OS_ARG_CHK_EN > 0
if (prio > OS_LOWEST_PRIO) { /* Make sure priority is within allowable range */
return (OS_ERR_PRIO_INVALID);
OS_ENTER_CRITICAL();
if (OSIntNesting > 0) { /* Make sure we don't create the task from within an ISR */
OS_EXIT_CRITICAL();
return (OS_ERR_TASK_CREATE_ISR);
if (OSTCBPrioTbl[prio] == (OS_TCB *)0) { /* Make sure task doesn't already exist at this priority */
OSTCBPrioTbl[prio] = OS_TCB_RESERVED;/* Reserve the priority to prevent others from doing ... */
/* ... the same thing until task is created. */
OS_EXIT_CRITICAL();
#if (OS_TASK_STAT_STK_CHK_EN > 0)
OS_TaskStkClr(pbos, stk_size, opt); /* Clear the task stack (if needed) */
psp = OSTaskStkInit(task, p_arg, ptos, opt); /* Initialize the task's stack */
err = OS_TCBInit(prio, psp, pbos, id, stk_size, pext, opt);
if (err == OS_ERR_NONE) {
if (OSRunning == OS_TRUE) { /* Find HPT if multitasking has started */
OS_Sched();
} else {
OSTCBPrioTbl[prio] = (OS_TCB *)0; /* Make this priority avail. to others */
OS_EXIT_CRITICAL();
return (err);
OS_EXIT_CRITICAL();
return (OS_ERR_PRIO_EXIST);
#endif |
