各位朋友,你们好。
刚装了WinAVR 20090313 不用使用。按网上的操作,修改好了makefile文件。
没有编译成功。
这是下面的故障:
这是makefile文件:
## General Flags
PROJECT = Test
MCU = atmega16
TARGET = Test.elf
CC = avr-gcc
CPP = avr-g++
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -std=gnu99 -DF_CPU=8000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
## Assembly specific flags
ASMFLAGS = $(COMMON)
ASMFLAGS += $(CFLAGS)
ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2
## Linker flags
LDFLAGS = $(COMMON)
LDFLAGS += -Wl,-Map=lcd1533.map
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom -R .fuse -R .lock -R .signature
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings
## Objects that must be built in order to link
OBJECTS = lcd1533.o
## Objects explicitly added by the user
LINKONLYOBJECTS =
## Build
all: $(TARGET) lcd1533.hex lcd1533.eep lcd1533.lss size
## Compile
lcd1533.o: ../lcd1533.c
$(CC) $(INCLUDES) $(CFLAGS) -c $<
##Link
$(TARGET): $(OBJECTS)
$(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
avr-objcopy -O ihex $(HEX_FLASH_FLAGS) $< $@
%.eep: $(TARGET)
-avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0
%.lss: $(TARGET)
avr-objdump -h -S $< > $@
@echo
@avr-size -C --mcu=${MCU} ${TARGET}
## Clean target
.PHONY: clean
clean:
-rm -rf $(OBJECTS) lcd1533.elf dep/* lcd1533.hex lcd1533.eep lcd1533.lss lcd1533.map
## Other dependencies
-include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
这里面的测试程序:
#include <avr/io.h>
#include <util/delay.h>
#define LED1_setout DDRA|=0x01
#define LED1_OFF PORTA|=0x01
#define LED1_ON PORTA$=0xfe
#define LED2_setout DDRA|=0x02
#define LED2_OFF PORTA|=0x02
#define LED2_ON PORTA&=0xfd
int main(void)
LED1_setout;
LED2_setout;
LED1_ON;
LED2_OFF;
_delay_ms(250);
LED2_ON
_delay_ms(250);
