主函数
#include<reg52.h>
#include "control.h"
#include "12864.h"
#include "ADXL.H"
#define uint unsigned int
sbit key=P2^7;
void timer_init()
TMOD=0X10;
TH1=(65535-100)/256;
TL1=(65535-100)%256;
EA=1;
ET1=1;
TR1=1;
void main()
char devid;
timer_init();
lcd_12864_init();
Init_ADXL345(); //初始化ADXL345
devid=Single_Read_ADXL345(0X00); //读出的数据为0XE5,表示正确
adxl345();
if(key==0)
keyscan_1();
keyscan();
Controh.H文件
#ifndef __contral_h_
#define __contral_h_
extern signed char pwm;
extern void delayms(unsigned int xms);
extern void keyscan();
extern void keyscan_1();
Control.C文件
#include<reg51.h>
#include "12864.h"
#define keydata P0
sbit A1=P2^4;
sbit A2=P2^5;
sbit ENA=P2^6;
signed int count=0;
signed char pwm=0;
signed char anjian=0;
uchar numshi=0;
uchar numge=0;
unsigned int i,j;
for(i=0;i<xms;i++)
for(j=0;j<110;j++);
void pwm_dis()
numshi=pwm/10;
numge=pwm%10;
write_12864_data(0x30+numshi);
write_12864_data(0x30+numge);
void anjian_dis()
numshi=anjian/10;
numge=anjian%10;
void keyscan()
unsigned char dat=0;
unsigned char num=0;
keydata=0xfe;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xee:num=1;
case 0xde:num=2;
case 0xbe:num=3;
case 0x7e:num=4;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
keydata=0xfd;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xed:num=5;
case 0xdd:num=6;
case 0xbd:num=7;
case 0x7d:num=8;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
keydata=0xfb;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xeb:num=9;
case 0xdb:num=10;
case 0xbb:num=11;
case 0x7b:num=12;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
keydata=0xf7;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xe7:num=13;
case 0xd7:num=14;
case 0xb7:num=15;
case 0x77:num=16;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
switch(num)
case 1: write_12864_addr(1,3);
pwm=0;
pwm_dis();
case 2: write_12864_addr(1,3);
pwm=10;
pwm_dis();
case 3:write_12864_addr(1,3);
pwm=20;
pwm_dis();
case 4:write_12864_addr(1,3);
pwm=30;
pwm_dis();
case 5:write_12864_addr(1,3);
pwm=40;
pwm_dis();
case 6:write_12864_addr(1,3);
pwm=50;
pwm_dis();
case 7:write_12864_addr(1,3);
pwm=60;
pwm_dis();
case 8:write_12864_addr(1,3);
pwm=70;
pwm_dis();
case 9: write_12864_addr(1,3);
pwm=80;
pwm_dis();
case 10: write_12864_addr(1,3);
pwm=90;
pwm_dis();
case 11:write_12864_addr(1,3);
pwm=99;
pwm_dis();
case 12:write_12864_addr(1,3);
pwm=35;
pwm_dis();
case 13:write_12864_addr(1,3);
pwm=pwm+5;
pwm_dis();
case 14:write_12864_addr(1,3);
pwm=pwm-5;
pwm_dis();
case 15:write_12864_addr(1,3);
pwm=pwm+1;
pwm_dis();
case 16:write_12864_addr(1,3);
pwm=pwm-1;
pwm_dis();
void keyscan_1()
keydata=0xfe;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xee:num=1;
case 0xde:num=2;
case 0xbe:num=3;
case 0x7e:num=4;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
keydata=0xfd;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xed:num=5;
case 0xdd:num=6;
case 0xbd:num=7;
case 0x7d:num=8;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
keydata=0xfb;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xeb:num=9;
case 0xdb:num=10;
case 0xbb:num=11;
case 0x7b:num=12;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
keydata=0xf7;
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
delayms(5);
dat=keydata;
dat=dat&0xf0;
while(dat!=0xf0)
dat=keydata;
switch(dat)
case 0xe7:num=13;
case 0xd7:num=14;
case 0xb7:num=15;
case 0x77:num=16;
while(dat!=0xf0)
dat=keydata;
dat=dat&0xf0;
switch(num)
case 1: write_12864_addr(3,7);
anjian=0;
anjian_dis();
case 2: write_12864_addr(3,7);
anjian=10;
anjian_dis();
case 3:write_12864_addr(3,7);
anjian=20;
anjian_dis();
case 4:write_12864_addr(3,7);
anjian=30;
anjian_dis();
case 5:write_12864_addr(3,7);
anjian=40;
anjian_dis();
case 6:write_12864_addr(3,7);
anjian=50;
anjian_dis();
case 7:write_12864_addr(3,7);
anjian=60;
anjian_dis();
case 8:write_12864_addr(3,7);
anjian=anjian+1;
anjian_dis();
case 9: write_12864_addr(3,7);
anjian=anjian+2;
anjian_dis();
case 10: write_12864_addr(3,7);
anjian=anjian+3;
anjian_dis();
case 11:write_12864_addr(3,7);
anjian=anjian+4;
anjian_dis();
case 12:write_12864_addr(3,7);
anjian=anjian+5;
anjian_dis();
case 13:write_12864_addr(3,7);
anjian=anjian+6;
anjian_dis();
case 14:write_12864_addr(3,7);
anjian=anjian+7;
anjian_dis();
case 15:write_12864_addr(3,7);
anjian=anjian+8;
anjian_dis();
case 16:write_12864_addr(3,7);
anjian=anjian+9;
anjian_dis();
void timer0() interrupt 3
A1=1;
A2=0;
count++;
if(count>=100)
count=0;
if(count<pwm)
ENA=1;
ENA=0;
12864.H文件
#ifndef __12864_h_
#define __12864_h_
//extern void lcd_writestring(unsigned char *str); //向lcd发送一个字符串,长度64字符之内。
extern void write_12864_cmd(unsigned char cmd ); //向液晶写数据
extern void write_12864_data(unsigned char dat); //向液晶写数据
extern void lcd_12864_init(); //初始化液晶
extern void write_12864_addr(unsigned char x ,unsigned char y); //写液晶的地址
extern void delayms_12864(unsigned char xms); //延时函数
//extern void write_12864_addr(unsigned char x ,unsigned char y); //写液晶的地址
12864.C文件
12864指令: 0x01 //将DDRAM填满“20H”,并且设定DDRAM的地址计数器(AC)到“00H”
0x02 //设定DDRAM的地址计数器 (AC)到“00H”,
并且将游标移到开头原点位置;这个指令并不改变DDRAM的内容
0x04 //读写后,AC减一,向左写
0x06 //读写后,AC加一,向右写
0x10 //光标向左移动,AC减一
0x14 //光标向右移动,AC加一
0x18 //显示向左移动,光标跟着移动
0x1c //显示向右移动,光标跟着移动
0x0c //整体显示开,游标关,游标位置反白不允许
0x0e //整体显示开,游标开,游标位置反白不允许
0x0f //整体显示开,游标开,游标位置反白允许
0x08 //关显示,关光标,关光标闪烁
0x30 //8位数据端口,基本指令操作
0x34 //8位数据总线,扩展指令集
0x20 //4位数据总线,基本指令集
0x24 //4位数据总线,扩展指令集
#include<reg52.h>
#include "12864.h"
#define lcd_data P1 //定义液晶数据端口
sbit lcd_PSB=P3^7; //液晶串行数据和并行数据选择端
sbit lcd_EN=P3^4; //液晶en使能端
sbit lcd_RS=P3^5; //液晶的rs
sbit lcd_RW=P3^6; //液晶的rw读写端口
void delayms_12864(unsigned char xms) //延时函数
unsigned char i,j;
for(i=0;i<xms;i++)
for(j=0;j<110;j++);
bit check_12864_busy() //检测液晶忙不忙
bit result=0;
lcd_RS=0;
lcd_RW=1;
lcd_EN=1;
delayms_12864(3);
result=(bit)(lcd_data&0x80); //取出数据端口的最高位
lcd_EN=0;
return result;
void write_12864_cmd(unsigned char cmd ) //写指令
while(check_12864_busy()); //检测液晶忙不忙
lcd_RS=0; //rs=0为写命令
lcd_EN=0;
lcd_RW=0;
lcd_data=cmd; //把指令给数据端口
delayms_12864(1);
lcd_EN=1;
delayms_12864(1);
lcd_EN=0;
void write_12864_data(unsigned char dat) //向液晶写数据
lcd_RS=1; //rs=1为写数据
lcd_EN=0;
lcd_RW=0;
lcd_data=dat; //把数据给数据端口
delayms_12864(1);
lcd_EN=1;
delayms_12864(1);
lcd_EN=0;
void lcd_12864_init() //初始化液晶
lcd_PSB=1;
write_12864_cmd(0x30);
delayms_12864(5);
write_12864_cmd(0x0c);
delayms_12864(5);
write_12864_cmd(0x01);
delayms_12864(5);
void write_12864_addr(unsigned char x ,unsigned char y) //写液晶的地址
unsigned char addr;
if(x==0) //如果x=0,地址为液晶第一行
{x=0x80;}
else if(x==1) //如果x=1,地址为液晶第二行
{x=0x90;}
else if(x==2) //如果x=2,地址为液晶第三行
{x=0x88;}
else if(x==3) //如果x=3,地址为液晶第四行
{x=0x98;}
addr=x+y;
write_12864_cmd(addr);
ADXL.H文件
#ifndef __ADXL_h_
#define __ADXL_h_
//extern void jiaodu(); //角度转换
//extern void display_x(); //x轴
//extern void display_y(); //y轴
//extern void display_z();//z轴
extern void Init_ADXL345(); //延时函数
extern unsigned char Single_Read_ADXL345(unsigned char REG_Address);
//extern void Multiple_read_ADXL345(void);
extern void adxl345();
ADXL.C 文件
#include <REG51.H>
#include <math.h> //Keil library
#include <stdio.h> //Keil library
#include <INTRINS.H>
#include "12864.h"
#define DataPort P1 //LCD1602数据端口
sbit SCL=P2^0; //IIC时钟引脚定义
sbit SDA=P2^1; //IIC数据引脚定义
sbit LED=P2^2;
#define SlaveAddress 0xA6 //定义器件在IIC总线中的从地址,根据ALT ADDRESS地址引脚不同修改
//ALT ADDRESS引脚接地时地址为0xA6,接电源时地址为0x3A
typedef unsigned char BYTE;
typedef unsigned short WORD;
BYTE BUF[8]; //接收数据缓存区
uchar ge,shi,bai,qian,wan; //显示变量
int dis_data;
//变量
void delay(unsigned int k);
void InitLcd(); //初始化lcd1602
void Init_ADXL345(void); //初始化ADXL345
void WriteDataLCM(uchar dataW);
void WriteCommandLCM(uchar CMD,uchar Attribc);
//void DisplayOneChar(uchar X,uchar Y,uchar DData);
void conversion(uint temp_data);
void Single_Write_ADXL345(uchar REG_Address,uchar REG_data); //单个写入数据
uchar Single_Read_ADXL345(uchar REG_Address); //单个读取内部寄存器数据
void Multiple_Read_ADXL345(); //连续的读取内部寄存器数据
void Delay5us();
void Delay5ms();
void ADXL345_Start();
void ADXL345_Stop();
void ADXL345_SendACK(bit ack);
bit ADXL345_RecvACK();
void ADXL345_SendByte(BYTE dat);
BYTE ADXL345_RecvByte();
void ADXL345_ReadPage();
void ADXL345_WritePage();
float tempz;
float tempy;
float tempx;
uchar tab[]="度";
uchar tab1[]="偏转";
uchar tab2[]="风力";
uchar tab3[]="输入";
wan=temp_data/10000+0x30 ;
temp_data=temp_data%10000; //取余运算
qian=temp_data/1000+0x30 ;
temp_data=temp_data%1000; //取余运算
bai=temp_data/100+0x30 ;
temp_data=temp_data%100; //取余运算
shi=temp_data/10+0x30 ;
temp_data=temp_data%10; //取余运算
ge=temp_data+0x30;
/*void DisplayOneChar(uchar DData)
//Y&=1;
//X&=15;
//if(Y)X|=0x40;
//X|=0x80;
//write_12864_addr(X,0);
write_12864_data(DData);
延时5微秒(STC90C52RC@12M)
不同的工作环境,需要调整此函数,注意时钟过快时需要修改
当改用1T的MCU时,请调整此延时函数
void Delay5us()
_nop_();_nop_();_nop_();_nop_();
延时5毫秒(STC90C52RC@12M)
不同的工作环境,需要调整此函数
当改用1T的MCU时,请调整此延时函数
void Delay5ms()
WORD n = 560;
while (n--);
起始信号
SDA = 1; //拉高数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 0; //产生下降沿
Delay5us(); //延时
SCL = 0; //拉低时钟线
停止信号
void ADXL345_Stop()
SDA = 0; //拉低数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 1; //产生上升沿
Delay5us(); //延时
发送应答信号
入口参数:ack (0:ACK 1:NAK)
SDA = ack; //写应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
接收应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
CY = SDA; //读应答信号
SCL = 0; //拉低时钟线
Delay5us(); //延时
return CY;
向IIC总线发送一个字节数据
BYTE i;
for (i=0; i<8; i++) //8位计数器
dat <<= 1; //移出数据的最高位
SDA = CY; //送数据口
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
ADXL345_RecvACK();
从IIC总线接收一个字节数据
BYTE i;
BYTE dat = 0;
SDA = 1; //使能内部上拉,准备读取数据,
dat <<= 1;
SCL = 1; //拉高时钟线
Delay5us(); //延时
dat |= SDA; //读数据
SCL = 0; //拉低时钟线
Delay5us(); //延时
return dat;
//******单字节写入*******************************************
ADXL345_Start(); //起始信号
ADXL345_SendByte(SlaveAddress); //发送设备地址+写信号
ADXL345_SendByte(REG_Address); //内部寄存器地址,请参考中文pdf22页
ADXL345_SendByte(REG_data); //内部寄存器数据,请参考中文pdf22页
ADXL345_Stop(); //发送停止信号
//********单字节读取*****************************************
{ uchar REG_data;
ADXL345_SendByte(REG_Address); //发送存储单元地址,从0开始
ADXL345_SendByte(SlaveAddress+1); //发送设备地址+读信号
REG_data=ADXL345_RecvByte(); //读出寄存器数据
ADXL345_SendACK(1);
ADXL345_Stop(); //停止信号
return REG_data;
//连续读出ADXL345内部加速度数据,地址范围0x32~0x37
{ uchar i;
ADXL345_SendByte(0x32); //发送存储单元地址,从0x32开始
for (i=0; i<6; i++) //连续读取6个地址数据,存储中BUF
BUF[i] = ADXL345_RecvByte(); //BUF[0]存储0x32地址中的数据
if (i == 5)
ADXL345_SendACK(1); //最后一个数据需要回NOACK
ADXL345_SendACK(0); //回应ACK
Delay5ms();
//初始化ADXL345,根据需要请参考pdf进行修改************************
void Init_ADXL345()
Single_Write_ADXL345(0x31,0x0B); //测量范围,正负16g,13位模式
Single_Write_ADXL345(0x2C,0x08); //速率设定为12.5 参考pdf13页
Single_Write_ADXL345(0x2D,0x08); //选择电源模式 参考pdf24页
Single_Write_ADXL345(0x2E,0x80); //使能 DATA_READY 中断
Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根据测试传感器的状态写入pdf29页
Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根据测试传感器的状态写入pdf29页
Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根据测试传感器的状态写入pdf29页
//显示x轴
void display_x()
{ //float tempx;
dis_data=(BUF[1]<<8)+BUF[0]; //合成数据
if(dis_data<0)
dis_data=-dis_data;
write_12864_addr(2,1);
write_12864_data('-'); //显示正负符号位
write_12864_data(' '); //显示空格
tempx=(float)dis_data*3.9; //计算数据和显示,查考ADXL345快速入门第4页
conversion(tempx); //转换出显示需要的数据
write_12864_addr(2,0);
write_12864_data('X');
write_12864_data(':');
write_12864_addr(2,2);
write_12864_data(qian);
write_12864_data('.');
write_12864_addr(2,3);
write_12864_data(bai);
write_12864_data(shi);
//write_12864_addr(2,3);
//DisplayOneChar(' ');
//显示y轴
void display_y()
{ // float tempy;
dis_data=(BUF[3]<<8)+BUF[2]; //合成数据
if(dis_data<0)
dis_data=-dis_data;
write_12864_addr(2,5);
tempy=(float)dis_data*3.9; //计算数据和显示,查考ADXL345快速入门第4页
conversion(tempy);//转换出显示需要的数据
write_12864_addr(2,4);
write_12864_data('Y'); //第1行,第0列 显示y
write_12864_addr(2,6);
write_12864_addr(2,7);
// write_12864_addr(2,7);
// DisplayOneChar(' ');
//显示z轴
void display_z()
// float temp;
dis_data=(BUF[5]<<8)+BUF[4]; //合成数据
if(dis_data<0)
dis_data=-dis_data;
write_12864_addr(3,1);
write_12864_data('-'); //显示负符号位
tempz=(float)dis_data*3.9; //计算数据和显示,查考ADXL345快速入门第4页
conversion(tempz); //转换出显示需要的数据
write_12864_addr(3,0);
write_12864_data('Z'); //第0行,第10列 显示Z
write_12864_addr(3,2);
write_12864_addr(3,3);
//write_12864_addr(3,4);
/*void adxl()
uchar devid;
uchar i,j;
float w;
delay(500);
void jiaodu()
uchar i,j,k;
float w;
w=(180*atan(tempz/tempx))/3.14;
if(w>=41&&w<=49)
LED=0;
LED=1;
conversion(w);
write_12864_addr(1,4);
for(j=0;tab1[j]!='\0';j++)
write_12864_data(tab1[j]);
write_12864_addr(1,6);
write_12864_data(ge);
write_12864_addr(1,7);
for(i=0;tab[i]!='\0';i++)
write_12864_data(tab[i]);
for(k=0;tab2[k]!='\0';k++)
write_12864_data(tab2[k]);
write_12864_addr(1,0);
for(k=0;tab3[k]!='\0';k++)
write_12864_data(tab3[k]);
void adxl345()
Multiple_Read_ADXL345(); //连续读出数据,存储在BUF中
display_x(); //---------显示X轴
display_y(); //---------显示Y轴
display_z(); //---------显示Z轴
//delay(200);
jiaodu();
