请教一个Verilog的问题,testbench仿真之后的输出一直是高阻态
一个四选一的选择器- module mux4_1(d0,d1,d2,d3,s0,s1,EN_n,data_out);
- input d0,d1,d2,d3;
- input s0,s1;
- input EN_n;
- output reg data_out;
- always @ (d0 or d1 or d2 or d3 or s0 or s1 or EN_n)
- if(EN_n)
- data_out <= 1'bz;
- else
- case ({s1,s0})
- 2'b00: data_out <= d0;
- 2'b01: data_out <= d1;
- 2'b10: data_out <= d2;
- 2'b11: data_out <= d3;
- default: data_out <= 1'dx;
- endcase
- endmodule
复制代码 这里是testbench- // *****************************************************************************
- // Generated on "11/03/2012 13:14:20"
- // Verilog Test Bench template for design : mux4_1
- // Simulation tool : ModelSim-Altera (Verilog)
- module mux4_1();
- // test vector input registers
- reg EN_n;
- reg d0;
- reg d1;
- reg d2;
- reg d3;
- reg s0;
- reg s1;
- // wires
- wire data_out;
- initial
- begin
- EN_n <= 1;
- d0 <= 1;
- d1 <= 0;
- d2 <= 1;
- d3 <= 0;
- s0 <= 0;
- s1 <= 0;
- forever #10 {s1,s0} <= $random;
- end
- initial
- #5000 EN_n <= 0;
- initial
- #10000
- $stop;
- endmodule
复制代码 仿真之后的结果如图
输出值一直是HiZ
不知何故 |
