近期做一个小项目,使用的FPGA开发箱是EP1C6Q240C8,利用I2C总线对OV9650摄像头进行配置,I2C仿真的波形正常,但一下到硬件中,就出现问题。问题描述如下:只能发送LUT_INDEX=2时的寄存器地址和数据,也就是说SDA上的数据一直是60 11 81,且起始信号,响应信号,终止信号都正常!望各位大神指教啊!这个问题已经困扰小弟多时了!
源代码如下:
module I2C( // Host Side
iCLK,
iRST_N,
//iExposure,
// I2C Side
I2C_SCLK,
I2C_SDAT );
// Host Side
input iCLK;
input iRST_N;
//input [15:0] iExposure;
// I2C Side
output I2C_SCLK;
inout I2C_SDAT;
// Internal Registers/Wires
reg [15:0] mI2C_CLK_DIV;
reg [23:0] mI2C_DATA;
reg mI2C_CTRL_CLK;
reg mI2C_GO;
wire mI2C_END;
wire mI2C_ACK;
reg [15:0] LUT_DATA;
reg [5:0] LUT_INDEX;
reg [3:0] mSetup_ST;
// Clock Setting
parameter CLK_Freq = 48000000; // 50 MHz
parameter I2C_Freq = 20000; // 20 KHz
// LUT Data Number
parameter LUT_SIZE = 5;
///////////////////// I2C Control Clock ////////////////////////
always@(posedge iCLK or negedge iRST_N)
begin
if(!iRST_N)
begin
mI2C_CTRL_CLK <= 0;
mI2C_CLK_DIV <= 0;
end
begin
if( mI2C_CLK_DIV < (CLK_Freq/I2C_Freq) )
mI2C_CLK_DIV <= mI2C_CLK_DIV+1;
begin
mI2C_CLK_DIV <= 0;
mI2C_CTRL_CLK <= ~mI2C_CTRL_CLK;
end
end
end
I2C_Controller u0 ( .CLOCK(mI2C_CTRL_CLK), // Controller Work Clock
.I2C_SCLK(I2C_SCLK), // I2C CLOCK
.I2C_SDAT(I2C_SDAT), // I2C DATA
.I2C_DATA(mI2C_DATA), // DATA:[SLAVE_ADDR,SUB_ADDR,DATA]
.GO(mI2C_GO), // GO transfor
.END(mI2C_END), // END transfor
.ACK(mI2C_ACK), // ACK
.RESET(iRST_N) );
////////////////////// Config Control ////////////////////////////
always@(posedge mI2C_CTRL_CLK or negedge iRST_N)
begin
if(!iRST_N)
begin
LUT_INDEX <= 0;
mSetup_ST <= 0;
mI2C_GO <= 0;
end
begin
if(LUT_INDEX<LUT_SIZE)
begin
case(mSetup_ST)
0: begin
mI2C_DATA <= {8'h60,LUT_DATA};
mI2C_GO <= 1;
mSetup_ST <= 1;
end
1: begin
if(mI2C_END)
begin
if(!mI2C_ACK)
mSetup_ST <= 2;
mSetup_ST <= 0;
mI2C_GO <= 0;
end
end
2: begin
LUT_INDEX <= LUT_INDEX+1;
mSetup_ST <= 0;
end
endcase
end
end
end
///////////////////// Config Data LUT //////////////////////////
always
begin
case(LUT_INDEX)
0 : LUT_DATA <= 16'h1280;
1 : LUT_DATA <= 16'h1280;
2 : LUT_DATA <= 16'h1181; // Mirror Row and Columns
3 : LUT_DATA <= 16'h6b0a;// Exposure
4 : LUT_DATA <= 16'h3b01;
default:LUT_DATA <= 16'h0000;
endcase
end
endmodule
module I2C_Controller (
CLOCK,
I2C_SCLK,//I2C CLOCK
I2C_SDAT,//I2C DATA
I2C_DATA,//DATA:[SLAVE_ADDR,SUB_ADDR,DATA]
GO, //GO transfor
END, //END transfor
W_R, //W_R
ACK, //ACK
RESET,
//TEST
SD_COUNTER,
SDO
input CLOCK;
input [23:0]I2C_DATA;
input GO;
input RESET;
input W_R;
inout I2C_SDAT;
output I2C_SCLK;
output END;
output ACK;
//TEST
output [5:0] SD_COUNTER;
output SDO;
reg SDO;
reg SCLK;
reg END;
reg [23:0]SD;
reg [5:0]SD_COUNTER;
wire I2C_SCLK=SCLK | ( ((SD_COUNTER >= 4) & (SD_COUNTER <=30))? ~CLOCK :0 );
wire I2C_SDAT=SDO?1'bz:0 ;
reg ACK1,ACK2,ACK3;
wire ACK=ACK1 | ACK2 |ACK3;
//--I2C COUNTER
always @(negedge RESET or posedge CLOCK ) begin
if (!RESET) SD_COUNTER=6'b111111;
else begin
if (GO==0)
SD_COUNTER=0;
if (SD_COUNTER < 6'b111111) SD_COUNTER=SD_COUNTER+1;
end
end
if (!RESET) begin SCLK=1;SDO=1; ACK1=0;ACK2=0;ACK3=0; END=1; end
case (SD_COUNTER)
6'd0 : begin ACK1=0 ;ACK2=0 ;ACK3=0 ; END=0; SDO=1; SCLK=1;end
//start
6'd1 : begin SD=I2C_DATA;SDO=0;end
6'd2 : SCLK=0;
//SLAVE ADDR
6'd3 : SDO=SD[23];
6'd4 : SDO=SD[22];
6'd5 : SDO=SD[21];
6'd6 : SDO=SD[20];
6'd7 : SDO=SD[19];
6'd8 : SDO=SD[18];
6'd9 : SDO=SD[17];
6'd10 : SDO=SD[16];
6'd11 : begin SDO=1'b1;ACK1=I2C_SDAT;end//ACK
//SUB ADDR
6'd12 : SDO=SD[15]; //ACK1=I2C_SDAT; end
6'd13 : SDO=SD[14];
6'd14 : SDO=SD[13];
6'd15 : SDO=SD[12];
6'd16 : SDO=SD[11];
6'd17 : SDO=SD[10];
6'd18 : SDO=SD[9];
6'd19 : SDO=SD[8];
6'd20 : begin SDO=1'b1; ACK2=I2C_SDAT;end//ACK
//DATA
6'd21 : SDO=SD[7];// ACK2=I2C_SDAT; end
6'd22 : SDO=SD[6];
6'd23 : SDO=SD[5];
6'd24 : SDO=SD[4];
6'd25 : SDO=SD[3];
6'd26 : SDO=SD[2];
6'd27 : SDO=SD[1];
6'd28 : SDO=SD[0];
6'd29 : begin SDO=1'b1; ACK3=I2C_SDAT;end//ACK
//stop
6'd30 : begin SDO=1'b0; SCLK=1'b0; end
6'd31 : SCLK=1'b1;
6'd32 : begin SDO=1'b1; END=1; end
endcase
end
endmodule
