以下是Silicon Laboratories提供的example。 即依次对P2.0、P2.1、P2.2、P2.3、P2.5、P2.6的电压值进行采样,这样的话为什么在Port_Init()里把P2口配置为P2MDIN &= ~0x3F?不应该是P2MDIN &= ~0x6F吗??板子上的P2.5连接的是一电位器,采取P2MDIN &= ~0x3F的配置扭动电位器时P2.6(P2.6是悬空的)的值不会随电位器变化而变化;而改为P2MDIN &= ~0x6F后扭动电位器时P2.6的值也会随电位器的变化而变化??这是为什么呢??麻烦各位给看看这是怎么个情况!!
// F34x_ADC0_ExternalInput_Mux.c
// Copyright 2005 Silicon Laboratories, Inc.
// http://www.silabs.com
// This code example illustrates using the internal analog multiplexer to
// measure analog voltages on up to 8 different analog inputs. Results are
// printed to a PC terminal program via the UART.
// The inputs are sequentially scanned, beginning with input 0 (P2.0), up
// to input number <ANALOG_INPUTS>-1 based on the values in <PIN_TABLE>.
// ADC Settling Time Requirements, Sampling Rate:
// The total sample time per input is comprised of an input setting time
// (Tsettle), followed by a conversion time (Tconvert):
// Tsample = Tsettle + Tconvert
// Settling and conversion times may overlap, as the ADC holds the value once
// conversion begins. This program takes advantage of this to increase the
// settling time above the minimum required. In other words, when
// converting the value from analog input Ain(n), the input mux is switched
// over to the next input Ain(n+1) to begin settling.
// |---Settling Ain(n)---|=Conversion Ain(n)=|
// |---Settling Ain(n+1)---|=Conversion Ain(n+1)=|
// |---Settling Ain(n+2)---|
// ISR: Timer 2 ^ ^ ^
// ISR: ADC0 ^ ^
// The ADC input voltage must be allowed adequate time to settle before the
// conversion is made. This settling depends on the external source
// impedance, internal mux impedance, and internal capacitance.
// Settling time is given by:
// | 2^n |
// Tsettle = ln | --- | * Rtotal * Csample
// | SA |
// In this application, assume a 100kohm potentiometer as the voltage divider.
// The expression evaluates to:
// | 2^12 |
// Tsettle = ln | ---- | * 105e3 * 10e-12 = 10.2uS
// | 0.25 |
// In addition, one must allow at least 1.5 us after changing analog MUX
// inputs or PGA settings. The settling time in this example, then, is
// dictated by the large external source resistance.
// The conversion is 16 periods of the SAR clock. At 2.5 MHz,
// this time is 16 * 400nS = 6.4 uS.
// Tsample, minimum = Tsettle + Tconvert
// = 10.2uS + 6.4uS
// = 16.6 uS
// Timer2 is set to change the MUX input and start a conversion every 20 us.
// General:
// The system is clocked using the internal 12MHz oscillator. Results are
// printed to the UART from a loop with the rate set by a delay based on
// Timer0. This loop periodically reads the ADC value from a global array,
// <RESULT>.
// The ADC makes repeated measurements at 20 us intervals based on Timer2.
// The end of each ADC conversion initiates an interrupt which calls an
// averaging function. <INT_DEC> samples are averaged, then the Result
// values updated.
// For each power of 4 of <INT_DEC>, you gain 1 bit of effective resolution.
// For example, <INT_DEC> = 256 gain you 4 bits of resolution: 4^4 = 256.
// The ADC input multiplexer is set for a single-ended input. The example
// sequentially scans through the inputs, starting at P2.0. <ANALOG_INPUTS>
// inputs are read. The amplifier is set for unity gain so a voltage range of
// 0 to Vref (2.43V) may be measured. Although voltages up to Vdd may be
// applied without damaging the device, only the range 0 to Vref may be
// measured by the ADC.
// A 100 kohm potentiometer may be connected as a voltage divider between
// VREF and AGND as shown below:
// o| AGND ----|
// o| VREF ----|<-|
// o| P2.x | |
// o| | |
// o| --------
// o|
// o|
// o|
// How To Test:
// 1) Download code to a 'F34x device that is connected to a UART transceiver
// 2) Verify the TX and RX jumpers are populated on J3.
// 3) Connect a serial cable from the DB9 connector to a PC
// 4) On the PC, open HyperTerminal (or any other terminal program) and connect
// to the COM port at <BAUDRATE> and 8-N-1
// 5) Connect a variable voltage source (between 0 and Vref) to the Port2 pins,
// or a potentiometer voltage divider as shown above.
// 6) HyperTerminal will print the voltages measured by the device if
// everything is working properly. Note that some of the analog inputs are
// floating and will return nonzero values.
// FID: 34X000092
// Target: C8051F34x
// Tool chain: Keil C51 7.50 / Keil EVAL C51
// Command Line: None
// Release 1.0
// -Initial Revision (SM / TP)
// -19 OCT 2006
// Includes
#include <C8051F340.h> // SFR declarations
#include <stdio.h>
// 16-bit SFR Definitions for 'F34x
sfr16 TMR2RL = 0xCA; // Timer2 reload value
sfr16 TMR2 = 0xCC; // Timer2 counter
sfr16 ADC0 = 0xBD; // 10-bit ADC0 result
// Global CONSTANTS
#define SYSCLK 12000000 // SYSCLK frequency in Hz
#define BAUDRATE 115200 // Baud rate of UART in bps
#define ANALOG_INPUTS 6 // Number of AIN pins to measure,
// skipping the UART0 pins
#define INT_DEC 256 // Integrate and decimate ratio
#define TIMER0_RELOAD_HIGH 0 // Timer0 High register
#define TIMER0_RELOAD_LOW 255 // Timer0 Low register
// Function PROTOTYPES
void Oscillator_Init (void);
void Port_Init (void);
void Timer2_Init(void);
void ADC0_Init(void);
void UART0_Init (void);
void Timer0_wait(int ms);
// Global Variables
long RESULT[ANALOG_INPUTS]; // ADC0 decimated value, one for each
// analog input
// The <PIN_MUX_TABLE> values are the values to be written to the AMX0P
// register to select the P2.<PIN_TABLE> port pins.
// For the 'F340, the AMX0P settings correspond to the following port pins:
// AMX0P Port Pin
// 0x00 P2.0
// 0x01 P2.1
// 0x02 P2.2
// 0x03 P2.3
// 0x04 P2.5
// 0x05 P2.6
unsigned char idata PIN_TABLE[ANALOG_INPUTS] = {0,1,2,3,5,6};
unsigned char idata PIN_MUX_TABLE[ANALOG_INPUTS] = {0,1,2,3,4,5};
unsigned char AMUX_INPUT = 0; // Index of analog MUX inputs
// MAIN Routine
void main (void)
unsigned char i;
unsigned long measurement;
PCA0MD &= ~0x40; // WDTE = 0 (clear watchdog timer
// enable)
Oscillator_Init (); // Initialize system clock to
// 12MHz
Port_Init (); // Initialize crossbar and GPIO
Timer2_Init(); // Init Timer2 to generate
// overflows to trigger ADC
UART0_Init(); // Initialize UART0 for printf's
ADC0_Init(); // Initialize ADC0
EA = 1; // Enable global interrupts
while (1)
EA = 0; // Disable interrupts
printf("\f");
for(i = 0; i < ANALOG_INPUTS; i++)
// The 10-bit ADC value is averaged across INT_DEC measurements.
// The result is then stored in RESULT, and is right-justified
// The measured voltage applied to the port pins is then:
// Vref (mV)
// measurement (mV) = --------------- * Result (bits)
// (2^10)-1 (bits)
measurement = RESULT * 2430 / 1023;
printf("P2.%bu voltage: %4ld mV\n",PIN_TABLE,measurement);
EA = 1; // Re-enable interrupts
Timer0_wait(25); // Wait before displaying new values
// Initialization Subroutines
// SYSCLK_Init
// Return Value : None
// Parameters : None
// This routine initializes the system clock to use the internal 12MHz
// oscillator as its clock source. Also enables missing clock detector reset.
OSCICN = 0x83; // Configure internal oscillator for
// its highest frequency
RSTSRC = 0x04; // Enable missing clock detector
// Port_Init
// Configure the Crossbar and GPIO ports.
// P0.4 - UART TX (push-pull)
// P0.5 - UART RX
// P1.5 - analog (VREF)
// P2.0 - analog input (ADC0)
// P2.1 - analog input (ADC0)
// P2.2 - analog input (ADC0)
// P2.3 - analog input (ADC0)
// P2.5 - analog input (ADC0)
// P2.6 - analog input (ADC0)
P2SKIP = 0x3F; // Skip all analog pins
XBR0 = 0x01; // UART0 TX and RX pins enabled
XBR1 = 0x40; // Enable crossbar and weak pull-ups
P0MDOUT |= 0x10; // Enable TX0 as a push-pull output
P1MDIN &= ~0x20; // P1.5 in analog mode
P2MDIN &= ~0x3F; // Set desired pins as analog inputs
// Timer2_Init
// Configure Timer2 to 16-bit auto-reload and generate an interrupt at 10 us
// intervals. Timer2 overflows automatically triggers ADC0 conversion.
void Timer2_Init (void)
TMR2CN = 0x00; // Stop Timer2; Clear TF2;
// use SYSCLK as timebase, 16-bit
// auto-reload
CKCON |= 0x10; // Select SYSCLK for timer 2 source
TMR2RL = 65535 - (SYSCLK / 10000); // Init reload value for 10 us
TMR2 = 0xffff; // Set to reload immediately
ET2 = 1; // Enable Timer2 interrupts
TR2 = 1; // Start Timer2
// ADC0_Init
// Configures ADC0 to make single-ended analog measurements on Port 2 according
// to the values of <ANALOG_INPUTS> and <PIN_TABLE>.
void ADC0_Init (void)
ADC0CN = 0x02; // ADC0 disabled, normal tracking,
// conversion triggered on TMR2 overflow
REF0CN = 0x03; // Enable internal VREF
AMX0P = PIN_MUX_TABLE[0]; // ADC0 initial positive input = P2.0
AMX0N = 0x1F; // ADC0 negative input = GND
// i.e., single ended mode
ADC0CF = ((SYSCLK/3000000)-1)<<3; // Set SAR clock to 3MHz
ADC0CF |= 0x00; // Right-justify results
EIE1 |= 0x08; // Enable ADC0 EOC interrupt
AD0EN = 1; // Enable ADC0
// UART0_Init
// Configure the UART0 using Timer1, for <BAUDRATE> and 8-N-1.
SCON0 = 0x10; // SCON0: 8-bit variable bit rate
// level of STOP bit is ignored
// RX enabled
// ninth bits are zeros
// clear RI0 and TI0 bits
if (SYSCLK/BAUDRATE/2/256 < 1) {
TH1 = -(SYSCLK/BAUDRATE/2);
CKCON |= 0x08; // T1M = 1; SCA1:0 = xx
} else if (SYSCLK/BAUDRATE/2/256 < 4) {
TH1 = -(SYSCLK/BAUDRATE/2/4);
CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 01
CKCON |= 0x01;
} else if (SYSCLK/BAUDRATE/2/256 < 12) {
TH1 = -(SYSCLK/BAUDRATE/2/12);
CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 00
} else if (SYSCLK/BAUDRATE/2/256 < 48) {
TH1 = -(SYSCLK/BAUDRATE/2/48);
CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 10
CKCON |= 0x02;
} else {
while (1); // Error. Unsupported baud rate
TL1 = TH1; // Init Timer1
TMOD &= ~0xF0; // TMOD: timer 1 in 8-bit autoreload
TMOD |= 0x20;
TR1 = 1; // START Timer1
TI0 = 1; // Indicate TX0 ready
// Interrupt Service Routines
// Timer2_ISR
// This routine changes to the next Analog MUX input whenever Timer2 overflows
// for the next ADC sample. This allows the ADC to begin setting on the new
// input while converting the old input.
void Timer2_ISR (void) interrupt 5
TF2H = 0; // Clear Timer2 interrupt flag
// Set up the AMUX for the next ADC input
// ADC0 positive input = P2.<PIN_TABLE[AMUX_INPUT+1]>
if (AMUX_INPUT == (ANALOG_INPUTS - 1))
AMX0P = PIN_MUX_TABLE[AMUX_INPUT+1];
// ADC0_ISR
// This ISR averages <INT_DEC> samples for each analog MUX input then prints
// the results to the terminal. The ISR is called after each ADC conversion,
// which is triggered by Timer2.
void ADC0_ISR (void) interrupt 10
static unsigned int_dec = INT_DEC; // Integrate/decimate counter
// A new result is posted when
// int_dec is 0
// Integrate accumulator for the ADC samples from input pins
static long accumulator[ANALOG_INPUTS] = 0x00000000;
unsigned char i; // Loop counter
AD0INT = 0; // Clear ADC conversion complete
// overflow
accumulator[AMUX_INPUT] += ADC0; // Read the ADC value and add it to the
// running total
// Reset sample counter <int_dec> and <AMUX_INPUT> if the final input was
// just read
if(AMUX_INPUT == (ANALOG_INPUTS - 1))
int_dec--; // Update decimation counter
// when the last of the analog inputs
// is sampled
if (int_dec == 0) // If zero, then post the averaged
{ // results
int_dec = INT_DEC; // Reset counter
// Copy each averaged ADC0 value into the RESULT array
// Copy averaged values into RESULT
RESULT = accumulator / int_dec;
// Reset accumulators
accumulator = 0x00000000;
AMUX_INPUT = 0; // Reset input index back to P2.0
// Otherwise, increment the AMUX channel counter
AMUX_INPUT++; // Step to the next analog mux input
// Support Subroutines
// Timer0_Init
// Parameters :
// 1) int ms - number of milliseconds to wait
// range is positive range of an int: 0 to 32767
// This function configures the Timer0 as a 16-bit timer, interrupt enabled.
// Using the internal osc. at 12MHz with a prescaler of 1:8 and reloading the
// T0 registers with TIMER0_RELOAD_HIGH/LOW, it will wait for <ms>
// milliseconds.
// Note: The Timer0 uses a 1:12 prescaler
TH0 = TIMER0_RELOAD_HIGH; // Init Timer0 High register
TL0 = TIMER0_RELOAD_LOW ; // Init Timer0 Low register
TMOD |= 0x01; // Timer0 in 16-bit mode
CKCON &= 0xFC; // Timer0 uses a 1:12 prescaler
TR0 = 1; // Timer0 ON
while(ms)
TF0 = 0; // Clear flag to initialize
while(!TF0); // Wait until timer overflows
ms--; // Decrement ms
TR0 = 0; // Timer0 OFF
// End Of File
