i2c的头文件如下(只有几个函数式没有具体代码),想调用包含一下 I2C.H 能行吗,还是要自己写?如果需要自己写那它的头文件还有什么用。
CodeVisionAVR C Compiler
(C) 1998-2000 Pavel Haiduc, HP InfoTech S.R.L.
Prototypes for I2C bus master functions
BEFORE #include -ING THIS FILE YOU
MUST DECLARE THE I/O ADDRESS OF THE
DATA REGISTER OF THE PORT AT WHICH
THE I2C BUS IS CONNECTED AND
THE DATA BITS USED FOR SDA & SCL
EXAMPLE FOR PORTB:
#asm
.equ __i2c_port=0x18
.equ __sda_bit=3
.equ __scl_bit=4
#endasm
#include <i2c.h>
#ifndef _I2C_INCLUDED_
#define _I2C_INCLUDED_
#pragma used+
void i2c_init(void);
unsigned char i2c_start(void);
void i2c_stop(void);
unsigned char i2c_read(unsigned char ack);
unsigned char i2c_write(unsigned char data);
#pragma used-
