MWC中ADXL345的速率选的很低- void ACC_init () {
- delay(10);
- i2c_writeReg(ADXL345_ADDRESS,0x2D,1<<3); // register: Power CTRL -- value: Set measure bit 3 on
- i2c_writeReg(ADXL345_ADDRESS,0x31,0x0B); // register: DATA_FORMAT -- value: Set bits 3(full range) and 1 0 on (+/- 16g-range)
- i2c_writeReg(ADXL345_ADDRESS,0x2C,0x09); // register: BW_RATE -- value: rate=50hz, bw=20hz
- acc_1G = 265;
复制代码 是不是这样有利于滤波?
是不是加速度计返回的是在两个读取数据时间之间的加速度平均值? |
