发表于 2012-11-23 20:00:04
maxims 发表于 2012-11-22 22:12 ![](static/image/common/back.gif)
这些或许对你有用。。。我记忆中,只能找到这些了,梅树派的论坛,好像有3个主要的,上边很多资料 ...
没有DSI接口
1.1 Overview
BCM2835 contains the following peripherals which may safely be accessed by the ARM:
• Timers
• Interrupt controller
• GPIO
• USB
• PCM / I2S
• DMA controller
• I2C master
• I2C / SPI slave
• SPI0, SPI1, SPI2
• PWM
• UART0, UART1
The purpose of this datasheet is to provide documentation for these peripherals in sufficient
detail to allow a developer to port an operating system to BCM2835.
There are a number of peripherals which are intended to be controlled by the GPU. These are
omitted from this datasheet. Accessing these peripherals from the ARM is not recommended. |
