发表于 2012-10-17 20:26:08
gamalot 发表于 2012-10-17 20:14 ![](static/image/common/back.gif)
我很想知道什么是“广域C语言参数传递”
看懂了,是“关于”吧 ......
#include<reg52.h>
#include"LCD.h"
#define uint unsigned int
sbit CS = P3^2;
sbit RES = P0^1;
sbit A0 = P3^3;
sbit l_scl = P2^3;
sbit l_sda = P2^2;
extern h_tem,l_tem;
extern table1[16],tempdata[2];
uchar table[7],result1,result2;
uchar code shuzi[]=
/*-- 文字: 0 --*/
0xF8,0x04,0x04,0x04,0xF8,0x00,0x01,0x02,0x02,0x02,0x01,0x00,
/*-- 文字: 1 --*/
0x00,0x08,0xFC,0x00,0x00,0x00,0x00,0x02,0x03,0x02,0x00,0x00,
/*-- 文字: 2 --*/
0x18,0x84,0x44,0x24,0x18,0x00,0x03,0x02,0x02,0x02,0x02,0x00,
/*-- 文字: 3 --*/
0x08,0x04,0x24,0x24,0xD8,0x00,0x01,0x02,0x02,0x02,0x01,0x00,
/*-- 文字: 4 --*/
0x40,0xB0,0x88,0xFC,0x80,0x00,0x00,0x00,0x00,0x03,0x02,0x00,
/*-- 文字: 5 --*/
0x3C,0x24,0x24,0x24,0xC4,0x00,0x01,0x02,0x02,0x02,0x01,0x00,
/*-- 文字: 6 --*/
/*-- 宋体9; 此字体下对应的点阵为:宽x高=6x12 --*/
/*-- 高度不是8的倍数,现调整为:宽度x高度=6x16 --*/
0xF8,0x24,0x24,0x2C,0xC0,0x00,0x01,0x02,0x02,0x02,0x01,0x00,
/*-- 文字: 7 --*/
0x0C,0x04,0xE4,0x1C,0x04,0x00,0x00,0x00,0x03,0x00,0x00,0x00,
/*-- 文字: 8 --*/
0xD8,0x24,0x24,0x24,0xD8,0x00,0x01,0x02,0x02,0x02,0x01,0x00,
/*-- 文字: 9 --*/
0x38,0x44,0x44,0x44,0xF8,0x00,0x00,0x03,0x02,0x02,0x01,0x00,
void LCD_write_dat(uchar dat) //写数据
uchar i;
CS = 0;
A0 = 1;
for(i = 0;i<8;i++)
if(0x80 == (dat&0x80))
l_sda = 1;
else l_sda = 0;
dat = dat<<1;
l_scl = 0;
l_scl = 1;
CS = 1;
void LCD_write_com(uchar com) //写命令
uchar i;
CS = 0;
A0 = 0;
for(i = 0;i<8;i++)
if(0x80 == (com&0x80))
l_sda = 1;
else l_sda = 0;
com = com<<1;
l_scl = 0;
l_scl = 1;
CS = 1;
void LCD_add(uchar x,y) //写命令
LCD_write_com(0xb0|y);
x = x+4;
LCD_write_com(x>>4|0x10); //要写两次地址
LCD_write_com(x&0x0f);
void w_shuzi(uchar x,uchar y,uchar zz)
uchar i,z;
z = zz;
LCD_add(x*6,y);
for(i = 0;i<6;i++)
LCD_write_dat(shuzi[z*12+i]);
LCD_add(x*6,y+1);
for(i = 6;i<12;i++)
void LCD_qingping(uchar aa)
uchar page,j;
for(page = 0;page<8;page++)
for(j = 0;j<128;j++)
LCD_add(j,page);
LCD_write_dat(aa);
void delay_1(uint z)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<148;y++);
void LCD_init()
// CS=0;
// res();
/* LCD_write_com(0xA2); //LCD偏压设置,V3时选--LCD Bias selection(1/65 Duty,1/9Bias)
LCD_write_com(0xA1); //Segment方向选择,正常--ADC selection(SEG0->SEG128)
LCD_write_com(0x80); //设置显示起始行对应RAM--SHL selection(COM0->COM64)
delay(5);
LCD_write_com(0x26); //设置Rb/Ra=6--Regulator Resistor Selection
LCD_write_com(0x81); //电量设置模式(显示亮度)--Electronic Volume
LCD_write_com(0x08); //Reference Register selection Vo=(1+Rb/Ra)(1+a)*2.1=10
delay(10);
LCD_write_com(0x2f); //设置上电控制模式--Power Control(Vc=1;Vr=1;Vf=1)
delay(10);
LCD_write_com(0xF8); //升压比设置
LCD_write_com(0x00);
delay(5);
LCD_write_com(0xAF); //LCD显示开--Display on
delay(5);
LCD_write_com(0xa4);*/
LCD_write_com(0xaf); //开关指令
LCD_write_com(0x40); //读状态设置
LCD_write_com(0xa1); //ADC选择
LCD_write_com(0xa6); //正向显示
LCD_write_com(0xa2); //偏压比设置
LCD_write_com(0xa4); //全屏点亮设置
LCD_write_com(0xe0); //读写操作
LCD_write_com(0xc0); //COM口正常方向扫描
LCD_write_com(0x2f); //上电控制
LCD_write_com(0x23); //电阻控制
LCD_write_com(0x3f); //电量控制
LCD_write_com(0x81); //电量控制
LCD_write_com(0xad); //静态指示器关 */
void xianshi()
char i;
// xs(tempdata[1],4,4);
xs(tempdata[0],0,0);
for(i = 0;i<8;i++)
// w_shuzi(i,0,table1[i+8]);
w_shuzi(i,2,table1);
void xs(uchar dd,uchar i,uchar k) //结果显示函数,dd 要显示的函数,k显示的列数位置,i显示行数位置
uint temp4,temp5,shu[20];
char j = 0;
if(dd<10)
w_shuzi(k,i,0);
w_shuzi(k+1,i,dd);
while(dd)
temp4 = dd/10;
temp5 = dd%10;
shu[j++] = temp5;
dd = temp4;
for(--j;j>=0;j--)
w_shuzi(k++,i,shu[j]);
