最近在调24L01的多对一通信,在调试过程中第一第二路可以调通,实现正常的无线通信,但是第三、四、五、六路就一直调不通,按资料手册上说是只要发射和接收的地址一致就可以,但是很奇怪一换到第三、四、五、六路地址通信就不行了,很是不解,想问下各位大神问题出在哪里?或者求指教24L01的多对一通信应该如何设置。
真心求教,万分感激!
附上我的程序地址码部分:
//PI 0
uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address
//PI 1
uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0xc2,0xc2,0xc2,0xc2,0xc1};// Define a static TX address
//PI 2
//uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0xc2,0xc2,0xc2,0xc2,0xc2};// Define a static TX address
//PI 3
//uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0xc2,0xc2,0xc2,0xc2,0xc3};// Define a static TX address
//PI 4
//uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0xc2,0xc2,0xc2,0xc2,0xc4};// Define a static TX address
//PI 5
//uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0xc2,0xc2,0xc2,0xc2,0xc5};// Define a static TX address
uchar const RxAddr0[5] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address
uchar const RxAddr1[5] = {0xc2,0xc2,0xc2,0xc2,0xc1};
uchar const RxAddr2[5] = {0xc2,0xc2,0xc2,0xc2,0xc2};
uchar const RxAddr3[5] = {0xc2,0xc2,0xc2,0xc2,0xc3};
uchar const RxAddr4[5] = {0xc2,0xc2,0xc2,0xc2,0xc4};
uchar const RxAddr5[5] = {0xc2,0xc2,0xc2,0xc2,0xc5};
void RX_Mode(void)
CE=0;
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // Enable Pipe0
SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40
SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:RX. RX_DR enabled..
CE = 1; // Set CE pin high to enable RX device
void TX_Mode(void)
CE=0;
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // Writes TX_Address to nRF24L01
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as TX_Adr for Auto.Ack
SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // Writes data to TX payload
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled..
CE=1;
