发表于 2012-10-16 11:29:51
40342zz 发表于 2012-10-16 11:22
IIC延时可以适当减少甚至去掉
我觉得可能是某些细节地方设置不对,现在函数是这样子的:
void I2C_delay(void)
__nop(); __nop();
已经很简单了,但是还是那个问题,我正在检查...
另外模拟iic程序是淘宝买东西附带的,百度也有:(能读数,就是太慢,我正在看时钟配置对不对)
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_delay();
if(!SDA_read)return FALSE; //SDA线为低电平则总线忙,退出
SDA_L;
I2C_delay();
if(SDA_read) return FALSE; //SDA线为高电平则总线出错,退出
SDA_L;
I2C_delay();
return TRUE;
void I2C_Ack(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
void I2C_NoAck(void)
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
bool I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
SCL_L;
I2C_delay();
return FALSE;
SCL_L;
I2C_delay();
return TRUE;
void I2C_SendByte(u8 SendByte) //数据从高位到低位
u8 i=8;
while(i--)
SCL_L;
I2C_delay();
if(SendByte&0x80)
SDA_H;
SDA_L;
SendByte<<=1;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
unsigned char I2C_RadeByte(void) //数据从高位到低位
u8 i=8;
u8 ReceiveByte=0;
SDA_H;
while(i--)
ReceiveByte<<=1;
SCL_L;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
ReceiveByte|=0x01;
SCL_L;
return ReceiveByte;
bool Single_Write(unsigned char SlaveAddress,unsigned char REG_Address,unsigned char REG_data)
if(!I2C_Start())return FALSE;
I2C_SendByte(SlaveAddress); //发送设备地址+写信号//I2C_SendByte(((REG_Address & 0x0700) >>7) | SlaveAddress & 0xFFFE);//设置高起始地址+器件地址
if(!I2C_WaitAck()){I2C_Stop(); return FALSE;}
I2C_SendByte(REG_Address ); //设置低起始地址
I2C_WaitAck();
I2C_SendByte(REG_data);
I2C_WaitAck();
I2C_Stop();
delay5ms();
return TRUE;
unsigned char Single_Read(unsigned char SlaveAddress,unsigned char REG_Address)
{ unsigned char REG_data;
I2C_SendByte(SlaveAddress); //I2C_SendByte(((REG_Address & 0x0700) >>7) | REG_Address & 0xFFFE);//设置高起始地址+器件地址
if(!I2C_WaitAck()){I2C_Stop();test=1; return FALSE;}
I2C_SendByte((u8) REG_Address); //设置低起始地址
I2C_WaitAck();
I2C_Start();
I2C_SendByte(SlaveAddress+1);
I2C_WaitAck();
REG_data= I2C_RadeByte();
I2C_NoAck();
I2C_Stop();
//return TRUE;
return REG_data;
