发表于 2012-10-4 09:49:27
这不是郭天祥的程序吗 自己对比。。。
#include<reg52.h>
#define uint unsigned int
sbit lcdrs=P3^4;
sbit lcden=P3^7;
sbit lcdrw=P3^6;
sbit K4=P2^3;
sbit s1=P2^7;
sbit s2=P2^6;
sbit s3=P2^5;
sbit a1=P1^0;
sbit a2=P1^1;
sbit a3=P1^2;
sbit a4=P1^3;
sbit a5=P1^4;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]=" 2011-06-17 MON";
sbit sda=P1^6;
sbit scl=P1^5;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=120;y>0;y--);
void delay0() //微妙延迟函数
void start() //开始信号
sda=1;
delay0();
scl=1;
delay0();
sda=0;
delay0();
void stop() //停止
sda=0;
delay0();
scl=1;
delay0();
sda=1;
delay0();
void respons() //应答
uchar i;
scl=1;
delay0();
while((sda==1)&&(i<250))i++;
scl=0;
delay0();
void init_24c02() //I2C初始化函数
sda=1;
delay0();
scl=1;
delay0();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay0();
sda=CY;
delay0();
scl=1;
delay0();
scl=0;
delay0();
sda=1;
delay0();
uchar read_byte()
uchar i,k;
scl=0;
delay0();
sda=1;
delay0();
for(i=0;i<8;i++)
scl=1;
delay0();
k=(k<<1)|sda;
scl=0;
delay0();
return k;
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
void write_com(uchar com)
lcdrs=0;
lcdrw=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
lcdrs=1;
lcdrw=0;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void init() //初始化函数
uchar num;
K4=0;
a1=a2=a3=a4=a5=0;
lcden=0;
fen=0;
miao=0;
shi=0;
count=0;
s1num=0;
init_24c02();
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40+6);
write_date(':');
delay(5);
write_com(0x80+0x40+9);
write_date(':');
delay(5);
miao=read_add(1);
fen=read_add(2);
shi=read_add(3);
write_sfm(10,miao);
write_sfm(7,fen);
write_sfm(4,shi);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void keyscan() //按键扫描函数
if(s1==0)
delay(5);
if(s1==0)
{ s1num++;
while(!s1);
if(s1num==1)
TR0=0;
write_com(0x80+0x40+10);
write_com(0x0f);
if(s1num==2)
write_com(0x80+0x40+7);
if(s1num==3)
write_com(0x80+0x40+4);
if(s1num==4)
s1num=0;
write_com(0x0c);
TR0=1;
if(s1num!=0)
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
if(s1num==1)
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
write_add(1,miao); //数据改变立即存入24c02
if(s1num==2)
fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
write_add(2,fen); //数据改变立即存入24c02
if(s1num==3)
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_add(3,shi); //数据改变立即存入24c02
if(s3==0)
delay(5);
if(s3==0)
while(!s3);
if(s1num==1)
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
if(s1num==2)
fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
if(s1num==3)
shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
void main()
init();
keyscan();
void timer0() interrupt 1
count++;
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
