回复: 39
led心形流水灯程序(含各种效果应有尽有)
发表于 2012-10-1 13:55:03 | 显示全部楼层 |阅读模式
功能:改程序包含积点效果,顺、逆时针逐个点亮,顺、逆时针逐个
熄灭,对角亮灭,交叉亮灭,顺、逆时针逐段点亮,顺、逆时针逐段
熄灭等各种效果
连接线路为:P0^7-P0^0接灯1-8   //p0口接线与芯片引脚顺序相反方便焊接
            P1^0-P1^7接灯9-16        //其余引脚相同
                        P3^0-P3^7接灯17-24
                        P2^0-P2^7接灯25-32
#include<reg52.h>
#include <intrins.h>
#define        uint unsigned int
#define        uchar unsigned char
void delay(uint t);                                //延时
void zg(uint t,uchar a);                    //两边逐个亮
void qs(uint t,uchar a);                    //全部闪烁
void zgxh(uint t,uchar a);                  //逆时针逐个点亮
void zgxh1(uint t,uchar a);                 //顺时针逐个点亮
void djs(uint t,uchar a);                   //对角闪
void lbzgm(uint t,uchar a);                  //两边逐个灭
void sszgm(uint t,uchar a);                  // 顺时针逐个灭
void nszgm(uint t,uchar a);                 // 逆时针逐个灭
void sztl(uint t,uchar a);                  //顺时逐个同步亮
void nztl(uint t,uchar a);                   //逆时逐个同步亮
void sztm(uint t,uchar a);                  //顺时逐个同步灭
void nztm(uint t,uchar a);                  //逆时逐个同步灭
void hwzjl(uint t,uchar a);                 //横往中间亮
void hwzjm(uint t,uchar a);                  //横往中间灭
void nzdl(uint t,uchar a);                   //逆时逐段亮
void nzdgl(uint t,uchar a);                  //逆时逐段一个点亮
void jgs(uint t,uchar a);                    //间隔闪
uchar code table[]={0xfe,0xfc,0xf8,0xf0,
0xe0,0xc0,0x80,0x00};                         // 逐个点亮0~7
uchar code table1[]={0x7f,0x3f,0x1f,0x0f,
0x07,0x03,0x01,0x00};                         // 逐个点亮7~0
uchar code table2[]={0x01,0x03,0x07,0x0f,
0x1f,0x3f,0x7f,0xff};                          // 逐个灭0~7
uchar code table3[]={0x80,0xc0,0xe0,0xf0,
0xf8,0xfc,0xfe,0xff};                           // 逐个灭7~0
uint code display_P0[]={
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7E,      //P0--》P3逐个堆积点亮部分的P0 堆积点亮
0x7D,0x7B,0x77,0x6F,0x5F,0x3F,0x3F,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
0x1E,0x1D,0x1B,0x17,0x0F,
0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
0x0E,0x0D,0x0B,0x07,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x06,0x05,0x03,
0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
0x02,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x00,0x00,0x00,
0x00,0x00,
                     //P0 口显示内容
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
/*0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,*/
uint code display_P1[]={
0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,
0x7E,0xBE,0xDE,0xEE,0xF6,0xFA,0xFC,
0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,
0x7C,0xBC,0xDC,0xEC,0xF4,0xF8,
0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,
0x78,0xB8,0xD8,0xE8,0xF0,
0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,
0x70,0xB0,0xD0,0xE0,
0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,
0x60,0xA0,0xC0,
0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
0x40,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,   */
uint code display_P2[]={
0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,           //P0--》P3逐个堆积点亮部分的P0 流水点亮
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,           //P0  全灭等待        0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7E,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,      //P0--》P3逐个堆积点亮部分的P0 堆积点亮
0x60,0xA0,0xC0,
0x40,0x80,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,                       //P0 亮灭闪烁
0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,    //P0--》P3间隔点亮部分的P0 1,3,5,7 亮。2,4,6,8灭
uint code display_P3[]={
0x7F,0xBF,0xDF,        0xEF,0xF7,0xFB,0xFD,0xFE,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0x60,0xA0,0xC0,
0x40,0x80,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
void zg(uint t,uchar a)//两边逐个亮
        uchar i,j;
      for(j=0;j<a;j++)
                   P0=P1=P2=P3=0xff;
                  P0=0x7f;delay(t);
                  for(i=0;i<7;i++)
                  P0=table1[i+1];
                  P2=table1;
                  delay(t);
                  P2=0x00;P1=0xfe;
                  delay(t);
                  for(i=0;i<7;i++)
                          P1=table[i+1];
                        P3=table1;
                        delay(t);
                  P3=0x00;delay(t);
void qs(uint t,uchar a)         //全部闪烁
        uchar j;
        for(j=0;j<a;j++)
           P0=P1=P2=P3=0xff;
           delay(t);
           P0=P1=P2=P3=0x00;
           delay(t);
void zgxh(uint t,uchar a)  // 逆时针逐个点亮
        uchar i,j;
        for (j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for (i=0;i<8;i++)
                        P0=table1;
                        delay(t);
                for(i=0;i<8;i++)
                        P1=table;
                        delay(t);
                for(i=0;i<8;i++)
                        P3=table;
                        delay(t);
                for(i=0;i<8;i++)
                        P2=table;
                        delay(t);
void nszgm(uint t,uchar a) // 逆时针逐个灭
        uchar i,j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0x00;
                for (i=0;i<8;i++)
                        P0=table3;delay(t);
                for (i=0;i<8;i++)
                        P1=table2;delay(t);
                for (i=0;i<8;i++)
                        P3=table2;delay(t);
                for (i=0;i<8;i++)
                        P2=table2;delay(t);
void djs(uint t,uchar a)  //对角闪
        uchar j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                P0=P3=0x00;
                delay(t);
                P0=P1=P2=P3=0xff;
                P1=P2=0x00;
                delay(t);
void lbzgm(uint t,uchar a)//两边逐个灭
          uchar i,j;
          for (j=0;j<a;j++)
                  P0=P2=0x00;
                P3=0x01;delay(t);
                for(i=7;i>1;i--)
                        P1=table[i-1];P3=table1[i-2];
                        delay(t);
                P1=0xfe;P3=0xff;delay(t);
                P1=0xff;P2=0x01;delay(t);
                for(i=7;i>1;i--)
                        P0=table1[i-1];
                        P2=table1[i-2];
                        delay(t);
                P0=0x7f;P2=0xff;delay(t);
                P0=0xff;delay(t);
void sztl(uint t,uchar a)//顺时逐个同步亮
        uchar i,j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for(i=0;i<8;i++)
                        P0=table;
                        P1=P2=P3=table1;
                        delay(t);
void nztl(uint t,uchar a)//逆时逐个同步亮
        uchar i,j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for(i=0;i<8;i++)
                        P0=table1;
                        P1=P2=P3=table;
                        delay(t);
void sztm(uint t,uchar a)//顺时逐个同步灭
        uchar i,j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0x00;
                for(i=0;i<8;i++)
                        P0=table2;
                        P1=P2=P3=table3;
                        delay(t);
void nztm(uint t,uchar a)//逆时逐个同步灭
        uchar i,j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for(i=0;i<8;i++)
                        P0=table3;
                        P1=P2=P3=table2;
                        delay(t);
void hwzjl(uint t,uchar a) //横往中间亮
        uchar i,j;
        for (j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for(i=0;i<8;i++)
                        P0=P2=P1=table1;
                        P3=table;delay(t);
void hwzjm(uint t,uchar a) //横往中间灭
        uchar i,j;
        for (j=0;j<a;j++)
                P0=P1=P2=P3=0x00;
                for(i=0;i<8;i++)
                        P0=P2=P1=table3;
                        P3=table2;delay(t);
void nzdl(uint t,uchar a) //逆时逐段亮
        uchar i,j;
        for (j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for(i=0;i<8;i++)
                        P0=table1;
                        delay(t);
                P0=0xff;
                for(i=0;i<8;i++)
                        P1=table;
                        delay(t);
                P1=0xff;
                for(i=0;i<8;i++)
                        P3=table;
                        delay(t);
                P3=0xff;
                for(i=0;i<8;i++)
                        P2=table;
                        delay(t);
                P2=0xff;
void nzdgl(uint t,uchar a)   //逆时逐段一个点亮
        uchar i,j,k,l;
        for (j=0;j<a;j++)
                k=table1[0];
                P0=k;l=table[0];
                P1=P2=P3=l;delay(t);
                for(i=0;i<8;i++)
                        k=_crol_(k,-1);
                        P0=k;
                        l=_crol_(l,1);
                        P1=P2=P3=l;
                        delay(t);
void jgs(uint t,uchar a)   //间隔闪
        uchar j;
        for (j=0;j<a;j++)
                P0=0x55;P1=P2=P3=0xaa;
                delay(t);
                P0=0xaa;P1=P2=P3=0x55;
                delay(t);
void sszgm(uint t,uchar a) // 顺时针逐个灭
        uchar i,j;
        for(j=0;j<a;j++)
                P0=P1=P2=P3=0x00;
                for (i=0;i<8;i++)
                        P2=table3;delay(t);
                for (i=0;i<8;i++)
                        P3=table3;delay(t);
                for (i=0;i<8;i++)
                        P1=table3;delay(t);
                for (i=0;i<8;i++)
                        P0=table2;delay(t);
void zgxh1(uint t,uchar a)  //顺时针逐个亮
uchar i,j;
        for (j=0;j<a;j++)
                P0=P1=P2=P3=0xff;
                for (i=0;i<8;i++)
                        P2=table1;
                        delay(t);
                for(i=0;i<8;i++)
                        P3=table1;
                        delay(t);
                for(i=0;i<8;i++)
                        P1=table1;
                        delay(t);
                for(i=0;i<8;i++)
                        P0=table;
                        delay(t);
void delayms(uint ms)                                //延时子程序
  uint k;
  while(ms--)
    for(k = 0; k <100; k++);
void delay(uint t)
        uint x,y;
        for (x=t;x>0;x--)
                for (y=120;y>0;y--);
void main()
        uint g,i;
         zg(100,1);                         //两边逐个亮
         lbzgm(100,1);                 //两边逐个灭
         jgs(300,10);
         djs(100,20);        //对角闪
        for(g=0;g<546; g++)   //积点效果
       P2 =display_P2[g];
       P3 =display_P3[g];
           P1 =display_P1[g];
           P0 =display_P0[g];
      delayms(40);
        P1=P2=P3=0xff;
        for(i=0;i<3;i++)
                 P0=0x00;delay(800);
                 P0=0xff;delay(800);
              P0=0x00;
         for(i=0;i<3;i++)
                 P1=0x00;delay(800);
                 P1=0xff;delay(800);
         P1=0x00;
         for(i=0;i<3;i++)
         P3=0x00;delay(800);
         P3=0xff;delay(800);
         P3=0x00;
         for(i=0;i<3;i++)
         P2=0x00;delay(800);
         P2=0xff;delay(800);
         qs(500,3);
        for(i=0;i<6;i++)
         zgxh(50,1);
         nszgm(50,1);
        djs(100,20);  //对角闪
        for(i=0;i<3;i++)
         zg(100,1);                         //两边逐个亮
         qs(200,10);djs(100,50);
         for(i=0;i<5;i++)
                 sztl(200,1); //顺时逐个同步亮
                nztm(200,1);  //逆时针同步灭
                 nztl(200,1);
                sztm(200,1); //顺时逐个同步灭
         djs(300,10);  //对角闪
         nzdgl(300,10);   //逆时逐段一个点亮
         jgs(300,10);   //间隔闪
        for(i=0;i<3;i++)
         zgxh(100,1);
         nszgm(100,1);
   nzdl(200,3); //逆时逐段亮
   jgs(50,100);   //间隔闪
        nzdgl(50,40);   //逆时逐段一个点亮
        for(i=0;i<4;i++)
         zg(100,1);
         qs(100,10);
         lbzgm(100,1);
         djs(50,100);  //对角闪
        for(i=0;i<1;i++)
         zgxh(100,1);
         sszgm(100,1);
        for(i=0;i<1;i++)
         zgxh1(100,1);
         nszgm(100,1);
        for(i=0;i<1;i++)
         zgxh(100,1);
         sszgm(100,1);
        for(i=0;i<1;i++)
         zgxh1(100,1);
         nszgm(100,1);
                 for(i=0;i<1;i++)
         zgxh(100,1);
         sszgm(100,1);
        for(i=0;i<2;i++)
         zgxh1(100,1);
         nszgm(100,1);
     djs(1000,10);
         for(i=0;i<10;i++)
                hwzjl(200,1); //横往中间亮
                hwzjm(200,1); //横往中间灭
         djs(300,10);  //对角闪
        for(i=0;i<5;i++)
         zgxh(100,1);
         nszgm(100,1);
         djs(100,20);  //对角闪
         zg(300,1);
         lbzgm(300,1);
         for(i=0;i<5;i++)
                nztm(200,1);
                 nztl(200,1);
         djs(500,20);  //对角闪
         djs(100,30);  //对角闪
         djs(50,50);  //对角闪
//         djs(10,100);  //对角闪
         delay(1000);
 楼主| 发表于 2012-10-1 13:55:43 | 显示全部楼层
自己的沙发自己坐哦
发表于 2012-10-1 14:02:46 | 显示全部楼层
guohairui 发表于 2012-10-1 13:55
自己的沙发自己坐哦
lz
介绍下硬件部分啊  单纯看程序 貌似不好理解
 楼主| 发表于 2012-10-1 14:04:30 | 显示全部楼层
mubei 发表于 2012-10-1 14:02
lz
有图有真像哦
发表于 2012-10-1 14:20:50 来自手机 | 显示全部楼层
好大一堆数组啊
发表于 2012-10-1 14:33:38 | 显示全部楼层
好大的一个芯片在中间,视觉效果不怎么理想。。
发表于 2012-10-1 14:33:50 | 显示全部楼层
简单移位。复杂查表。
发表于 2012-10-1 15:02:06 | 显示全部楼层
自己的沙发自己坐哦
哈。。。我当年刚入门时也做过这个。。。
 楼主| 发表于 2012-10-1 15:50:17 | 显示全部楼层
晚上灯关了就好看些了
发表于 2012-10-1 15:55:56 | 显示全部楼层
guohairui 发表于 2012-10-1 15:50
晚上灯关了就好看些了
是啊,
发表于 2012-10-1 20:38:08 来自手机 | 显示全部楼层
好多表。。。
发表于 2012-10-1 21:04:09 | 显示全部楼层
可以尝试加上PWM功能了。
发表于 2012-10-2 00:05:19 | 显示全部楼层
哈哈 你说给媳妇做一个行不?
发表于 2012-10-2 00:10:04 | 显示全部楼层
楼主给个具体点的图片 反面看看 还有电路图啊
 楼主| 发表于 2012-10-2 12:56:46 | 显示全部楼层
发表于 2012-10-2 13:29:49 来自手机 | 显示全部楼层
想些办法 用20P的MCU控制试试 还可以用SOP的 就好了
发表于 2012-10-2 14:50:05 | 显示全部楼层
guohairui 发表于 2012-10-2 12:56
可不可以看看走线啊 我也想学习一下做一个试试!!谢谢 具体点好吗?新手!
 楼主| 发表于 2012-10-2 15:27:33 | 显示全部楼层
张超540748551 发表于 2012-10-2 00:05
哈哈 你说给媳妇做一个行不?
可以啊,电路焊接好就行了
发表于 2012-10-2 18:07:47 来自手机 | 显示全部楼层
一个灯写这么麻烦
出145入215汤圆
发表于 2012-10-3 08:15:21 来自手机 | 显示全部楼层
我也做了一个,26个灯,都是透明草帽红色的,有整体开关电路,有时间上个图
发表于 2012-10-3 09:24:50 | 显示全部楼层
哈哈 你说给媳妇做一个行不?
媳妇更喜欢闪闪发光的钻石
发表于 2012-10-3 09:47:55 | 显示全部楼层
我进来是为了看效果的。。。LZ木有发视频!
发表于 2012-10-3 09:54:58 | 显示全部楼层
媳妇更喜欢大把大把的钞票。
发表于 2012-10-3 10:08:15 | 显示全部楼层
这个倒是挺炫的
 楼主| 发表于 2012-10-3 10:57:48 | 显示全部楼层
1兆的网六个人用,暂不支持此功能哦
发表于 2012-10-7 16:52:48 | 显示全部楼层
请问一下 电解电容的作用是什么啊 接在哪啊?还有电源怎么接入?谢谢
 楼主| 发表于 2012-10-7 19:25:23 | 显示全部楼层
电解电容哪是复位电路,电源在上面随便找个正负极都行(所有正极相连、所有负极相连)
发表于 2012-10-7 22:39:10 | 显示全部楼层
这些灯要是都焊在另外一层是不是更好看一些呢?
发表于 2012-10-9 00:03:46 | 显示全部楼层
芯片应该焊到背面的
 楼主| 发表于 2012-10-9 09:16:33 | 显示全部楼层
开始没想到哦
发表于 2012-10-13 10:10:35 | 显示全部楼层
大侠们多上一些,好好学习做一个玩玩。
发表于 2012-10-13 15:00:09 | 显示全部楼层
记号,有需要再来
发表于 2013-4-22 01:31:19 | 显示全部楼层
我累个擦!!~~~
发表于 2013-4-22 09:59:02 | 显示全部楼层
这么多的数组,还不如做个8*8*8光立方呢
发表于 2013-4-22 14:43:26 | 显示全部楼层
LZ居然把所有的IO口都用了,强啊。。。
发表于 2015-1-4 19:19:09 | 显示全部楼层
能用8个IO口控制这么多灯吗?
发表于 2015-1-4 19:50:21 | 显示全部楼层
sidu320 发表于 2015-1-4 19:19
能用8个IO口控制这么多灯吗?
完全可以的~~~~~~~~~~~~~~~
发表于 2015-1-5 22:24:55 | 显示全部楼层
那么多灯的话,电流跟的上吗?
发表于 2015-1-6 20:47:15 | 显示全部楼层
sidu320 发表于 2015-1-5 22:24
那么多灯的话,电流跟的上吗?
它那是动态扫描的
每一时刻只点亮一个
所以电流不是问题
再说了
stc的输出电流很大呢
发表于 2015-1-6 21:05:45 | 显示全部楼层
程序还是打包上传的好,看着书真心累。
GMT+8, 2024-6-30 21:11
