发表于 2012-9-24 21:01:06
http://www.frank-zhao.com/fusecalc/fusecalc.php?chip=atmega88pa
这里有提示说:
Be extra careful about anything with a star *, the star * means the setting is related to ISP programming. If ISP programming becomes disabled (by disabling SPI programming, disabling the reset pin, or enabling debugWIRE), you will require special equipment (HV programmer, parallel programmer, or something with debugWIRE) to change them back.
如果进入debugWIRE模式,则ISP被禁止。
后面又说,可以通过高压编程器、并行编程器、或者某种通过debugWIRE的改回来(something with debugWIRE),有什么软件可以利用debugWIRE把ISP改回来呢? |
