//ICC-AVR application builder : 2012/9/16 22:07:45
// Target : M8
// Crystal: 7.3728Mhz
#include <iom8v.h>
#include <macros.h>
#include "1602.h"
#define SIZE 100
unsigned char SPI_rx_buff[SIZE];
unsigned char SPI_tx_buff[SIZE];
unsigned char rx_wr_index,rx_rd_index,rx_counter,rx_buffer_overflow;
unsigned char tx_wr_index,tx_rd_index,tx_counter,SPI_ok;
unsigned char table[]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','e','f'};
#pragma interrupt_handler spi_stc_isr:18
void spi_stc_isr(void)
SPI_rx_buff[rx_wr_index] = SPDR; //从ISP口读出收到的字节
SPI_ok = 1; // SPI 空闲
if (++rx_wr_index == SIZE) rx_wr_index = 0; //放入接收缓冲区,并调整队列指针
if (++rx_counter == SIZE)
rx_counter = 0;
rx_buffer_overflow = 1;
if (tx_counter) //如果发送缓冲区中有待发的数据
--tx_counter;
SPDR = SPI_tx_buff[tx_rd_index]; //发送一个字节数据,并调整指针
if (++tx_rd_index == SIZE) tx_rd_index = 0;
SPI_ok = 0; // SPI 发送工作
unsigned char getSPIchar(void)
unsigned char data;
while (rx_counter == 0); //无接收数据,等待
data = SPI_rx_buff[rx_rd_index]; //从接收缓冲区取出一个SPI收到的数据
if (++rx_rd_index == SIZE) rx_rd_index = 0; //调整指针
CLI();
--rx_counter;
SEI();
return data;
void putSPIchar(char c)
while (tx_counter == SIZE);//发送缓冲区满,等待
CLI();
if (tx_counter || SPI_ok==0 ) //发送缓冲区已中有待发数据
{ //或SPI正在发送数据时
SPI_tx_buff[tx_wr_index] = c; //将数据放入发送缓冲区排队
if (++tx_wr_index == SIZE) tx_wr_index = 0; //调整指针
++tx_counter;
SPDR = c; // 发送缓冲区中空且SPI口空闲,直接放入SPDR由SIP口发送
SEI();
void spi_init(void)
unsigned char temp;
DDRB|= 0b00101100; //MISO=input and MOSI,SCK,SS = output
PORTB|=0b00010000; //MISO上拉电阻有效
PORTB&=~0b00000100;
SPCR = 0xD3; //SPI允许,主机模式,MSB,允许SPI中断,极性方式01,1/16系统时钟速率
SPSR = 0x00;
temp = SPSR;
temp = SPDR; //清空SPI,和中断标志,使SPI空闲
unsigned char i=0x0c;
unsigned char x100,x10,x1,d;
CLI(); //关中断
spi_init(); //初始化SPI接口
SEI(); //开中断
LCD_init();
LCD_write_char(0,0,'a');
putSPIchar(0xAc); //写控制寄存器地址
putSPIchar(0x41); //写控制寄存器数据
putSPIchar(0x2c); //发送
d=getSPIchar(); //接收一个字节(第一个字节为空字节)
x100=d/100;
d=d-x100*100;
x10=d/10;
d=d-x10*10;
x1=d;
LCD_write_char(0,0,table[x100]);
LCD_write_char(1,0,table[x10]);
LCD_write_char(2,0,table[x1]);
delay_nms(1000);
这个程序师本坛马老师的例子,我修改到M8上面了,我把MOSI和MISO短接,1602上可以正确收发数据,所以收发程序应该没问题。
我的目的是M8控制MMA7455,这是个验证程序,就是将数据写入MMA7455方式寄存器,然后读出来,但是无论如何都不能读到数据。
我简单描述一下流程:
1、按照7455手册上的规范,首先向7455写入寄存器地址:1位读写状态(0=读,1=写)+6位地址(寄存器地址是0x16)+1位无作用位
所以地址为1+010110+0=0XAC;
2、接着写入数据0X41;
3、接着读出数据,地址变为0+010110+0=00x2c;
4、转换读出的数据位三位字符给1602显示。
各位看看我程序的流程和操作有问题没有,为什么读不出数据?或者哪位用过7455给提供个范例也行啊,非常感谢。搞好久了,头大了。
