平台ubuntu11.10,不是虚拟机,所以你懂得。
一下为官方的方法
Requirements
Please make sure that you have installed libusb as this is necessary for
the J-Link to work via USB.
You can install it the following way for all apt-able Linux derivates:
apt-get -update
apt-get -install libusb
This will update the apt-get package resources and download and install
libusb. Please unplug and replug your J-Link after successful
libusb installation.
You also need to make sure the libreadline is installed on your system.
This library is needed by the JLinkExe utility.
Installing the shared library
To install the delivered shared library in a system directory perform the following
steps as root:
- Copy the library in a system directory for example /usr/lib
cp libjlinkarm.so.* /usr/lib
- Update the cache of dynamic loader and setup symbolic links by running:
ldconfig
Running JLinkExe with standard user rights
In order to run JLinkExe with standard user rights you have to do the following:
- Place the rule file "45-jlink.rules" provided with this J-Link software package
at /etc/udev/rules.d/
- Make sure that you are member of the group "plugdev"
- If the group "plugdev" does not exist, you have to create it:
Command line:
groupadd plugdev // Creates new group "plugdev"
usermod -a -G plugdev <Username> // Appends user <Username> to the group "plugdev"
- Restart your system
以上内容为官方给的标准安装方法
//linux的系统命令可以到linux系统管理里面去看,记住几个常用的就行
下面是具体步骤
先演示一下最终结果
1.检查命令是否可用 JLinkExe
2.插上Jlink,查看是否链接上"lsusb"
3.测试Jlink,JLinkExe
1.解压到/usr/local目录下,我的arm编译软件也安装到这里
2.安装libusb
sudo apt-get install libusb-dev
3.复制库到系统目录/usr/lib
# cp libjlinkarm.so.4 /usr/lib
# cp libjlinkarm.so.41.7 /usr/lib
# cp 45-jlink.rules /etc/udev/rules.d/
4.把自己添加到plugdev中
ubuntn默认自己plugdev中的用户
如果不是或不确定
如果有plugdev用户组执行 usermod -a -G plugdev <你的用户名> 把自己加到plugdev中
如果没有plugdev用户组先创建,再把自己加进去。
5.把命令添加到环境变量里面
需该/etc/envirtonment按照文件给的例程写
6.重新启动
