回复: 0
【求助】ATmega128操作HC_SR04超声波测距
发表于 2012-9-16 19:29:27 | 显示全部楼层 |阅读模式
  1. int   main(void)
  2. {
  3.        volatile unsigned int time_us=0;//定时器计数值
  4.        volatile unsigned int distance_cm = 0; //距离
  5.         DDRG |= 0x01;
  6.         DDRG &= 0xfd; //Trig输出接PG0  Echo输入接PG1
  7.         PORTG &= 0xfe; //PG0 = 0
  8.         PORTG |= 0x02; //PG1 = 1 带上拉电阻输入
  9.         lcd_init();     //液晶初始化
  10.         while(1)
  11.         {
  12.                 PORTG &= 0xfe; //PG0 = 0
  13.                 PORTG |= 0x01; //PG0 = 1
  14.                 _delay_us(20);
  15.                 PORTG &= 0xfe; //PG0 = 0
  16.                 while(!(PING & 0x02)); //等待PG1=1
  17.                 TCNT1 = 0; //开始一次计数
  18.                 TCCR1B = 0x02; //8分频
  19.
  20.                 while(PING & 0x02); //等待PG1=0
  21.                 TCCR1B = 0x00; //定时器停止
  22.                 time_us = TCNT1; //读取计数值
  23.                 distance_cm = time_us/58;
  24.                 table[0] = (distance_cm%1000)/100 + 0x30;
  25.                 table[1] = (distance_cm%100)/10 + 0x30;
  26.                 table[2] = distance_cm%10 + 0x30;
  27.                 lcd_display(table);
  28.                 _delay_ms(100);
  29.         }
  30. }
单片机使用8M晶振,测试结果在0-5cm内显示正确,而超过5cm后液晶一直显示是5cm,请问程序有什么问题吗?
GMT+8, 2024-7-24 06:20
