想做四轴,硬件已经搭好,现在研究飞控了,MK的飞控好复杂,看了好多遍还有好多地方不懂,前来请教一下。- // Coupling fraction
- if(!Looping_Nick && !Looping_Roll && (ParamSet.GlobalConfig & CFG_AXIS_COUPLING_ACTIVE))
- tmpl = (Reading_GyroYaw * Reading_IntegralGyroNick) / 2048L;
- tmpl *= FCParam.Yaw_PosFeedback;
- tmpl /= 4096L;
- tmpl2 = ( Reading_GyroYaw * Reading_IntegralGyroRoll) / 2048L;
- tmpl2 *= FCParam.Yaw_PosFeedback;
- tmpl2 /= 4096L;
- if(labs(tmpl) > 128 || labs(tmpl2) > 128) FunnelCourse = 1;
- else tmpl = tmpl2 = 0;
复制代码 这个地方怎么把Reading_GyroYaw 和Reading_IntegralGyroNick两个轴乘到一起?这有什么意义?- int32_t tmp_long, tmp_long2;
- if(FCParam.Kalman_K != -1)
- // determine the deviation of gyro integral from averaged acceleration sensor
- tmp_long = (int32_t)(IntegralNick / ParamSet.GyroAccFactor - (int32_t)Mean_AccNick);
- tmp_long = (tmp_long * FCParam.Kalman_K) / (32 * 16);
- tmp_long2 = (int32_t)(IntegralRoll / ParamSet.GyroAccFactor - (int32_t)Mean_AccRoll);
- tmp_long2 = (tmp_long2 * FCParam.Kalman_K) / (32 * 16);
- if((MaxStickNick > 64) || (MaxStickRoll > 64)) // reduce effect during stick commands
- tmp_long /= 2;
- tmp_long2 /= 2;
- if(abs(PPM_in[ParamSet.ChannelAssignment[CH_YAW]]) > 25) // reduce further if yaw stick is active
- tmp_long /= 3;
- tmp_long2 /= 3;
- // limit correction effect
- if(tmp_long > (int32_t)FCParam.Kalman_MaxFusion) tmp_long = (int32_t)FCParam.Kalman_MaxFusion;
- if(tmp_long < -(int32_t)FCParam.Kalman_MaxFusion) tmp_long =-(int32_t)FCParam.Kalman_MaxFusion;
- if(tmp_long2 > (int32_t)FCParam.Kalman_MaxFusion) tmp_long2 = (int32_t)FCParam.Kalman_MaxFusion;
- if(tmp_long2 <-(int32_t)FCParam.Kalman_MaxFusion) tmp_long2 =-(int32_t)FCParam.Kalman_MaxFusion;
复制代码 这个地方 (int32_t)(IntegralNick / ParamSet.GyroAccFactor - (int32_t)Mean_AccNick);陀螺仪和加速度计数据可以直接比较吗?难道加速度计不需要用反正切得出角度?- if(!Looping_Nick && !Looping_Roll && !FunnelCourse)
- // Calculate mean value of the gyro integrals
- MeanIntegralNick /= BALANCE_NUMBER;
- MeanIntegralRoll /= BALANCE_NUMBER;
- // Calculate mean of the acceleration values
- IntegralAccNick = (ParamSet.GyroAccFactor * IntegralAccNick) / BALANCE_NUMBER;
- IntegralAccRoll = (ParamSet.GyroAccFactor * IntegralAccRoll ) / BALANCE_NUMBER;
- // Nick ++++++++++++++++++++++++++++++++++++++++++++++++
- // Calculate deviation of the averaged gyro integral and the averaged acceleration integral
- IntegralErrorNick = (int32_t)(MeanIntegralNick - (int32_t)IntegralAccNick);
- CorrectionNick = IntegralErrorNick / ParamSet.GyroAccTrim;
- AttitudeCorrectionNick = CorrectionNick / BALANCE_NUMBER;
- // Roll ++++++++++++++++++++++++++++++++++++++++++++++++
- IntegralErrorRoll = (int32_t)(MeanIntegralRoll - (int32_t)IntegralAccRoll);
- CorrectionRoll = IntegralErrorRoll / ParamSet.GyroAccTrim;
- AttitudeCorrectionRoll = CorrectionRoll / BALANCE_NUMBER;
- if(((MaxStickNick > 64) || (MaxStickRoll > 64) || (abs(PPM_in[ParamSet.ChannelAssignment[CH_YAW]]) > 25)) && (FCParam.Kalman_K == -1) )
- AttitudeCorrectionNick /= 2;
- AttitudeCorrectionRoll /= 2;
复制代码 上面不是已经 MeanIntegralNick /= BALANCE_NUMBER; 了吗,为什么还要再除一次? AttitudeCorrectionNick = CorrectionNick / BALANCE_NUMBER;- // +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
- // Nick-Axis
- DiffNick = Reading_GyroNick - StickNick; // get difference
- if(Gyro_I_Factor) SumNick += IntegralNick * Gyro_I_Factor - StickNick; // I-part for attitude control
- else SumNick += DiffNick; // I-part for head holding
- if(SumNick > (STICK_GAIN * 16000L)) SumNick = (STICK_GAIN * 16000L);
- if(SumNick < -(STICK_GAIN * 16000L)) SumNick = -(STICK_GAIN * 16000L);
- pd_result = DiffNick + Ki * SumNick; // PI-controller for nick
- tmp_int = (int32_t)((int32_t)FCParam.DynamicStability * (int32_t)(GasMixFraction + abs(YawMixFraction)/2)) / 64;
- if(pd_result > tmp_int) pd_result = tmp_int;
- if(pd_result < -tmp_int) pd_result = -tmp_int;
- // Motor Front
- MotorValue = GasMixFraction + pd_result + YawMixFraction; // Mixer
- MotorValue /= STICK_GAIN;
- if ((MotorValue < 0)) MotorValue = 0;
- else if(MotorValue > ParamSet.Gas_Max) MotorValue = ParamSet.Gas_Max;
- if (MotorValue < ParamSet.Gas_Min) MotorValue = ParamSet.Gas_Min;
- Motor_Front = MotorValue;
- // Motor Rear
- MotorValue = GasMixFraction - pd_result + YawMixFraction; // Mixer
- Motor_Rear = MotorValue;
复制代码 最后这个
地方不懂。。
Reading_GyroNick应该是角速度,为什么能和StickNick相减呢?
后面IntegralNick 已经是积分了的,为什么 SumNick +=还要积分一次?
最后的电机控制量应该是:角速度*a+角度*b 吧?
还是 角速度*a+角度*b+∫角度*c ??
恳请高手指教一下,谢谢了 |
