写了一个很简单的UART的程序,就是按照“0xBB 八位数据 0xEE”的数据帧格式通过串口给mega16发数据,(数据在0-9之间),然后通过数码管显示。
UART设置是9600波特率,1M时钟。
现在问题是:
1.发送数据总是发好几遍才可以使数码管值改变
2.发数据0x01总是显示溢出
3.用proteus仿真,显示数据帧格式不对
不知道是什么原因,想请指教,程序如下:
#include <iom16v.h>
#include <macros.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1 << FE)
#define PARITY_ERROR (1 << UPE)
#define DATA_OVERRUN (1 << OVR)
#define RX_COMPLETE (1<<RXC)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define UART_BEGIN_STX 0xBB
#define UART_END_STX 0xEE
#define TX_BUFFER_SIZE 5
#define RX_BUFFER_SIZE 5
unsigned char tx_buffer[TX_BUFFER_SIZE];
unsigned char tx_wr_index,tx_rd_index,tx_counter;
unsigned char rx_buffer[RX_BUFFER_SIZE];
unsigned char rx_counter;
unsigned char Uart_RecvFlag;
unsigned char a;
unsigned char led[10] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
#pragma interrupt_handler USART_RXC_isr:iv_USART_RXC
void USART_RXC_isr(void)
unsigned char status,data;
status = UCSRA;
data = UDR;
if(!Uart_RecvFlag) //判断是否可以接收一个新的数据包
if((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN)) == 0)
rx_buffer[rx_counter] = data;
rx_counter++;
switch(rx_counter)
case 1: //校检起始字符
if(data != UART_BEGIN_STX) rx_counter = 0;
case 3:
if(data == UART_END_STX) Uart_RecvFlag = 1;
rx_counter = 0;
break; //表示正确接受到一个数据包
DDRB = 0xff;
PORTA = 0x01;
DDRA |= 0xFF; //初始化数码管输出使能和段选信号口
//UART initialization
CLI();
USART_INIT();
SEI(); //Global enable interruPts
if(Uart_RecvFlag)
PORTB = led[rx_buffer[1]];
Uart_RecvFlag = 0;
