我写的程序向液晶写数字,键盘第一列反应很好,按一下就显示,但是其他列要按好几次才可能显示出来 大神帮忙看看原因
#include <c8051f020.h> // SFR declarations
#include <intrins.h>
#include <stdio.h>
#define uint unsigned int
#define Lcd_Bus P5
#define ScanKeyPort P2
#define SYSCLK 22118400 // SYSCLK frequency in Hz
#define INT_DEC 256 // integrate and decimate ratio
#define _Nop() _nop_()
// 16-bit SFR Definitions for 'F02x
sfr16 DP = 0x82; // data pointer
sfr16 TMR3RL = 0x92; // Timer3 reload value
sfr16 TMR3 = 0x94; // Timer3 counter
sfr16 ADC0 = 0xbe; // ADC0 data
sfr16 ADC0GT = 0xc4; // ADC0 greater than window
sfr16 ADC0LT = 0xc6; // ADC0 less than window
sfr16 RCAP2 = 0xca; // Timer2 capture/reload
sfr16 T2 = 0xcc; // Timer2
sfr16 RCAP4 = 0xe4; // Timer4 capture/reload
sfr16 T4 = 0xf4; // Timer4
sfr16 DAC0 = 0xd2; // DAC0 data
sfr16 DAC1 = 0xd5; // DAC1 data
unsigned char keydata;
unsigned char keyvalue;
// 延时
void delay(unsigned int t)
{ unsigned int k,j;
for(k=0;k<t;k++)
for(j=0;j<10;j++) ;
// 按键扫描
unsigned char key_in(void)
uchar keytemp,scancode,tmpcode;
ScanKeyPort=0xf0;
keytemp=ScanKeyPort;
if ((keytemp&0xf0)^0xf0)
// delay(50);
scancode = 0xfe;
while((scancode&0x10)!=0) // 逐行扫描
ScanKeyPort= scancode; // 输出行扫描码
if ((ScanKeyPort&0xf0)!=0xf0) // 本行有键按下
tmpcode = (ScanKeyPort&0xf0)|0x0f;
return((~scancode)+(~tmpcode)); /* 返回特征字节码,为1的位即对应于行和列 */
scancode = (scancode<<1)|0x01; // 行扫描码左移一位
return(0);//返回0,表示没有按键按xia
// 液晶接口定义
//#define LEDCTL0Low P4&=~0x01;
//#define LEDCTL0High P4|=0x01;
#define LCDELow P4&=~0x02;
#define LCDEHigh P4|=0x02;
#define LCDRWLow P4&=~0x04;
#define LCDRWHigh P4|=0x04;
#define LCDRSLow P4&=~0x08;
#define LCDRSHigh P4|=0x08;
#define LCDPSBLow P4&=~0x10;
#define LCDPSBHigh P4|=0x10;
uchar num;
uint delay_time;
void SYSCLK_Init (void);
void PORT_Init (void);
// 液晶显示写命令
void write_com(unsigned char cmdcode)
LCDRSLow;
LCDRWLow;
LCDEHigh;
Lcd_Bus=cmdcode;
delay(50);delay(60); //在数据写入的时候加入适当的延时
LCDELow;
// 液晶显示写数据
void write_data(unsigned char Dispdata)
LCDRSHigh;
LCDRWLow;
LCDEHigh;
Lcd_Bus=Dispdata;
delay(50);delay(60); // 在数据写入的时候加入适当的延时
LCDELow;
// 液晶显示,复位初始
void lcdreset()
delay(200);delay(250);
write_com(0x30);
delay(100);delay(250); //选择基本指令集
write_com(0x30); //选择8bit数据流
delay(50);delay(250);
write_com(0x0c); //开显示(无游标、不反白)
write_com(0x01); //清除显示,并且设定地址指针为00H
write_com(0x06); //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位
// 液晶显示
void display(unsigned char code *s)
while(*s>0)
{ write_data(*s);
s++;
delay(50);delay(100);
// 液晶显示内容
void zero_screen()
{ uint a;
a=0x30;
write_com(0x30);
delay(10000);
write_com(0x80);
write_data(a+keyvalue);
// 通用I/O口及交叉开关初始化
XBR2 = 0x40; // 交叉开关使能
P2MDOUT=0x00;
P74OUT=0xff;
// 系统时钟初始化
void SYSCLK_Init()
OSCICN =0x87; //使用内部时钟16M
while((OSCICN & 0x10)==0);//内部时钟按设定频率运行
// 配置系统时钟使用外部晶振11.0592MHz
int i; // delay counter
OSCXCN = 0x67; // start external oscillator with
// 22.1184MHz crystal
for (i=0; i < 256; i++) ; // XTLVLD blanking interval (>1ms)
while (!(OSCXCN & 0x80)) ; // Wait for crystal osc. to settle
OSCICN = 0x88; // select external oscillator as SYSCLK
// source and enable missing clock
// detector
// 系统初始化
void init()
SYSCLK_Init();
PORT_Init ();
lcdreset();
zero_screen();
// 主程序
void main()
WDTCN = 0xde;
WDTCN = 0xad; //禁止看门狗定时器
SYSCLK_Init ();
PORT_Init();
init();
//SFRPAGE = LEGACY_PAGE;
keydata=key_in(); //读按键
if(keydata!=0) //有按键按下,显示对应的按键
switch(keydata)
case 0x14: keyvalue=0;break;
case 0x88: keyvalue=1;break;
case 0x84: keyvalue=2;break;
case 0x82: keyvalue=3;break;
case 0x48: keyvalue=4;break;
case 0x44: keyvalue=5;break;
case 0x42: keyvalue=6;break;
case 0x28: keyvalue=7;break;
case 0x24: keyvalue=8;break;
case 0x22: keyvalue=9;break;
//case 0x14: keyvalue=10;break;
//case 0x48: keyvalue=11;break;
zero_screen();
