//* 数码相框
//*控制芯片:ATmgea128
//*开发环境:AVR Studio+GCC
//*隶属模块:位图解码
//*设计者: 桃子
#include "bmp.h"
extern unsigned char buffer[512]; //文件系统数据缓冲
extern FATFS fs; //文件系统结构
extern FIL fl; //文件状态信息
extern FRESULT res; //文件返回值
extern unsigned int r; //文件读取数量
//*隶属模块:BMP解码
//*函数功能:小端转大端
UINT32 bmp_LE2BE(UINT8 *dat,UINT8 len)
UINT32 temp=0;
if(len >= 1) temp = (UINT32)dat[0];
if(len >= 2) temp |= (UINT32)dat[1]<<8;
if(len >= 3) temp |= (UINT32)dat[2]<<16;
if(len >= 4) temp |= (UINT32)dat[3]<<24;
return temp;
//*隶属模块:BMP解码
//*函数功能:单灰BMP解码显示
//*注意:图片宽度最好小于208
void BMP_1(unsigned int x0,unsigned int y0,unsigned char type)
unsigned int j;
unsigned char k=0;
if(BMP.bmp_width & 0x001f)BMP.bmp_width +=32 - (BMP.bmp_width & 0x001f);
if(type)
TFT_Windons(x0,x0+BMP.bmp_width-1,y0,y0+BMP.bmp_hight-1);
x0 = (240 - BMP.bmp_width)/2;
y0 = (320 - BMP.bmp_hight)/2;
res = f_read(&fl,buffer,512,&r);
if(res || r==0) break;
for(j=0;j<r;j++)
for(k=8;k;k--)
if(buffer[j] & (1 << (k-1)))
TFT_Write_Data(0x00,0x00);
TFT_Write_Data(0xff,0xff);
//*隶属模块:BMP解码
//*函数功能:16位灰BMP解码显示
//*注意:图片宽度最好小于232
void BMP_4(unsigned int x0,unsigned int y0,unsigned char type)
unsigned int j;
unsigned char color_H,color_L,i;
const unsigned char table_RBGcolor[16] = {0xff,0xee,0xdd,0xcc,0xbb,0xaa,//经查表RGB三像素相同
0x99,0x88,0x77,0x66,0x55,0x44,//从白到黑FF~00共16个
0x33,0x22,0x11,0x00}; //段
if(BMP.bmp_width & 0x0007)BMP.bmp_width +=8 - (BMP.bmp_width & 0x007);
if(type)
for(j=0;j<r;j++)
i = buffer[j]>> 4;
color_H = (table_RBGcolor[i] & 0xf8) | (table_RBGcolor[i] >> 5);
color_L = ((table_RBGcolor[i] << 3) & 0xe0) | (table_RBGcolor[i] >> 3);
TFT_Write_Data(color_H,color_L);
i = buffer[j]& 0x0f;
//*隶属模块:BMP解码
//*函数功能:256位灰BMP解码显示
//*注意:图片宽度最好小于236
void BMP_8(unsigned int x0,unsigned int y0,unsigned char type)
const unsigned char table_Bcolor[4] = {0x00,0x55,0xaa,0xff};//经查表R像素
const unsigned char table_GRcolor[8] = {0x00,0x24,0x48,0x6d,0x91,0xb6,0xda,0xff};//经查表GB像素相同
unsigned int j;
unsigned char color_H,color_L;
if(BMP.bmp_width & 0x0003)BMP.bmp_width +=4 - (BMP.bmp_width & 0x03);
if(type)
for(j=0;j<r;j++)
color_H = (table_Bcolor[buffer[j]>>6] & 0xf8) | (table_GRcolor[(buffer[j] & 0x38)>>3] >> 5);
color_L = ((table_GRcolor[(buffer[j] & 0x38)>>3] << 3) & 0xe0) | (table_GRcolor[buffer[j] & 0x07] >> 3);
//*隶属模块:BMP解码
//*函数功能:16位真彩BMP解码显示
void BMP_16(unsigned int x0,unsigned int y0,unsigned char type)
unsigned int j=0;
unsigned int temp_color=0;
if(BMP.bmp_width & 0x0001)BMP.bmp_width +=1;
if(type)
for(j=0;j<r;j+=2)
temp_color = ((buffer[j]&0xE0)<<1)|(buffer[j]&0x1F);
TFT_Write_Data((buffer[j+1]<<1)|(temp_color>>8),temp_color&0x00FF);
//*隶属模块:BMP解码
//*函数功能:24位真彩BMP解码显示
void BMP_24(unsigned int x0,unsigned int y0,unsigned char type)
unsigned int j=0;
unsigned char temp[2];
if(type)
temp[0] = buffer[510];temp[1] = buffer[511];
for(j=0;j<r-2;j+=3)
TFT_Write_Data((buffer[j+2]&0xf8)|(buffer[j+1]>>5),
((buffer[j+1]<<3)&0xe0)|(buffer[j]>>3));
TFT_Write_Data((buffer[0]&0xf8)|(temp[1]>>5),
((temp[1]<<3)&0xe0)|(temp[0]>>3));
temp[0] = buffer[511];
for(j=1;j<r-1;j+=3)
TFT_Write_Data((buffer[1]&0xf8)|(buffer[0]>>5),
((buffer[0]<<3)&0xe0)|(temp[0]>>3));
for(j=2;j<r;j+=3)
//*隶属模块:BMP解码
//*函数功能:32位真彩BMP解码显示
void BMP_32(unsigned int x0,unsigned int y0,unsigned char type)
unsigned int j=0;
if(type)
for(j=0;j<r;j+=4)
//*隶属模块:BMP解码
//*函数功能:BMP图片格式解码
void dis_bmp(unsigned int x0,unsigned int y0,unsigned char type)
do
res = f_read(&fl,buffer,512,&r);//读512个数据
}while(res || r==0);
BMP.bmp_offset = bmp_LE2BE((buffer + 10),4);//数据偏移量
BMP.bmp_width = (UINT16)(bmp_LE2BE((buffer + 18),4));//图像宽度
BMP.bmp_hight = (UINT16)(bmp_LE2BE((buffer + 22),4));//说明图像高度
BMP.bmp_form = (UINT16)(bmp_LE2BE((buffer + 28),2));//说明图像格式
do{
res = f_lseek(&fl,BMP.bmp_offset);
}while(res);
if(type == 2)
{BMP.bmp_width >>= 1;BMP.bmp_hight >>= 1;}
else if(type == 4)
{BMP.bmp_width >>= 2;BMP.bmp_hight >>= 2;}
switch(BMP.bmp_form)
case 1: BMP_1(x0,y0,type); break;
case 4: BMP_4(x0,y0,type); break;
case 8: BMP_8(x0,y0,type); break;
case 16:BMP_16(x0,y0,type);break;
case 24:BMP_24(x0,y0,type);break;
case 32:BMP_32(x0,y0,type);break;
default:break;
f_close(&fl);
f_mount(0,NULL);
