发表于 2013-1-14 13:49:03
好机要配好鞍。
俺决定给小JJ配一块漂亮的电控板:
荷兰出品的CPU5 - B Professional6轴专业版
http://www.edingcnc.com/index.ph ... &productenid=51
这是网站的对这款控制板的简介:
Advanced CPU for high speed machines with complex tool-changers
125 KHz step frequency.
Full 6 axes interpolation.
Euro card size 100x160mm.
5 status LED's.
6 Standard CNC outputs ( Tool, Tool direction, TOOL PWM, Flood coolant, Mist coolant, Charge PUMP for external watchdog)
9 Standard CNC inputs (6 Home inputs, Probe, Spindle sensor, 2 x E-Stop, External ERROR, Run, Pause, Hand wheel).
10 general purpose digital outputs (tool-changer).
2 Extra PWM outputs for motor speed or temperature control.
6 Extra digital Inputs (tool changer).
3 Extra analogue Inputs 3. The extra IO is controlled by M54, M55, M66.
Interface to PC is USB2.0.
Optional 100 Mbit Ethernet.
On board Power supply, input +9 – 24 Volt.
Field upgradable firmware.
USBCNC Software included.
Windows XP, Windows 7.
Runs on single core Atom PC.
Features
Shortest possible CNC production time, especially 3D work, depending on the product, USBCNC can be up to 2 times faster . This is thanks to the advanced Look Ahead Feed Algorithm that works for all motion segments, lines and circles by looking at their curvature and reduce speed only when absolutely necessary.
Simple one screen operation, UI designed for and by professional CNC operators.
Nesting mode execution for multiple production.
Optimized tooltip feed calculations for 4th axis milling, no tool breakage due to wrong tool-tip feed.
Feed Override control while running 0-300%.
Easy start half way in g-code file, using search method
Slave axes, for systems with dual motors (tandem) on X, Y or Z axis.
Special homing sequence for tandems, sets tandem straight.
Tangential knife, you need to program only X.Y coordinates and the tangential knife follows, also in circles and lifts automatically up when needed.
Backlash compensation.
Spindle proportional ramp-up time.
Collision detection when g-code job is loaded prevents machine damage.
Running time estimation when job is loaded.
Thread cutting (Lathe).
OpenGL graphics allows real-time PAN/ZOOM/ROTATE
G-code is EMC compatible, RS274NGC, can be used with all CAM software's so far.
G-code extensions with IF..THEN, WHILE..ENDWHILE, SUB ENDSUB, GOSUB.
G68, Zeroing with rotation, accurate setup of clamping device no longer necessary.
Super long file mode allows endless files, tested with 100.000.000 lines g-code.
User interaction from G-Code with DlgMsg command and a lot more.
Automatic tool change can be programmed entirely in G-code.
Pause, Jog away, resume run in middle of g-code run.
Hand wheel jog with position and velocity mode.
Build in 2D CAM for drilling, engraving, profiling and pocketing, reads DXF and HPGL.
SDK for building customized UI's.
CPU5 - B Professional6轴专业版 |
