回复: 1
PLC自由通讯问题
发表于 2012-7-29 15:09:50 | 显示全部楼层 |阅读模式
我模拟了一个机械控制流程,先机器工作,然后发送一个FF到电脑,然后电脑进行判断并反馈一个F00FF或FF11FF到PLC,PLC作出反应,如此循环。但实际测试时发现偶尔PLC会多发一个FF到电脑,而且PLC在工作了50个循环左右就会卡主,不能循环。用的是S7-200,CPU224。求指教。
LD     First_Scan_On:SM0.1
MOVB   9, P0_Config:SMB30
MOVB   1, VB100
MOVB   3, VB200
MOVB   16#FF, VB101
MOVB   16#68, P0_Ctrl_Rcv:SMB87
MOVB   16#F0, P0_Start_Char:SMB88
MOVB   16#FF, P0_End_Char:SMB89
MOVB   3, P0_Max_Char:SMB94
S      S0.0, 1
ATCH   INT_0:INT0, 9
ATCH   INT_1:INT1, 23
ENI
LSCR   S0.0
LD     Always_On:SM0.0
MOVB   0, VB150
SCRT   S0.1
SCRE
LSCR   S0.1
LD     Always_On:SM0.0
S      Q0.1, 1
R      Q0.2, 1
SCRT   S0.2
SCRE
LSCR   S0.2
LDB<>  VB150, 1
XMT    VB100, 0
MOVB   1, VB150
SCRE
LSCR   S0.3
LD     Always_On:SM0.0
R      Q0.1, 1
S      Q0.2, 1
AN     T33
TON    T33, 300
LD     T33
MOVB   0, VB150
SCRT   S0.1
SCRE
INT0:
LD     Always_On:SM0.0
S      P0_Ctrl_Rcv_7:SM87.7, 1
RCV    VB200, 0
CRETI
INT1:
LD     Always_On:SM0.0
LPS
R      P0_Ctrl_Rcv_7:SM87.7, 1
AB=    VB202, 16#11
S      Q0.3, 1
R      Q0.4, 1
LRD
AB=    VB202, 16#0
S      Q0.4, 1
R      Q0.3, 1
LPP
SCRT   S0.3
CRETI
 楼主| 发表于 2012-7-29 15:38:38 | 显示全部楼层
说错了,电脑反馈的是F000FF或F011FF。
GMT+8, 2024-9-1 08:16
