发表于 2013-9-8 13:45:37
目前正把 px4 移植到 tmr-fc 已經成功了, 但還是有其他地方需要再修改的.
代碼庫 : https://github.com/cctsao1008/Firmware
branch : tmr-fc
submodules : bootloader, libopencm3, Nuttx
亮點 :
tone alarm, 12 ch pwm output, 1 PPM input, 1 SBUS input, 5 LEDs, Mocro SD (接到電腦可讀資料), USB VCP (虛擬串口), MS5611 + MPU6050 + HMC5883, STM32F405RG, I2C IO 擴展IC (PCA9533/36)
內部 flash 虛擬 EEPROM, EKF, Commander, Stress test scrpit (auto reboot, tone alarm loop test...... ) , RTC 時間可靠水銀電池自保持 ... etc
開機 log :
reboot
ABCDF
nsh_romfsetc: nsh > romfs_img_len 0xFF52F09C
nsh_romfsetc: nsh > Mounting ROMFS filesystem at target=/etc with source=/dev/ram0
[boot] Initializing (HRT) 1...
[boot] Initializing (CPU) 2...
[boot] Initializing (DMA) 3...
[boot] Initializing pca953x driver
[PCA953X] on I2C bus 2 at 0x62
[TMRFC_LED] led_off, led = 0x338
[TMRFC_LED] led_off, led = 0x332
[TMRFC_LED] led_on, led = 0x334
[boot] Initializing soft SPI for the MMC/SD slot
[boot] Successfully initialized soft SPI for the MMC/SD slot
[boot] Binding soft SPI device to MMC/SD slot 0
[boot] Successfuly bound Soft SPI device to MMC/SD slot 0
[boot] Initializing SPI3
[init] MODE = autostart
[init] Looking for microSD...
[init] Card mounted at /fs/microsd
[init] tone_alarm start
[init] Reading /fs/microsd/etc/rc.txt
Detecting on board sensors on I2C bus(I2C2) ......
( 0x62 ) Have PCA9533DP
( 0x41 ) Have PCA9536DP
( 0x69 ) Have MPU6050
Set MPU6050 auxiliary I2C bus to bypass mode......
Detecting sensors on MPU6050 auxiliary I2C bus......
( 0x1e ) Have HMC5883L
( 0x77 ) Have MS5611
i2c: Done
[init] Start the ORB
[uorb] ready
ramtron: RAMTRON not enabled, skipping.
param: selected parameter default file /fs/microsd/params
[init] param load /fs/microsd/params
param: end of parameters
[init] Start mavlink ( 57600 /dev/ttyS1 )
mavlink: MAVLink v1.0 serial interface starting...
mavlink: DOWNLINK MODE
mavlink: UART is /dev/ttyS1, baudrate is 57600
[init] Start commander
commander: starting
commander: No RGB LED found
[fcservo] default PWM output device
<fcservo> MODE_NONE
[fcservo] starting
<fcservo> adjusted actuator update interval to 100ms
FC driver (no PWM) started
[init] Start sensors >> need to implement
[init] Start one of the estimators ( attitude_estimator_ekf ) >> wait for MPU6050 driver ready !!
[init] Start GPS >> need to implement
NuttShell (NSH)
nsh> eeprom test
RM0090 Table 5. Flash module organization (STM32F40x and STM32F41x)
[DEBUG]Check_Sector_Erased (845):SS = 0x08000000, SE = 0x08003FFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (986):Check_Sector_Erased 0 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08004000, SE = 0x08007FFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (988):Check_Sector_Erased 1 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08008000, SE = 0x0800BFFF, COUNT = 0x00004000
[DEBUG]internal_flash_test (990):Check_Sector_Erased 2 (ERASED)
[DEBUG]Check_Sector_Erased (845):SS = 0x0800C000, SE = 0x0800FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (992):Check_Sector_Erased 3 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08010000, SE = 0x0801FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (994):Check_Sector_Erased 4 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08020000, SE = 0x0803FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (996):Check_Sector_Erased 5 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08040000, SE = 0x0805FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (998):Check_Sector_Erased 6 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08060000, SE = 0x0807FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1000):Check_Sector_Erased 7 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x08080000, SE = 0x0809FFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1002):Check_Sector_Erased 8 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x080A0000, SE = 0x080BFFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1004):Check_Sector_Erased 9 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x080C0000, SE = 0x080DFFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1006):Check_Sector_Erased 10 (DATA)
[DEBUG]Check_Sector_Erased (845):SS = 0x080E0000, SE = 0x080FFFFF, COUNT = 0x00000001
[DEBUG]internal_flash_test (1008):Check_Sector_Erased 11 (DATA)
[DEBUG]internal_flash_test (1011):Warning !! This test will destroy the data stored on sector 1 and 2 !
[DEBUG]internal_flash_test (1014):1)sched_lock....
[DEBUG]internal_flash_test (1018):2)FLASH_Unlock....
[DEBUG]internal_flash_test (1022):3)EE_Init....
[DEBUG]EE_Init (146):EE_Init
[DEBUG]EE_Init (330):EE_Init >> VALID_PAGE
[DEBUG]EE_Init (345):EE_Init >> ERASED
[DEBUG]EE_Init (347):EE_Init >> FLASH_EraseSector 1
[DEBUG]EE_Init (355):Page 1 blank, skip to erase it.
[DEBUG]internal_flash_test (1025):4)FLASH_Lock....
[DEBUG]internal_flash_test (1029):5)sched_unlock....
nsh> |
