这个程序,调了很久不知道错在哪里了,希望大家找找,谢谢了,太谢谢打家了。
/**************************************主模块******************************************/
#include "delay.h"
#include "read_write_init.h"
bit write=0;
uchar t=0;
uchar table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void mian()
TMOD=0x01;
EA=1;
ET0=1;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
scl=1;
sda=1;
t=read_add(6);
TR0=1;
P0=table[t%10];
p27=0;
delayms(2);
p27=1;
P0=table[t/10];
p26=0;
delayms(2);
p26=1;
if(write==1) //判断计时器是否计时一秒
write=0; //清零
write_address(6,t);//在24c08的地址2中写入数据sec
if(k1==0)
delayms(10);
if(k1==0)
t=0;
void t0() interrupt 1
uchar i;
i++;
if(i>=20)
i=0;
t+=1;
write=1;
if(t>=100)
t=0;
#include"delay.h"
#include<intrins.h>
void start()//开始信号
sda=1;
scl=1;
_nop_();_nop_();_nop_();_nop_();_nop_();
sda=0;
scl=0;
void stop()//终止信号
sda=0;
scl=1;
sda=1;
scl=0;
sda=0;
bit wait_nok()
bit ack_bit;
sda=1;
_nop_();_nop_();
scl=1;
ack_bit=sda;
scl=0;
return ack_bit;
void write_byte(uchar dat)
uchar i;
for(i=0;i<8;i++)
sda=(bit)(dat&0x80);
_nop_();
scl=1;
_nop_();_nop_();
scl=0;
dat<<=1;
uchar read_byte()
uchar i,k;
for(i=0;i<8;i++)
scl=1;
k<<=1;
k|=sda;
scl=0;
return (k);
void write_address(uchar add,uchar date)
start();
write_byte(0xa0);
wait_nok();
write_byte(add);
wait_nok();
write_byte(date);
wait_nok();
stop();
delayms(5);
uchar read_add(uchar add)
uchar m;
start();
write_byte(0xa0);
wait_nok();
write_byte(add);
wait_nok();
start();
write_byte(0xa1);
wait_nok();
m=read_byte();
stop();
return (m);
#ifndef __READ_WRITE_INIT_H__
#define __READ_WRITE_INIT_H__
//void init();
uchar read_byte();
uchar read_add(uchar add);
void write_address(uchar add,uchar date);
#include "delay.h"
void delay5us() //延迟5毫秒左右
void delayms(uchar a)
uchar k;
while(a--)
for(k=115;k>0;k--);
#ifndef __DELAY_H__
#define __DELAY_H__
#include<reg52.h>
sbit scl=P3^4;
sbit sda=P3^5;
sbit k1=P3^2;
sbit p27=P2^7;
sbit p26=P2^6;
//void delay5us();
void delayms(uchar a);
#endif |
