最近在研究mwc飞控的气压计定高算法,不知道有没有看过mwc代码的高手来分析一下此段代码
void getEstimatedAltitude(void)
uint32_t index;
static uint32_t deadLine = INIT_DELAY;
static int16_t BaroHistTab[BARO_TAB_SIZE];
static uint32_t BaroHistIdx;
static int32_t BaroHigh = 0;
static int32_t BaroLow = 0;
int32_t temp32;
int16_t last;
if (currentTime < deadLine)
return;
deadLine = currentTime + UPDATE_INTERVAL;
//**** Alt. Set Point stabilization PID ****
//calculate speed for D calculation
last = BaroHistTab[BaroHistIdx];
BaroHistTab[BaroHistIdx] = BaroAlt / 10;
BaroHigh += BaroHistTab[BaroHistIdx];
index = (BaroHistIdx + (BARO_TAB_SIZE / 2)) % BARO_TAB_SIZE;
BaroHigh -= BaroHistTab[index];
BaroLow += BaroHistTab[index];
BaroLow -= last;
BaroHistIdx++;
if (BaroHistIdx >= BARO_TAB_SIZE)
BaroHistIdx = 0;
BaroPID = 0;
//D
temp32 = cfg.D8[PIDALT] * (BaroHigh - BaroLow) / 40;
BaroPID -= temp32;
EstAlt = BaroHigh * 10 / (BARO_TAB_SIZE / 2);
temp32 = AltHold - EstAlt;
if (abs(temp32) < 10 && abs(BaroPID) < 10)
BaroPID = 0; // remove small D parameter to reduce noise near zero position
// P
BaroPID += cfg.P8[PIDALT] * constrain(temp32, (-2) * cfg.P8[PIDALT], 2 * cfg.P8[PIDALT]) / 100;
BaroPID = constrain(BaroPID, -150, +150); // sum of P and D should be in range 150
// I
errorAltitudeI += temp32 * cfg.I8[PIDALT] / 50;
errorAltitudeI = constrain(errorAltitudeI, -30000, 30000);
temp32 = errorAltitudeI / 500; // I in range +/-60
BaroPID += temp32; |
