LaunchPad_TemperSensor
- * MSP-EXP430G2-LaunchPad User Experience Application
- * 1. Device starts up in LPM3 + blinking LED to indicate device is alive
- * + Upon first button press, device transitions to application mode
- * 2. Application Mode
- * + Continuously sample ADC Temp Sensor channel, compare result against
- * initial value
- * + Set PWM based on measured ADC offset: Red LED for positive offset, Green
- * LED for negative offset
- * + Transmit temperature value via TimerA UART to PC
- * + Button Press --> Calibrate using current temperature
- * Send character '� via UART, notifying PC
- #include "msp430g2553.h"
- #define LED0 BIT0
- #define LED1 BIT6
- #define LED_DIR P1DIR
- #define LED_OUT P1OUT
- #define BUTTON BIT3
- #define BUTTON_OUT P1OUT
- #define BUTTON_DIR P1DIR
- #define BUTTON_IN P1IN
- #define BUTTON_IE P1IE
- #define BUTTON_IES P1IES
- #define BUTTON_IFG P1IFG
- #define BUTTON_REN P1REN
- #define TXD BIT1 // TXD on P1.1
- #define RXD BIT2 // RXD on P1.2
- #define APP_STANDBY_MODE 0
- #define APP_APPLICATION_MODE 1
- #define TIMER_PWM_MODE 0
- #define TIMER_UART_MODE 1
- #define TIMER_PWM_PERIOD 2000
- #define TIMER_PWM_OFFSET 20
- #define TEMP_SAME 0
- #define TEMP_HOT 1
- #define TEMP_COLD 2
- #define TEMP_THRESHOLD 5
- // Conditions for 9600/4=2400 Baud SW UART, SMCLK = 1MHz
- #define Bitime_5 0x05*4 // ~ 0.5 bit length + small adjustment
- #define Bitime 13*4//0x0D
- #define UART_UPDATE_INTERVAL 1000
- unsigned char BitCnt;
- unsigned char applicationMode = APP_STANDBY_MODE;
- unsigned char timerMode = TIMER_PWM_MODE;
- unsigned char tempMode;
- unsigned char calibrateUpdate = 0;
- unsigned char tempPolarity = TEMP_SAME;
- unsigned int TXByte;
- /* Using an 8-value moving average filter on sampled ADC values */
- long tempMeasured[8];
- unsigned char tempMeasuredPosition=0;
- long tempAverage;
- long tempCalibrated, tempDifference;
- void InitializeLeds(void);
- void InitializeButton(void);
- void PreApplicationMode(void); // Blinks LED, waits for button press
- void ConfigureAdcTempSensor(void);
- void ConfigureTimerPwm(void);
- void ConfigureTimerUart(void);
- void Transmit(void);
- void InitializeClocks(void);
- void main(void)
- unsigned int uartUpdateTimer = UART_UPDATE_INTERVAL;
- unsigned char i;
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT
- InitializeClocks();
- InitializeButton();
- InitializeLeds();
- PreApplicationMode(); // Blinks LEDs, waits for button press
- /* Application Mode begins */
- applicationMode = APP_APPLICATION_MODE;
- ConfigureAdcTempSensor();
- ConfigureTimerPwm();
- __enable_interrupt(); // Enable interrupts.
- /* Main Application Loop */
- while(1)
- ADC10CTL0 |= ENC + ADC10SC; // Sampling and conversion start
- __bis_SR_register(CPUOFF + GIE); // LPM0 with interrupts enabled
- /* Moving average filter out of 8 values to somewhat stabilize sampled ADC */
- tempMeasured[tempMeasuredPosition++] = ADC10MEM;
- if (tempMeasuredPosition == 8)
- tempMeasuredPosition = 0;
- tempAverage = 0;
- for (i = 0; i < 8; i++)
- tempAverage += tempMeasured[i];
- tempAverage >>= 3; // Divide by 8 to get average
- if ((--uartUpdateTimer == 0) || calibrateUpdate )
- ConfigureTimerUart();
- if (calibrateUpdate)
- TXByte = 248; // A character with high value, outside of temp range
- Transmit();
- calibrateUpdate = 0;
- TXByte = (unsigned char)( ((tempAverage - 630) * 761) / 1024 );
- Transmit();
- uartUpdateTimer = UART_UPDATE_INTERVAL;
- tempDifference = tempAverage - tempCalibrated;
- if (tempDifference < -TEMP_THRESHOLD)
- tempDifference = -tempDifference;
- tempPolarity = TEMP_COLD;
- LED_OUT &= ~ LED1;
- else
- if (tempDifference > TEMP_THRESHOLD)
- tempPolarity = TEMP_HOT;
- LED_OUT &= ~ LED0;
- else
- tempPolarity = TEMP_SAME;
- TACCTL0 &= ~CCIE;
- TACCTL1 &= ~CCIE;
- LED_OUT &= ~(LED0 + LED1);
- if (tempPolarity != TEMP_SAME)
- tempDifference <<= 3;
- tempDifference += TIMER_PWM_OFFSET;
- TACCR1 = ( (tempDifference) < (TIMER_PWM_PERIOD-1) ? (tempDifference) : (TIMER_PWM_PERIOD-1) );
- TACCTL0 |= CCIE;
- TACCTL1 |= CCIE;
- LED_DIR |= LED0 + LED1;
- LED_OUT |= LED0; // To enable the LED toggling effect
- LED_OUT &= ~LED1;
- BCSCTL1 |= DIVA_1; // ACLK/2
- BCSCTL3 |= LFXT1S_2; // ACLK = VLO
- TACCR0 = 1200; //
- TACTL = TASSEL_1 | MC_1; // TACLK = SMCLK, Up mode.
- TACCTL1 = CCIE + OUTMOD_3; // TACCTL1 Capture Compare
- TACCR1 = 600;
- __bis_SR_register(LPM3_bits + GIE); // LPM0 with interrupts enabled
- unsigned char i;
- /* Configure ADC Temp Sensor Channel */
- ADC10CTL1 = INCH_10 + ADC10DIV_3; // Temp Sensor ADC10CLK/4
- ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;
- __delay_cycles(1000); // Wait for ADC Ref to settle
- tempCalibrated = ADC10MEM;
- for (i=0; i < 8; i++)
- tempMeasured[i] = tempCalibrated;
- tempAverage = tempCalibrated;
- timerMode = TIMER_PWM_MODE;
- TACCR0 = TIMER_PWM_PERIOD; //
- TACTL = TASSEL_2 | MC_1; // TACLK = SMCLK, Up mode.
- TACCTL0 = CCIE;
- TACCR1 = 1;
- timerMode = TIMER_UART_MODE; // Configure TimerA0 UART TX
- CCTL0 = OUT; // TXD Idle as Mark
- TACTL = TASSEL_2 + MC_2 + ID_3; // SMCLK/8, continuous mode
- P1SEL |= TXD + RXD; //
- P1DIR |= TXD; //
- // Function Transmits Character from TXByte
- void Transmit()
- BitCnt = 0xA; // Load Bit counter, 8data + ST/SP
- while (CCR0 != TAR) // Prevent async capture
- CCR0 = TAR; // Current state of TA counter
- CCR0 += Bitime; // Some time till first bit
- TXByte |= 0x100; // Add mark stop bit to TXByte
- TXByte = TXByte << 1; // Add space start bit
- CCTL0 = CCIS0 + OUTMOD0 + CCIE; // TXD = mark = idle
- while ( CCTL0 & CCIE ); // Wait for TX completion
- // Timer A0 interrupt service routine
- #pragma vector=TIMER0_A0_VECTOR
- __interrupt void Timer_A (void)
- if (timerMode == TIMER_UART_MODE)
- CCR0 += Bitime; // Add Offset to CCR0
- if (CCTL0 & CCIS0) // TX on CCI0B?
- if ( BitCnt == 0)
- CCTL0 &= ~ CCIE; // All bits TXed, disable interrupt
- else
- CCTL0 |= OUTMOD2; // TX Space
- if (TXByte & 0x01)
- CCTL0 &= ~ OUTMOD2; // TX Mark
- TXByte = TXByte >> 1;
- BitCnt --;
- else
- if (tempPolarity == TEMP_HOT)
- LED_OUT |= LED1;
- if (tempPolarity == TEMP_COLD)
- LED_OUT |= LED0;
- TACCTL0 &= ~CCIFG;
- #pragma vector=TIMER0_A1_VECTOR
- __interrupt void ta1_isr(void)
- TACCTL1 &= ~CCIFG;
- if (applicationMode == APP_APPLICATION_MODE)
- else
- LED_OUT ^= (LED0 + LED1);
- BCSCTL1 = CALBC1_1MHZ; // Set range
- DCOCTL = CALDCO_1MHZ;
- BCSCTL2 &= ~(DIVS_3); // SMCLK = DCO / 8 = 1MHz
- void InitializeButton(void) // Configure Push Button
- BUTTON_DIR &= ~BUTTON;
- BUTTON_OUT |= BUTTON;
- BUTTON_REN |= BUTTON;
- BUTTON_IES |= BUTTON;
- BUTTON_IFG &= ~BUTTON;
- BUTTON_IE |= BUTTON;
- * Port Interrupt for Button Press
- * 1. During standby mode: to exit and enter application mode
- * 2. During application mode: to recalibrate temp sensor
- #pragma vector=PORT1_VECTOR
- __interrupt void PORT1_ISR(void)
- BUTTON_IFG = 0;
- BUTTON_IE &= ~BUTTON; /* Debounce */
- WDTCTL = WDT_ADLY_250;
- IFG1 &= ~WDTIFG; /* clear interrupt flag */
- IE1 |= WDTIE;
- tempCalibrated = tempAverage;
- calibrateUpdate = 1;
- else
- applicationMode = APP_APPLICATION_MODE; // Switch from STANDBY to APPLICATION MODE
- __bic_SR_register_on_exit(LPM3_bits);
- #pragma vector=WDT_VECTOR
- __interrupt void WDT_ISR(void)
- IE1 &= ~WDTIE; /* disable interrupt */
- WDTCTL = WDTPW + WDTHOLD; /* put WDT back in hold state */
- BUTTON_IE |= BUTTON; /* Debouncing complete */
- // ADC10 interrupt service routine
- #pragma vector=ADC10_VECTOR
- __interrupt void ADC10_ISR (void)
- __bic_SR_register_on_exit(CPUOFF); // Return to active mode
复制代码 .
LaunchPad_Lab2
- // LaunchPad Lab2 - Software Toggle P1.0,
- // MSP430G2xx2
- // /|\| XIN|-
- // --|RST XOUT|-
- // | P1.0|-->LED
- #include <msp430g2553.h>
- void main(void)
- WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
- if (CALBC1_1MHZ == 0xFF || CALDCO_1MHZ == 0xFF)
- while(1); // If calibration constants erased, trap CPU!!
- // Configure Basic Clock
- DCOCTL = CALDCO_1MHZ; // Set DCO step + modulation
- BCSCTL3 |= LFXT1S_2; // Set LFXT1
- P1DIR = BIT6; // P1.6 output (green LED)
- P1OUT = 0; // LED off
- IFG1 &= ~OFIFG; // Clear OSCFault flag
- BCSCTL2 |=SELM_1 + DIVM_0; // Set MCLK
- for(;;)
- P1OUT = BIT6; // P1.6 on (green LED)
- _delay_cycles(100);
- P1OUT = 0; // green LED off
- _delay_cycles(5000);
复制代码 .
LaunchPad_Lab3
- // LaunchPad Lab3 - Software Port Interrupt Service
- // MSP430G2xx2
- // /|\| XIN|-
- // --|RST XOUT|-
- // --o--|P1.3 P1.0|-->LED
- void main(void)
- P1DIR |= BIT0; // Set P1.0 to output direction
- P1IES |= BIT3; // P1.3 Hi/lo edge
- P1IFG &= ~BIT3; // P1.3 IFG cleared
- P1IE |= BIT3; // P1.3 interrupt enabled
- _BIS_SR(LPM4_bits + GIE); // Enter LPM4 w/interrupt
- // Port 1 interrupt service routine
- __interrupt void Port_1(void)
- if (P1IFG & BIT3)
- P1OUT ^= BIT0; // P1.0 = toggle
复制代码 .
LaunchPad_Lab4
- // LaunchPad Lab4 - Timer Toggle P1.6,
- // MSP430G2452
- // /|\| XIN|-
- // --|RST XOUT|-
- // | P1.6|-->LED
- void main(void)
- if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF)
- BCSCTL3 |= LFXT1S_2; // LFXT1 = VLO
- P1DIR = 0x40; // P1.6 output (green LED)
- BCSCTL1 |= DIVA_3; // ACLK = VLO/8
- BCSCTL2 |= SELM_3 + DIVM_3 + DIVS_3; // MCLK = DCO/8, SMCLK = DCO/8
- // Configure TimerA
- TACTL = TASSEL_1 + MC_1 + TAIE; // Source: ACLK, UP mode
- CCR0 = 5100; //Timer count 5100
- CCR1 = 2000; //Timer count 100
- CCTL0 = CCIE; //CCR0 interrupt enabled
- CCTL1 = CCIE; //CCR1 interrupt enabled
- _BIS_SR(GIE);
- for(;;);
- __interrupt void Timer_A0 (void)
- P1OUT |= BIT6; // P1.6 output High
- // Timer A1 Interrupt Vector (TA0IV) handler
- __interrupt void Timer_A1(void)
- switch( TA0IV )
- case 2: P1OUT &= ~BIT6; // P1.6 output Low
- break;
- case 10:
- break;
复制代码 .
LaunchPad_Lab5
- // LaunchPad Lab5 - Timer Toggle P1.6 with Low Power Mode
- // MSP430G2452
- // /|\| XIN|-
- // --|RST XOUT|-
- // | P1.6|-->LED
- #include <msp430g2452.h>
- void main(void)
- //TACTL = TASSEL_2 + MC_1; // SMCLK, UP mode
- TACTL = TASSEL_1 + MC_1; // ACLK, UP mode
- CCTL0 = CCIE; //interrupt enabled
- CCTL1 = CCIE; //interrupt enabled
- _BIS_SR(LPM0_bits + GIE); //Enter Low Power Mode
- for(;;);
- // Timer_A2 Interrupt Vector (TA0IV) handler
- switch( TA0IV )
- break;
- case 10:
- break;
复制代码 .
LaunchPad_Lab6- //******************************************************************************
- // LaunchPad Lab5 - ADC10, Sample A10 Temp and Convert to oC and oF
- // MSP430G2452
- // /|\| XIN|-
- // --|RST XOUT|-
- // |A10 |
- long temp;
- long IntDegF;
- long IntDegC;
- void main(void)
- //Configure ADC10
- ADC10CTL1 = INCH_10 + ADC10DIV_3; // Choose ADC Channel as Temp Sensor
- ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE; //Choose ADC Ref source
- TACCR0 = 30; // Delay to allow Ref to settle
- TACCTL0 |= CCIE; // Compare-mode interrupt.
- LPM0; // Wait for delay.
- TACCTL0 &= ~CCIE; // Disable timer Interrupt
- __disable_interrupt();
- while(1)
- __bis_SR_register(LPM0_bits + GIE); // LPM0 with interrupts enabled
- // oF = ((A10/1024)*1500mV)-923mV)*1/1.97mV = A10*761/1024 - 468
- temp = ADC10MEM;
- IntDegF = ((temp - 630) * 761) / 1024;
- // oC = ((A10/1024)*1500mV)-986mV)*1/3.55mV = A10*423/1024 - 278
- temp = ADC10MEM;
- IntDegC = ((temp - 673) * 423) / 1024;
- __no_operation(); // SET BREAKPOINT HERE
- __bic_SR_register_on_exit(LPM0_bits); // Clear CPUOFF bit from 0(SR)
- __interrupt void ta0_isr(void)
- TACTL = 0;
复制代码 .
GUI是用于第一个实验的PC上位机
