发表于 2013-5-6 08:43:47
- #ifndef ADNS9500_HPP_
- #define ADNS9500_HPP_
- #include <mbed.h>
- #include <stdint.h>
- #include <string>
- #define ADNS9500_CONFIGURATION_II_RPT_MOD (1 << 2)
- #define ADNS9500_CONFIGURATION_IV_SROM_SIZE (1 << 1)
- #define ADNS9500_LASER_CTRL0_FORCE_DISABLED (1 << 0)
- #define ADNS9500_OBSERVATION_CHECK_BITS 0x3f
- #define ADNS9500_HAS_MOTION_DETECTED(x) (bool)(x & 0x80)
- #define ADNS9500_HAS_LASER_FAULT(x) (bool)(x & 0x40)
- #define ADNS9500_IS_RUNNING_SROM_CODE(x) (bool)(x & 0x80)
- #define ADNS9500_HAS_FIRST_PIXEL(x) (bool)(x & 0x01)
- #define ADNS9500_PASS_OBSERVATION_TEST(x) (bool)(x & ADNS9500_OBSERVATION_CHECK_BITS)
- #define ADNS9500_UINT16(ub, lb) (uint16_t)(((ub & 0xff) << 8) | (lb & 0xff))
- #define ADNS9500_INT16(ub, lb) (int16_t)(((ub & 0xff) << 8) | (lb & 0xff))
- namespace adns9500
- // Maximum SPI clock frequency supported by the sensor
- const int MAX_SPI_FREQUENCY = 2000000;
- // Internal oscillator norminal frequency
- const int INTERNAL_OSCILLATOR_FREQUENCY = 47000000;
- // Number of pixels per frame
- const int NUMBER_OF_PIXELS_PER_FRAME = 900;
- // Maximum surface quality
- const int MAX_SURFACE_QUALITY = 676; // 169 * 4
- // Sensor registers
- enum Register
- PRODUCT_ID = 0x00,
- REVISION_ID = 0x01,
- MOTION = 0x02,
- DELTA_X_L = 0x03,
- DELTA_X_H = 0x04,
- DELTA_Y_L = 0x05,
- DELTA_Y_H = 0x06,
- SQUAL = 0x07,
- PIXEL_SUM = 0x08,
- MAXIMUM_PIXEL = 0x09,
- MINIMUM_PIXEL = 0x0a,
- SHUTTER_LOWER = 0x0b,
- SHUTTER_UPPER = 0x0c,
- FRAME_PERIOD_LOWER = 0x0d,
- FRAME_PERIOD_UPPER = 0x0e,
- CONFIGURATION_I = 0x0f,
- CONFIGURATION_II = 0x10,
- FRAME_CAPTURE = 0x12,
- SROM_ENABLE = 0x13,
- LASER_CTRL0 = 0x20,
- DATA_OUT_LOWER = 0x25,
- DATA_OUT_UPPER = 0x26,
- SROM_ID = 0x2a,
- OBSERVATION = 0x24,
- CONFIGURATION_V = 0x2f,
- CONFIGURATION_IV = 0x39,
- POWER_UP_RESET = 0x3a,
- MOTION_BURST = 0x50,
- SROM_LOAD_BURST = 0x62,
- PIXEL_BURST = 0x64
- // Supported resolutions
- enum Resolution
- CPI_90 = 0x01,
- CPI_1630 = 0x12,
- CPI_3240 = 0x24,
- CPI_5040 = 0x38
- // Motion burst data
- struct MotionData
- MotionData()
- : motion(0), observation(0), dx(0), dy(0), dxMM(0), dyMM(0),
- surfaceQuality(0), averagePixel(0), maximumPixel(0),
- minimumPixel(0), shutter(0), framePeriod(0)
- int motion;
- int observation;
- int dx;
- int dy;
- float dxMM;
- float dyMM;
- int surfaceQuality;
- float averagePixel;
- int maximumPixel;
- int minimumPixel;
- int shutter;
- int framePeriod;
- // Interface to access to ADNS-9500 mouse sensor
- class ADNS9500
- public:
- // Create the sensor interface
- // @param mosi MOSI pin for the SPI interface
- // @param miso MISO pin for the SPI interface
- // @param sclk SCLK pin for the SPI interface
- // @param spi_frequency SPI clock frequency in Hz up to MAX_SPI_PORT_FREQUENCY
- // @param ncs A digital active-low output pin for sensor chip select
- // @param motion A digital active-low input pin activated by the sensor when motion
- // is detected
- ADNS9500(PinName mosi, PinName miso, PinName sclk, PinName ncs,
- int spi_frequency = MAX_SPI_FREQUENCY, PinName motion = NC);
- // Destroy de sensor interface
- ~ADNS9500();
- // Power up/reset the sensor
- // Terminate with error if the connection can not be established
- // @param firmware If the firmware has to be downloaded, C-string containing the name
- // of the file where it is stored, or NULL in other case
- void reset(const char* firmware = NULL);
- // Shutdown the sensor
- void shutdown();
- // Read the value of a sensor register
- // @param lregister The register which to read its value
- // @return The value of the register
- int read(Register lregister);
- // Read the values of sensor registers
- // @param uregister The register which to read the upper byte
- // @param lregister The register which to read the lower byte
- // @return The values of registers as a 16-bit integer, putting the value
- // of uregister in the upper byte and the value of lregister in the
- // lower byte
- int read(Register uregister, Register lregister);
- // Get information about sensor status
- // @return The value of MOTION register. It tells if motion or laser fault
- // conditions have ocurred, laser power setting status and operating
- // mode in current frame
- int status()
- { return read(MOTION); }
- // Download the firmware to the sensor SROM
- // @param filename The name of the file which contains the sensor firmware
- // @return The SROM CRC value
- int sromDownload(const char* filename);
- // Enable the laser
- // @param enable True if laser must be enabled, or false if laser must be disabled
- void enableLaser(bool enable=true);
- // Get motion deltas from sensor
- // @param dx The component X of displacement
- // @param dy The component Y of displacement
- // @return True if motion was occurred since the last time the function was called,
- // or false in other case
- bool getMotionDelta(int& dx, int& dy);
- // Get motion deltas in mm. from sensor
- // @param dx The component X of displacement in mm.
- // @param dy The component Y of displacement in mm.
- bool getMotionDeltaMM(float& dx, float& dy);
- // Get all information about motion
- // @param data The struct where sensor data will be stored
- bool getMotionData(MotionData& data);
- // Set the resolution on XY axes together
- // @param xy_resolution The resolution for X-axis and Y-axis
- void setResolution(Resolution xy_resolution);
- // Set the resolutions on X-axis and Y-axis
- // @param x_resolution The resolution for X-axis
- // @param y_resolution The resolution for Y-axis
- void setResolution(Resolution x_resolution, Resolution y_resolution);
- // Get a full array of pixel values from a single frame.
- // This disables navigation and overwrites any donwloaded firmware,
- // so call to reset() is needed to restore them
- // @param pixels A pointer to the array where pixel values will be stored
- void captureFrame(uint8_t* pixels);
- // Member function invoked when motion has ocurred and if a motion pin
- // was specified when the object constructor was called.
- // By default it invokes the function specified by a previous call to attach()
- virtual void motionTrigger()
- { motionTrigger_.call(); }
- // Attach a function to call when a falling edge occurs on motion pin
- // @param function A pointer to a function or 0 to set the attached function as none
- void attach(void (*function)(void))
- { motionTrigger_.attach(function); }
- // Attach a member function to call when a falling edge occurs on motion pin
- // @param object A reference to the object to call the member function on
- // @param function A pointer to the member function to be called
- template<typename T>
- void attach(T& object, void (T::*member)(void))
- { motionTrigger_.attach(object, member); }
- private:
- SPI spi_;
- InterruptIn motion_;
- DigitalOut ncs_;
- bool enabled_;
- int xCpi_, yCpi_;
- FunctionPointer motionTrigger_;
- // Write a byte to the specified register
- // @param address The register address
- // @param value The value to be written to the register
- void spiSend(Register address, int value);
- // Read a byte from the specified register
- int spiReceive(Register address);
- #endif /* ADNS9500_HPP_ */
复制代码 |
