用的HOT51增强型板子做的,AD芯片PCF8591T。
无论用电位器调电阻,热敏电阻,光敏电阻,电压只能变化 000 125 250 375 498 几个值?
求大神 指导!
#include<reg52.h> //包含头文件,一般情况不需要改动
#include<intrins.h>
#define uint unsigned int
uchar a,bai,shi,ge;
float V1;
int V;
uchar code num[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void display(uchar,uchar,uchar,uchar,uchar,uchar);
sbit sda=P3^6; //AD定义 I2c总线
sbit scl=P1^5;
#define AddWr 0x90 //写数据地址
#define AddRd 0x91 //读数据地址
void delay()
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
void start() //开始信号
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop() //停止
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons() //应答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
// scl=0;
// delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
k=0;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=k<<1;
k=k|sda;
scl=0;
delay();
return k;
void delay2()
uint a;
for(a=1000;a>0;a--);
unsigned char AD_trans()
unsigned char dat;
start();
write_byte(0x90);
respons();
write_byte(0x01);
respons();
start();
write_byte(0x91);
respons();
dat=read_byte();
stop();
return dat;
void main()
init();
V1=AD_trans()*(5.0/256.0);
stop();
V1=V1*100;
V=(int)V1;
P2=0x00;
P0=num[V/100];
delay2();
P0=0x00;
P2=0x01;
P0=num[V%100/10];
delay2();
P0=0x00;
P2=0x02;
P0=num[V%100%10];
delay2();
P0=0x00;
